Additional pics of our new CampLite 21BHS
Started by gbpack, December 02, 2015, 07:59:37 PM
Here are some additional pictures of our new CampLite 21BHS, including many of the interior. Some you will have to turn sideways after opening them up. As you might be able to tell, we opted for the off-road package which gave us 15" wheels, BF Goodrich tires, and heavier axles.  We have been busy showing it off to neighbors, cleaning it, and figuring out what we want to put in it (and where!). As for the changes with these new models, they are mostly cosmetic on the interior. No changes to the structure and no changes to most of the materials used. All the models now come standard with some features that used to be upgrades, such as solid surface countertops, upgraded sink & faucet, heavy duty coupler (rated for 7,000 lbs), and a water heater that is both propane & electric. The outdoor shower and blackout package and porcelain toilet now come standard as well. As most of you are aware, they don't offer the aluminum cabinet faces any longer, so that is a change as well. We went with the Sierra interior package which is solid maple cabinet faces and it looks nice along with the different Azdel color and design that they have on the interior walls. The body of the cabinets is still aluminum frame. They have also added some valances over the windows which look nice. The window units are still the same and we love them. There are fewer options that you can choose from now and they won't let anyone custom design their interior anymore like some of you did. That is probably the biggest change they've implemented since Thor took over. Other than the cosmetic interior changes, the camper is still pretty much the same tried and true CampLite trailer that all of you know and love. Please let us know if you have any questions!  Gregg & Joan
[attachment id="985" thumbnail="1"][attachment id="986" thumbnail="1"][attachment id="987" thumbnail="1"][attachment id="989" thumbnail="1"]
I have tire envy.
That kitchen really looks great and is a significant upgrade in several things to the one in my '15. Very nice.
thedusty
This is great!  Thank you..
The black, metal storage box at the front...I assume that is standard?  It looks big enough to hold several batteries from the picture.  I could be wrong.
Also, I'm curious for your input and/or others.  We will order the 21BHS too but in silver.  I saw some pictures online of the silver with the silver aluminum trim vs. the blackout color.  Is there any advantage to the blackout metal other than cosmetic?  I liked the silver on silver look I've seen in pics online.  My dealer said he would check into having them do it without the blackout but I wanted to make sure I'm not giving up some added benefit I don't know about.
Thanks again...  The Sierra interior package actually ended up surprising me and it looks solid in person.
Hope you enjoy it.
Dusty - The black battery box was an add-on at the dealer. We got a large one to hold the 2 six-volt batteries and then there is enough room left over to store some of the gear and equipment that we'll need while camping, although our dealer told us not to put tools in there because they would be damaged from the battery acid fumes. We can put things like wheel chocks and wooden blocks in there, etc. It was an expensive box, but I think we'll like it.
thedusty
I'm ignorant as to what the 'coupler' is on a trailer.  You mentioned it was upgraded to a heavy duty coupler.  I think I recall some posts about a portion of the frame being bent when hooking up...is this improvement meant to fix that or am I thinking of the complete wrong thing.  Thank you again...
The coupler is the most forward thing on the front of the trailer that connects the trailer to the ball hitch on the tow vehicle.  It has a latch on it that secures the trailer to the ball once the trailer is placed on the ball hitch. In the past, the 21 foot CampLite trailers came with a lesser coupler (I think those only were rated for 5,000 lbs.) and some people had problems with them bending from the weight of the trailer or perhaps from having their weight distribution hitches cranked down too much. Now Livin Lite is putting beefier couplers on the 21 foot trailers, ones that are rated for 7,000 lbs., which should take care of any problems.
