9.2 BTU Low profile AC
Started by hdrehder, September 16, 2014, 11:22:51 PM
montedtrotter1
Ordered my hush kit today, had to get the full kit as I have the three blade fan blade that is quieter but evidently cracks or breaks after as short time?? I got a confirmation of the order and then another email saying they had shipped it today as well. According to much of what Orbital Machine has been reporting about their fix for the Mach 8 low profile AC unit, the key to the kit is the fan speed controller. We will see hopefully late next week.
montedtrotter1
OK got my Hush Kit from Orbital Machine installed this morning, Amazing results! I ordered the full kit since the fan blade I had was one that had a B in the part number which is said to crack.
No pictures and no movies as I concentrated on not falling off the trailer during install! Not really a problem but did not want to make it difficult.
Summary of install and results:
1. Took about two hours as I was being very deliberate and taking my time.
2. Decibels measured from about 15 feet using my iphone app, pre-hush kit install 67 db for both high and low noise with AC on.
3. After hush kit, 57 DB on high and 55 on low, again a phone app but all I had.
4. So basically a 10 DB reduction but this is a major reduction in noise.
5. I already had the 3 blade fan (versus six blade) and not sure how big a reduction of noise I would get, very surprised and pleased!
Bottom line, worth every penny due to peace of mind that I am not creating a lot of racket for  tent campers.
Now Orbital Machine needs to work on the inside fan noise as this is still extremely  loud. I measured 66 DB on low and 76 on high! The hush kit does nothing to help the interior fan noise.
widgetwizard
[quote timestamp="1457559414" source="/post/19364/thread" author="@montedtrotter1"]OK got my Hush Kit from Orbital Machine installed this morning, Amazing results! I ordered the full kit since the fan blade I had was one that had a B in the part number which is said to crack.
Glad you like it.
[attachment id="1240" thumbnail="1"]
Jim
montedtrotter1
Jim, let me know when you get something for the inside fan noise, I will be the first to place an order for the inside hush kit! You guys do very good work!
swbc150
I went ahead and placed my order for the full kit.
While in AZ and parked under that Canopy my A/C unit sounded like a jet engine when running it was that loud, both Low and High speeds.
I have a EXTECH Sound Level DB Meter, even though I am not parked under the canopy now or in AZ, I will get a reading of the DB as stock then after the Kit is installed.
This won't happen till mid-April so I'll report back when I can.
widgetwizard
We would be interested in those noise measurement too.  Please update when you can.
  Meanwhile for your viewing pleasure we put together an [a href="https://youtu.be/jpZmD48qXpI"]install video[/a] - makes it look easy at ground level.
(and yes we have black grilles now to match the black shrouds...)
[quote timestamp="1459422355" author="@widgetwizard" source="/post/20070/thread"]We would be interested in those noise measurement too.  Please update when you can.
(and yes we have black grilles now to match the black shrouds...)[/quote]Thanks for the video. It's going to be cold and snowy again this weekend, so it will be middle April before I do the kit install. The video helps a lot.
swbc150
I watched the Video before I placed my order,looks very easy to install, thanks for providing the Video. I'll be sure to do inside DB Readings as well.
swbc150
Fast Service, Mine was shipped out Today..
widgetwizard
[quote source="/post/20068/thread" author="@swbc150" timestamp="1459413535"]I went ahead and placed my order for the full kit.
This won't happen till mid-April so I'll report back when I can.[/quote]
Did you ever get the kit installed? - Did it help?
Jim
swbc150
[quote source="/post/20877/thread" author="@widgetwizard" timestamp="1461928706"][quote source="/post/20068/thread" author="@swbc150" timestamp="1459413535"]I went ahead and placed my order for the full kit.
This won't happen till mid-April so I'll report back when I can.[/quote]Did you ever get the kit installed? - Did it help?
Jim[/quote][p]No I did Not. I want to be able to check the noise level with using 30 amp power, my friend did not have the 30A as he thought he did and presently I don't have it here at my home, yet.[/p][p]As soon as I get wired here for 30amp (Next 30 days if not sooner) I'll then use my DB Sound meter, then install the kit.
I just installed the quiet kit (finally) in our 9.2 Coleman Mach. What a wonderful difference! Outside the noise level is perfectly fine; just what I would expect (and hope for) if I were a camper next to us.
Inside, I've managed to quiet the air flow noise significantly with careful use of Dynamat, Fatmat, and better filters on the intakes.
However, I still get a crazy loud oscillating booming sound inside when the unit is on high cool. It's especially bad in the forward curve area. I have to find a way to kill that resonance because we can't live with as it is. I can feel the compressor vibration in the ceiling and I think the entire roof is acting like a big bass drum. I suspect a faulty installation, with perhaps missing cushioning, or rubber washers, or etc. I'll see what I can do with dampening it down, but in the end if it isn't fixable we'll be shopping for a better quality unit.
Meanwhile, kudos to Orbital Machine Works for a great exterior quiet kit that was easy to install.
widgetwizard
We keep getting reports of broken "B" or "C" fan blades.
They break at the most inconvenient time and often inflict some collateral damage.
If you have a Mach 8 A/C please check the part number on the fan blade.
It needs to be  a "D"
Even if you dont buy a hush kit from us you must change the blade.
Part number needs to be 1472D5041
Thanks,
Jim
montedtrotter1
Does anyone know of a way to slow the interior AC fan down as this seems to be where the very loud interior noise is coming, cannot really use it on high due to the noise!
Jim, I hope you guys are working on that.
Merlin, is the AC interior noise from the air flow into the AC or the fan? You mentioned better filters but does  this restrict airflow?
Again we use the interior fan to create some ambient noise to cut down on outside sound, trucks  going by etc. however nothing helps when the guy with the Harley Davidson decides to let everyone know how cool his motorcycle sounds at 6AM!
widgetwizard
[quote timestamp="1465986577" source="/post/22165/thread" author="@montedtrotter1"]Does anyone know of a way to slow the interior AC fan down as this seems to be where the very loud interior noise is coming, cannot really use it on high due to the noise!
Jim, I hope you guys are working on that......
[/quote]No - we are done for now.
If a big enough chorus rises we may revisit. - But there are a lot of tests to perform to make sure its all still working.
Its a larger undertaking than most folks imagine.
Cheers,
Jim
