Awning rub when closed
Started by gnies, September 01, 2014, 12:02:12 PM
Hi I just got my new 2015 13qbb and there is a sligth rub with the awning when I close the door (the awning is closed) should I be working? Does not look like it damage it
[font size="3"]Strange you should ask. This is fixable. Sometimes, when the awning is fully retracted, the door may rub on it. This can be cured by leaving the vertical supports slightly extended before rolling up the awning. Usually one or two holes from the bottom end is sufficient. There are small pins on each support to set the closed position. They can be moved to adjust the height of the retracted awning and eliminate the door rub.[/font]
[quote source="/post/3144/thread" timestamp="1409584810" author="@charliem"][font size="3"]Strange you should ask. This is fixable. Sometimes, when the awning is fully retracted, the door may rub on it. This can be cured by leaving the vertical supports slightly extended before rolling up the awning. Usually one or two holes from the bottom end is sufficient. There are small pins on each support to set the closed position. They can be moved to adjust the height of the retracted awning and eliminate the door rub.[/font][/quote]
Thank you! I ajusted the pin like you sugested I moved it one hole higher and it fixed the problem! Thanks
