9.2 BTU Low profile AC
Started by hdrehder, September 16, 2014, 11:22:51 PM
[quote timestamp="1465986577" author="@montedtrotter1" source="/post/22165/thread"]Does anyone know of a way to slow the interior AC fan down as this seems to be where the very loud interior noise is coming, cannot really use it on high due to the noise!
Jim, I hope you guys are working on that.
Merlin, is the AC interior noise from the air flow into the AC or the fan? You mentioned better filters but does  this restrict airflow?
Again we use the interior fan to create some ambient noise to cut down on outside sound, trucks  going by etc. however nothing helps when the guy with the Harley Davidson decides to let everyone know how cool his motorcycle sounds at 6AM! [/quote]I can live with the inside fan noise as I currently have it set up. The better filters do restrict air flow I'm sure, but not enough to make a difference in cooling. The original air "filters" didn't do much except keep out large items and the new filters reduce the noise level from the air movement. I also added Fatmat and Dynamat in strategic locations in the inside air plenum to reduce vibration, resonance, echoes, and air noise in from the fan. It helps too to make sure the plastic flap that seals the outflow from the inflow to the fan is actually sealed. Mine was flopping around and not even fastened on one side.
My remaining problem, as I noted above, is the resonance and vibration from the operation of the compressor. I've decided to remove the AC unit and remount it with new gaskets and seals using the factory installation manual. I've ordered the parts to do that and will report back on whether I get the compressor noise solved or just end up with a 14X14 hole duct-taped closed in my roof.
mrt
[font face="comic sans ms" size="3"]Hi Jim,
I am interested in this product and am about to climb on top to see what fan I have.
I noticed people have mentioned that it does not reduce the interior noise and if this is the case you have my vote to add support for the development of same.  However, it is my understanding that your fix for the outside noise involves a reduction of the fan speed when on low cool (and low heat for those who have installed the resistive heater supplied by airxcel).  Would I be correct that this implies a lower db inside the trailer?  Its too bad there isn't a variable speed control for the fan but I guess there is more to the electronics than this simple solution.
Cheers
Mike
Quote from: @mrt" timestamp="1467077286" source="/post/22614/thread[font size="3" face="comic sans ms"]Hi Jim,
Cheers
Mike
The quiet kit affects only the outside fan, not the inside fan. There is no reduction in speed when using the resistance heating element because that uses only the inside fan. For both cooling and heating, there is no noticeable reduction in inside noise.
Do do you have the 9.2K unit in your 21?
mrt
[font face="comic sans ms" size="3"]Ahhh,thanks for the info. Yes, I have a 9.2....just not sure which fan blade is inside.  So, maybe a variable speed control would work to reduce the inside noise???
widgetwizard
[quote source="/post/22639/thread" timestamp="1467153592" author="@mrt"][font size="3" face="comic sans ms"]Ahhh,thanks for the info. Yes, I have a 9.2....just not sure which fan blade is inside.  So, maybe a variable speed control would work to reduce the inside noise???
[/font][/quote]I'm sure it would - we just dont have the time to do all the testing to make sure it still meets spec and to make a commercial kit for that.
Go for it!
Jim
I just replaced the foam roof seal on my 9.2K Coleman Mach and it made no difference in the booming resonance inside when the compressor is running on high cool. Bummer. Big job and I don't recommend anyone else tackle it alone. We'll live with it the rest of this year, but I'm going to begin the search for a quiet, efficient roof top AC unit. I suspect those features won't be compatible with inexpensive, or maybe even at all, but it's worth looking around for a better unit.
