9.2 BTU Low profile AC
Started by hdrehder, September 16, 2014, 11:22:51 PM
Widgetwizard- you didn't happen to make a hush kit for the Dometic 13.5 BTU low profile penguin AC, did you?
Jim at widgetwizard: Just sent in my order for the complete kit. I sure hope it helps!
widgetwizard
Quote from: @gbpack" source="/post/18956/thread" timestamp="1456409489Widgetwizard- you didn't happen to make a hush kit for the Dometic 13.5 BTU low profile penguin AC, did you?
Nope.  Just the Mach 8.
Jim
widgetwizard
[quote source="/post/18964/thread" timestamp="1456426913" author="@sandroad"]Jim at widgetwizard: Just sent in my order for the complete kit. I sure hope it helps! [/quote]I'm sure it will. Please report back with the results!
(looks like a 3-day ship to your part of the world so you should get it Tues)
Cheers,
Jim
montedtrotter1
Jim, does the hush kit improve the interior noise as well?
I caught a lot of heat (literally) from my bride for not running the AC unit near tent campers this past summer due to the AC noise. I have a 2015 21BHS, produced in Jan-Feb 2015. Not sure if I need the full kit or just the fan controller?
I see from other sites that the kit is getting rave reviews, but there is a question as to what is actually needed, full or partial kit. I see Merlin has ordered the full kit. I may wait a couple of weeks to see how his turns out.
I am doing everything I can to reduce noise, maybe this will be one of the last modifications! Not! I have decided that being a travel trailer owner is like being a golfer, that new club will shave 5 strokes off your game. The next mod, heat strip, roof coating, insulation, better battery, better thermostat, better step, better tires, and many many others,(pick one) will improve your camping experience. It is truly amazing that almost after every trip we get back home with one or two things we want to improve. This is a big one however that I hope will truly create a better experience for us and our neighbors.
widgetwizard
Quote from: @montedtrotter1" timestamp="1456450634" source="/post/18972/threadJim, does the hush kit improve the interior noise as well?
Monte,
We only tackled the exterior noise - but since that is also audible inside we reduced the inside noise a bit too.
But I dont have any dB values for the inside to brag about.
Most folks only need the partial kit.  Coleman (Airxcel) should have already supplied the needed replacement fan blade.
If you climb up there and remove 4 screws you can get the external shroud off.
Then just check the part number on the obvious fan blade.
If its got 6 blades you should be able to get a 3 blade from Airxcel.
If it is a 3 blade check the part number. The "B" series blades break.
You must have a series "D" blade. Check the number on the top of the blade. 1472B504 is B series and 1472D504 is a D series. You need the D one.
If they will not give you a replacement blade you need the 'full' kit.
Full details [a href="http://www.perfectcasita.com/ma8norefukit.html"]here
[/a]
Its all a bit confusing - but let me know if you need more info.
Jim
These trailers are fun to mod!  They are never "done" to my mind. I've had some luck with inside noise from the A/C by replacing the filter material and extensive use of Dynamat and Fatmat. I'll post up some photos and complete description as soon as I can get back into the camper (ice melts!). The outside is the main problem now and I think the noise reduction kit will really help the inside. On mine you can certainly tell when the outside part of the system cycles on, even when you're inside!
widgetwizard
For those of you that don't follow the Orbital Machine Works Facebook page....
Free Mach 8 hush kit.  Interested?.  What we are looking for are short videos that show how easy the install is and the noise difference between before and after.  We never seem to get around to making these things. So we thought - why not bribe our customers to do it for us.  Rules are simple - video the noise your A/C makes now,  you installing the kit, then the noise it makes after (from the same place - no cheating).  Upload the video to YouTube somewhere and send us the link. Best one (in our humble opinion) gets their money back on the kit.  Deadline for submission is March 31 2016. Simple eh?  What are you waiting for.
montedtrotter1
So very true about the modifications! I have to believe I am getting near the bottom of list however.  I have few more to go that have been fairly low on the priority list. I just changed out the single speed fans today for three speeds fans with two speeds in reverse. Now we can us the low speed and exhaust air or put in reverse and pull air in. The low speed is much quieter than the single speed. These were the replacement kits or guts for the Heng's vortex fans so all work is from the inside.
My bride is right now modifying the shower curtain for the third time. We replaced the plastic curtain with a nylon curtain, cut it down to a shorter/more narrow size. Now cutting it down even more for less material and adding velcro about three 3' from the top so we can "stick it to the sides" to stay in place better than it does now. Maybe the third time is the charm.
The next mod will be the AC hush kit then solid surface counter top as ours is already stained from a glass of something? The laminate is coming "aloose" as they say in GA and we will probably change the sink and faucet at the same time.
We are checking into replacing the led lights with dimmable led bulbs but not sure how practical this will be. We want to put one dim switch on the current on-off switch for dimming. We bought a package of six dimmable led button type lights at Costco and they work great as they dim to 10, 40, 60 and I believe 80%, they make a huge difference in ambient lighting especially in the morning when I am up having coffee reading the paper and bride is still trying to sleep.
Also looking at changing the mattress for 4-inch foam and then a mattress topper. This is what we did for the bunks and my bride says they are great now. The foam will be less weight and trimmed to a better fitting size than the mattress/topper.
