9.2 BTU Low profile AC
Started by hdrehder, September 16, 2014, 11:22:51 PM
hdrehder
I opted for the lessor AC unit so we could run it more easily from a small generator. It makes more noise than any other in the park. We've considered replacing but I don't want that expense. Anyone else have this experience or any advice.
I have the same A/C unit than you but I haven't really had a chance to try it out more than in the dealer lot (only camped with no hookup) next time I have a chance to try it I will pay attention to see if it make more noise.
Mine is also noisy.  I assume you mean noisy on the inside of the trailer?    That being said, my in-laws who are lifelong RV owners said that ours is very typical noise wise and that they've had plenty of lAC units just as loud.    If you think about it it is a window unit essentially inside the confines of the walls of the trailer rather than "outside".   The cabinet housing the AC does nothing to block the sound compared to if it were installed in a typical house window as it was designed to go where the back end is out away from the house.    The majority of the noise of the motor, compressor etc. is outside the walls of the house normally.   The use of a window unit in a camper is not really it's intended purpose.    I've made peace with it and don't mind it as much as I first did.   It does cut a lot of the exterior noise out if you are stuck next to some noisy camping neighbors.   You could try replacing it, but I wouldn't be suprised if it was just as noisy.
[quote source="/post/3630/thread" timestamp="1410987623" author="@tlbones"]Mine is also noisy.  I assume you mean noisy on the inside of the trailer?    That being said, my in-laws who are lifelong RV owners said that ours is very typical noise wise and that they've had plenty of lAC units just as loud.    If you think about it it is a window unit essentially inside the confines of the walls of the trailer rather than "outside".   The cabinet housing the AC does nothing to block the sound compared to if it were installed in a typical house window as it was designed to go where the back end is out away from the house.    The majority of the noise of the motor, compressor etc. is outside the walls of the house normally.   The use of a window unit in a camper is not really it's intended purpose.    I've made peace with it and don't mind it as much as I first did.   It does cut a lot of the exterior noise out if you are stuck next to some noisy camping neighbors.   You could try replacing it, but I wouldn't be suprised if it was just as noisy.   [/quote]The 9.2k btu low profile AC that we both have is not a house unit like yours, it's a roof mounted one
[quote source="/post/3633/thread" timestamp="1410992898" author="@paul"][quote source="/post/3630/thread" timestamp="1410987623" author="@tlbones"]Mine is also noisy.  I assume you mean noisy on the inside of the trailer?    That being said, my in-laws who are lifelong RV owners said that ours is very typical noise wise and that they've had plenty of lAC units just as loud.    If you think about it it is a window unit essentially inside the confines of the walls of the trailer rather than "outside".   The cabinet housing the AC does nothing to block the sound compared to if it were installed in a typical house window as it was designed to go where the back end is out away from the house.    The majority of the noise of the motor, compressor etc. is outside the walls of the house normally.   The use of a window unit in a camper is not really it's intended purpose.    I've made peace with it and don't mind it as much as I first did.   It does cut a lot of the exterior noise out if you are stuck next to some noisy camping neighbors.   You could try replacing it, but I wouldn't be suprised if it was just as noisy.   [/quote]The 9.2k btu low profile AC that we both have is not a house unit like yours, it's a roof mounted one
[/quote]Ahh....my bad.   Perhaps there is something wrong then?
They are a bit noisy. It is mostly noise from the blower. The low profile configuration probably contributes to the noise, but I doubt if you would see much difference if you replaced it with a bigger, taller unit.
hdrehder
Thanks for the replies. I don't mind the interior noise. Have gotten accustomed to that. It just freezes us out sometimes and I have to get up and turn it down a few times during the night. AND, we've been camping in 100+ weather. It's effective.
The bother is the exterior noise, and only when the compressor kicks in. That's when I feel bad for any tent campers around us. Our roof unit is twice or more as loud as any others I've heard.
If it is compressor noise, maybe you have something loose inside. Mine isn't particularly noisy outside.
hdrehder
[quote source="/post/3646/thread" timestamp="1411040990" author="@david"]If it is compressor noise, maybe you have something loose inside. Mine isn't particularly noisy outside.
David[/quote]Glad to hear a comparison. Think I'll have it checked. Thanks.
wvabeer
Mine is noisy as well. WAAAY louder than any other a/c. The condenser fan is the loudest I have ever heard.
This week we had our first chance for extended use of our Coleman-Mach 9200 Btu roof air conditioner. We tested it last fall to make sure it ran and cooled, but didn't use it until camping in 80+ weather this week. I think that unit is an epic fail and so far it's the only thing I don't like about our Camplite. It cooled fine, but what a noise! The circulating fan inside is ok for noise on low, but obnoxiously noisy on high. It's too bad it runs all the time and doesn't shut off with the cycling of the compressor. That seems uselessly inefficient but maybe they do that so you don't get shocked awake when the unit kicks on. The real noise problem is with the compressor and the outside fan. When the compressor turns on, it creates a low frequency vibration inside that pulses at about 3 cycles per second. You can feel it in the roof and walls and it's a headache waiting to happen with prolonged use. Outside, the exterior fan/compressor noise is truly disruptive. Ours was by far the loudest in the campground loop were we on and I felt sorry for our neighbors. There is simply no excuse for noise like that, other than super cheap design and construction. For comparison, our home air conditioner, at many times the cooling power, has an almost silent compressor and condenser fan. I'll check the mounting screws up on top and make sure things are tight inside. I'm a big fan of Dynamat for reducing unwanted vibration when installing speakers and maybe I'll poke around a bit and see if some sound-deadening could be useful. We can't afford to replace it with a better unit right now, but until we can "make peace with it" (as tibones suggested for his window unit), it may reduce our interest in camping in hot weather.
I cant imagine an AC unit noisier then my 13.5BTU in the 21RBS.   I use to sleep (On the sub) very close to the CO2 scrubber and O2 gens. So I can sleep in most noisey environments. Just has to be 99.9999% dark :-)
We have the 13.5 roof mount on our Mighty 11. Capable of making the 11 very cool.
Makes plenty of interior noise too. It's equipped with heat strip, but use a bathroom stye heater for heat down to 20s.
Positive side of interior AC noise, camped at campgrounds with groups noisy past midnight and found turning the fan on, even if cooling is not needed, usually drowns out outside noise.
hdrehder
[quote source="/post/11974/thread" timestamp="1433530221" author="@sandroad"]...Outside, the exterior fan/compressor noise is truly disruptive. Ours was by far the loudest in the campground loop were we on and I felt sorry for our neighbors. ...[/quote]Merlin, we have the same issue.  I absolutely HATE the exterior noise.  I don't like, but can handle, the interior noise.  I despise disrupting our campground neighbors, especially those in tents.
We have the camper in the shop for final warrantee work and this is one of the things we asked them to check.  They said all was fine and that it is just naturally loud.  If you find any ways to dampen it, I'll be very interested!
widgetwizard
You all know I hope that the Casita folks asked us to fix that outside noise problem on the Coleman Mach 8 A/C.
Well - we have a fix if you are interested.  Scoot over to [a href="http://www.perfectcasita.com/fred.html"]Mach 8 hush kits [/a]for all the details.
Basically we slowed down the "new" fan to match the output of the original very noisy one, made it respond to the internal hi/lo setting, and modified the plastic grille.
Check it out if you are interested. We cant build these kits fast enough so might be out of stock for a few days.
Cheers,
Jim