[quote source="/post/16928/thread" timestamp="1449104358" author="@gbpack"]The coupler is the most forward thing on the front of the trailer that connects the trailer to the ball hitch on the tow vehicle.  It has a latch on it that secures the trailer to the ball once the trailer is placed on the ball hitch. In the past, the 21 foot CampLite trailers came with a lesser coupler (I think those only were rated for 5,000 lbs.) and some people had problems with them bending from the weight of the trailer or perhaps from having their weight distribution hitches cranked down too much. Now Livin Lite is putting beefier couplers on the 21 foot trailers, ones that are rated for 7,000 lbs., which should take care of any problems.[/quote][font size="3"]gbpack,
Can you post a picture of the coupler and the manner of attachment? The original coupler tended to bend, especially when WDH was used. The #5000 rating was indeed marginal for a #7000 GVW rated trailer, but the fundamental problem was the lack of side bolts. Scan the Bent Coupler on 21RBS and New Coupler and WDH threads if you're interested. Several of us have replaced the OEM coupler with a beefier version and added side bolts. The #7000 version is a step in the right direction, but still should have the side bolts added if they're not supplied. A picture showing the side of the coupler would be interesting.[/font]
The kitchen is very nice, with almost all of it being an upgrade. The counter looks great; the stainless steel sink has faucets that are easy to clean; the backsplash is beautiful; and it appears that you have an exhaust van venting over the cooktop. The tile floor looks good as well. Put this together with the wood cabinets, it is a very residential look.
Thanks for posting the pictures. I think you will be able to enjoy many miles with your new camper. See you at a campground!
Great pictures. I now have countertop envy! :)
christianm
Whooo hooo!!! This is awesome to see! Thanks for sharing :-)
CharlieM: attached are pics of our coupler. As you will see, there are 4 bolts from top to bottom but no bolts in the the sides. I took a look to see how bolts thru the side would work, but I can't figure anything out. For one thing, there isn't much of a side to work with (it's tapered). Second, even when I finally found a spot to drill a hole of a side bolt, there isn't any room on the backside to attach the nut to the bolt (the frame members come together closely up there in the front and there really isn't any room back there to get a nut on the bolt, nor would there be room to put a wrench on the nut). Lastly, even if we could figure out a way to get a nut on the bolt, the frame beams are not open (totally enclosed) so there wouldn't be any way to get washers inside the frame beam so that we wouldn't collapse the frame when tightening the bolts. It seems pretty secure and safe right now the way it is, but if you or anyone else can help me figure out a way to install side bolts, I would consider doing that. Thanks![attachment id="998" thumbnail="1"][attachment id="999" thumbnail="1"]
I would suggest adding the bolts as shown in the red oval here:
[attachment id="1000" thumbnail="1"]   [attachment id="1001" thumbnail="1"]
I'm not sure what you mean by the the frame members being totally enclosed. The ends of the tubes on mine are open so the nuts actually go inside the rectangular frame tubes.Washers are used to fill any space between the coupler and the frame, but not inside the tubing because the bolts do not go all the way through the tubes. Can you do this?
I see what you're doing. You're suggesting that they be placed further in front of where I was looking. I was was looking further back which would have presented problems with both
the nuts and the frame members (which are fully closed back there and not accessible to put nuts inside in order to prevent collapse if drilling all the way through). I'll take a look and see if I can make that work. Will let you know. Thanks!
[font size="3"]gbpack,[/font][font size="3"]
As you can see from these original pictures, the failure point is just forward of the front vertical bolts. The added side bolts should be as far forward as practical before you run out of tubing. About 2/3 to 3/4 of the way down vertically is appropriate. The portion of tubing forward of the front bolts adds no structural strength so there's no problem drilling through it. It would be better to drill all the way through the frame and use a longer high strenth bolt, but that's not possible and would require protecting against compression. [/font]
[attachment id="1002" thumbnail="1"]  [attachment id="1003" thumbnail="1"]
[p]christianm:
LL needs to take a hard look at the last few posts. Relying on just the top bolts to take the heavy stress on that coupling is crazy. If they were building a steel frame trailer, would they just weld the coupler at top of the frame? Of course not. So accomplish the same thing on the aluminum frame CL by bolting through low and horizontal where Charlie indicates.[/p][p]
[/p][p]I would much prefer that LL build it right in the factory than some of us fixing it but leaving many others at risk.
David[/p]