But I am sure there will be others mods that come up as well, dash camera and camera for rear of trailer that works all the time, not just when backing up.
I think you may be right Merlin, Never Done!
[quote timestamp="1456799742" author="@montedtrotter1" source="/post/19064/thread"]So very true about the modifications! I have to believe I am getting near the bottom of list however..............
[/quote][font size="3"]Monte,
You're not even close to being finished with mods  ;)       . Here's what I've done before and after delivery:
Camplite 21RBS Mods
(As of Feb 20, 2016)
Ordered from the factory
1.   External and internal color selection, exterior blackout package
2.   Dinette vs sofa option
3.   Microwave and A/C
4.   Gas/electric water heater
5.   Dual propane tanks and dual battery holder
6.   Black tank flusher
7.   Enhanced rear bumper
8.   Skylight in shower
9.   Twelve volt outlet in bathroom
10.   Off road axles and tires
11.   Spray on chassis insulation (not recommended)
After delivery
1.   Installed dual 6 volt GC2 batteries
2.   Installed 7/8 inch thick rubber tile floor covering
3.   Installed Fifteen foot RhinoFlex sewer hose and 60 inch carrier. Moved OEM carrier to curb side
4.   Additional ten foot RhinoFlex extension and 42" carrier
5.   Added twelve volt LED night light in bath
6.   Attached full length mirror to bathroom door. Added LED light bar above bath door to improve mirror illumination
7.   Installed external rear view camera. Monitor in tow vehicle.
8.   Added twelve volt outlets beside bed, under dinette window, on TV table
9.   Replaced OEM thermostat with electronic thermostat
10.   Added LED spotlights above bed. Original lights moved to cabinets below sink
11.   Added wireless rear view camera on roof
12.   Placed Command Strip hooks everywhere, paper towel holder
13.   Installed SeeLevel tank monitor
14.   Replaced dinette table with larger custom table secured to wall. Removed post.
15.   Added 3.75 inches to dinette seat base
16.   Replaced dinette cushions with custom marine grade HR50 dinette cushions
17.   Added Oxygenics shower sprayer with Danco shutoff and swivel wall mount
18.   Replaced three vent fans with Fantastic vents. UltraBreeze deflectors on kitchen and bedroom vents.
19.   Installed Atwood power tongue jack
20.   Inverted spare tire to enable checking inflation without removal
21.   Added spacers to ensure  window latch engagement
22.   Installed Wilson Sleek cell phone amplifier with external antenna
23.   Installed SiriusXM satellite radio with external antenna
24.   Installed Majestic 19 inch 12 volt LED TV
25.   Installed Swagman Traveler XC 2 RV two bike platform carrier
26.   Installed refrigerator frame heater disable switch in outside access compartment
27.   Added three 12V outlets on slide near floor for dinette
28.   Replaced tongue coupler with heavier unit and  2  5/16" ball. Installed two side bolts.
29.   Added trash can and two storage tubes mounted on slide
30.   Upgraded bathroom sink faucet to single handle chrome model
31.   Added magnetic catches to hold above bed cabinets open
32.   Replaced and upgraded kitchen sink
33.   Insulated exterior water pipes
34.   Removed small brake battery and connected to main battery
35.   Installed HW circulator antifreeze-up  system
36.   New (second) dinette table replacement, detachable leaf.
Just something to occupy your weekends. All except the last one have been described somewhere on this forum.
Camp on![/font]
Besides, what else can we do in Michigan in February besides mods?
To permanently eliminate the shower curtain hassle, I highly recommend a folding shower door. Here is what we have. It works wonderful and was only about an hour install.
http://www.amazon.com/Irvine-3657SI-Ivory-Shower-Door/dp/B001FCBAII/ref=sr_1_7?s=hi&ie=UTF8&qid=1456802487&sr=1-7&keywords=shower+door
I am also working on dimming the lights over the beds. I have a slide-dimmer for the LED fixture that may work. If it does, I'll post the details. If it doesn't, I'll edit this post to deny everything.
This thread sure suffers from thread drift! Might want to continue in the Mods section.........
Just received the Mach 8 "hush kit". Looks well-made and easy to install. I doubt I'll be able to enter the Orbital Machine Works YouTube video installation contest by the end of March however. The camper is buried again in 10 inches of new snow and it will be cold for a while yet!
montedtrotter1
I will check this out on Saturday (the fan blade on my ac unit) but according to the test work Orbital Machine Works has produced, the total noise reduction is near 30%! This could be a very helpful mod for me!
Monte, I won't attempt to explain the decibel scale, because I don't fully understand it and I would only confuse myself. However, it is a log scale, not linear. Every 3db increase represents a doubling of the intensity and for most people, about a 10db increase represents sound that appears to be twice as loud. If the noise reduction tests from the hush kit are accurate and the intensity decreased almost 16dba, the AC will be lot quieter. I know that if it's really only 53dba (at 15') when installed, it will be worth it for me.
montedtrotter1
OMGosh! I just went to the internet to look up the definition of decibel; way, way, over my head. I will just go with the information that 53 decibels is quieter than 69 and agree with you Merlin, plenty good for me.
