Additional pics of our new CampLite 21BHS
Started by gbpack, December 02, 2015, 07:59:37 PM
aggie79
It's been a long time since I took a structures class - almost 40 years ago - but I believe the reason for not bolting in the side of the tongue is to keep from inducing a stress point for a shear fracture. When a beam flexes - in this case the tongue - the upper portion of the beam is in compression and the bottom portion is in tension.  At the horizontal line where the compression transitions to tension, beam shear can take place. A drilled hole in this location could accelerate the shear.
This can be addressed by adding additional beam thickness at the bolt location.
What is also curious to me is that it appears that CL is using a tongue angle other than 50 degrees which is standard for an a-frame tongue and coupler. Hence there is a need to add washer "shims" to the added bolt locations.  This may be my misunderstanding of the method used to upgrade the coupler.
[quote source="/post/16968/thread" timestamp="1449330219" author="@aggie79"]It's been a long time since I took a structures class - almost 40 years ago - but I believe the reason for not bolting in the side of the tongue is to keep from inducing a stress point for a shear fracture. When a beam flexes - in this case the tongue - the upper portion of the beam is in compression and the bottom portion is in tension.  At the horizontal line where the compression transitions to tension, beam shear can take place. A drilled hole in this location could accelerate the shear.
What is also curious to me is that it appears that CL is using a tongue angle other than 50 degrees which is standard for an a-frame tongue and coupler. Hence there is a need to add washer "shims" to the added bolt locations.  This may be my misunderstanding of the method used to upgrade the coupler.  [/quote][font size="3"]Admittedly structural engineering is not my strong suit, but there many good references available. Sheer stress does exist at the center of a beam, but it is minimal compared to the compression and tension stresses if the length dimension of the beam is large compared to the cross sectional dimensions. Generally, drilling a small hole in the center does not materially degrade the beam's strength. And in this case there is very little loading on the frame members forward of the front coupler attachment bolts and that is where the added bolt is placed. I haven't measured the tongue angle, but the side gap I encountered was primarily due to the placement of the existing jack hole. Others, using different replacement couplers, experienced less gap. See TinkeringTechie's posts.
For reference:
[a href="http://fp.optics.arizona.edu/optomech/references/OPTI_222/OPTI_222_W10.pdf"]http://fp.optics.arizona.edu/optomech/references/OPTI_222/OPTI_222_W10.pdf[/a]
[a href="http://www.assakkaf.com/Courses/ENES220/Lectures/Lecture14.pdf"]http://www.assakkaf.com/Courses/ENES220/Lectures/Lecture14.pdf[/a]
Well, first of all there is no stress on that front frame member as originally installed. In fact look at the weld in gbpack's second picture, it stops a few inches before the end of the aluminum frame member. Sure a bolt in the front of that member will carry stress, but put a few washers to compress the frame and the coupler together as Charlie has done and that stress is well distributed. And think about it, if the hole puts stress on the frame at that point, where is that stress being contained in the OEM installation? No where, and the coupler bends. That coupler was never designed to be installed with just bolts on the top as LL does it.
[attachment id="1038" thumbnail="1"]
Hi guys. Took your advice and had a bolt put in on each side of the coupler. Love it. Also had MaxAir2 vent covers installed over each power vent. Also, had the dealer seal the wheel wells under the floor to prevent road spray from coming up into the trailer (like it did on the way home from dealer after we first picked it up). That was covered under warranty. We are all set for camping now!
I really appreciate the posts that LL owners have posted here about their experiences. It helped me when I was ordering and taking delivery, and now the posts have also helped gbpack. So I would like to say a big thank you to everybody here who has shared their mods and how they have set up their campers.
Quote from: @gbpack" timestamp="1449710630" source="/post/17049/thread
[font size="3"]NOW you're set to go. Camp on![/font]
Yes, thanks to everybody for helping us get going with our trailer! All of your posts on this board (past & present), and all of your helpful advice have been invaluable to us! We really enjoy reading the posts and getting to know all of you in this way. It's like one big family and Joan & I are happy and privileged to be a part of it. And thanks Leslie for pointing that out to me, as I failed to thank everyone for their help.
Gregg
sarz272000
An interior mod I would prefer is to add a second shirt cabinet in the bed area. Having only one cabinet makes it look unbalanced. If LL refuses interior mods that would only be a pipe dream.
