Small generator recommendation for generator for 14dbs
Started by ron, August 24, 2014, 11:55:34 PM
ron
We have single battery, and in 24 hours went to a low of 12.49 volts.  Only used hot water, water pump and other electronics like refrigerator electronics.  Nothing else, not even lights as I used my wide assortment of flashlights and lanterns.
can some one recommend a small generator that would simply keep our battery properly charged for use with water pump and refrigerator and other automatic electronics as described.  No a/c, microwave, CD player, lights, etc.
thanks
I have a 13 QBB and my electrical usage is about the same as yours, my solution was a solar panel and charge controller.  There are a few threads on solar setups but in a nutshell I've got a 70 watt panel on the end of a 25 foot cord that goes to a charge controller and then hooks up to the battery. The length of cord allows me to move the panel into the sun but still park in the shade.  I have used this set up for extended camping trips (2 weeks) and it has kept my battery at full charge.  Total cost is less than $300.  I don't own a generator but I have researched them a bit, I'd probably go with the Honda 2000 because it's the quietest I've seen and I hate generator noise.
ron:
Before you jump into a generator or solar panel, do some research on batteries.
First read Trojan's (one of the premier deep cycle battery manufacturers) excellent article here: http://www.trojanbattery.com/pdf/TRJN0109_UsersGuide.pdf.
Note the voltage vs state of charge chart on page 20. This indicates that your 12.49 volts indicates that the battery was about 75% full and maybe higher if you had some small load on the trailer that was pulling the voltage down. As stated elsewhere in the article, you can discharge lead acid batteries safely to 50% and not affect battery life.
So you can probably camp for two days or maybe three and not bother about recharging.
Then read my thread at http://livinlite.proboards.com/thread/416/batteries-generators-solar-panels.
If you do buy and use a generator, hook it up to the shore power cable so that the generator will power the on board converter. That will greatly speed up charging over using the generator's 12V output. Even with the converter powered from the generator I am not sure that you will get that much charging if the battery is already at 75% full. Let it go to 50% which according to the Trojan chart is 12.1 volts before charging. Charge for about an hour and you will probably be up to 80% or so and stop there.
Note that the Trojan article says that you need a charging voltage above 14.0 as the batteries get full. If you were to simply hook up a generator's 12V output to your batteries, starting with a resting voltage of 12.49, you would get hardly any charging. You would just be making noise.
If you do buy a generator consider the Honda EU1000i. It is big enough to power your converter and is light, quiet and reliable. If you need enough power to run the A/C then consider the Honda EU2000i. The Yamaha equivalents also have a good reputation.
There are a ton of factors that go into choosing a generator. First and maybe most importantly is going to be a clear idea of what your needs are going to be. Things like how much power do you need and how often. Some other factors are cost, noise, size/weight, peak watts vs running watts vs amps, and fuel.
In my experience the Honda and Yamaha brands are going to be hard to beat for their quality and noise levels. However you are going to pay a premium for those models with a Honda EU2000 (2000 watts) going for about $1000. On the flip side there are cheap china imports sold by Harbor Freight that claim to put out about 1000 watts for about $150.
Some factors and my opinions
1. Cost - I personally know I dont have a grand to drop on a Honda so I'll be looking at other brands. It is also important to note that you will be paying higher prices for a "digital" or "inverter" generator. These have many advantages over a traditional generator, but again this equates to higher cost. I've found that for an average of 2000 watts you can expect to pay about $500 for a digital/inverter generator. Far less for a traditional generator.
2. Watts and Amps - Be on the look out for peak watts vs running watts. Many generators list at their peak, when the running watts can be drastically reduced. It would be a nasty surprise thinking you have 1000 watts at your disposal only to find out you actually have 800. Running watts is what the generator can maintain, where the peak is only available for a few seconds. Usually this is a factor if you will the spike in watts from an electrical device turning on. I have found a 2000 watt unit is very capable of dealing with all the needs of a regular camp including AC if you so desire. Beware of the Amps the generator puts out as well. Its easy to assume with higher watts comes higher Amps, but I've seen some generators limit the amp output per circuit. This is not often an issue but just keep it in mind.
3. Fuel - Most generators are going to use unleaded gas, but some of the cheap china imports actually run a 2 stroke engine and thus require gas/oil mix. I would stay away from the gas/oil mix just for simplicity when out. Some other generators are run off propane, and others still are diesel. Propane and diesel are less common and again higher price, but if everything you have runs on propane and you dont want to mess with gas it might be a good option. For my money I'm sticking with regular gas.
4. Size - for my needs I dont want the generator to be huge. This almost instantly rules out a traditional generator as they are usually rather large and heavy. The digital/inverter models however are generally very compact and manageable as far as weight goes. Many can be had for between 50 - 75 pounds.
5. Noise - traditional generators are known for being noisy. This is because they require larger engines and only have a single speed. They are designed to run at a certain RPM to maintain their power output. Digital/Inverter generators are different, they can run at multiple RPMs since the electricity is digitally controlled. They also require smaller engines to produce that power, thus the digital models are very quiet.
This list could go on for a long time and I could probably write pages on each factor given enough time. In short my money will be going towards a 2000 running watt digital inverter generator.
I personally like this model from northern tool: http://www.northerntool.com/shop/tools/product_200482992_200482992
 -an interesting feature is that it has a remote starter.
Another (cheaper option) http://www.wayfair.com/Powerhouse-2000-Watt-Gas-Inverter-Generator-60376-L6342-K~PWH1004.html?refid=GX50899353540-PWH1004&device=c&ptid=75696049020&pptid=75696049020&ci_src=17588969&ci_sku=PWH1004&gclid=COyFkYvPrsACFSpo7Aodqx0ASg
I started to ramble so I hope at least some of that information is helpful for you.
ron
Just a quick initial look, and thanks for the great info.  I will read this from my laptop this evening and copy all the info and the battery manual to my camping notebook.   Thank you all for your time and knowledge.
R
sidecarmike
[p]Generacs are good and a lot cheaper than Hondas.  I must confess, though, that I'm still using a 1974 Honda 400 watt that I bought used before my son was born.  [/p][p]
[/p][p]He's 32.  [/p][p]
[/p][p][a href="http://s2.photobucket.com/user/SidecarMike/media/Camping/20140422_2251241_zps2b18e9b7.jpg.html"]
[p]Old thread (not as old as that Honda though) but consider doing a Gasoline/LP/LNG tri-fuel conversion on the Honda inverter generators. I did this a few years ago to supplement our off-grid system and it works real well coupled to the LP tanks after the tank reg. Benefits beside the versatility of fuel include the exhaust smell and keeping the tiny little carb jet on those gennys clean and gunk free while on LP/LNG. With no fuel in the bowl to get stale.[/p][p]
[/p][p]The OP used very little power though so I agree a generator may be overkill.
I have 2 Honda generators I'd like to be able to run on LP (EU1000i and EM5000SX). Any recommendations on tri-fuel conversion kits?
[p]I went with this one from Central Maine Diesel. I had a brand new core at that time though too so I had them do the drilling of the carb. There are several kits out there and some of them are cheaper. Since it came from a respected diesel shop I felt confident going with this one.  [a href="http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit"]http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit[/a][/p][p]
[/p][p]They have them for the 1000W. I don't see one for the 5000W but I'd call and ask. My Dad had a 1973 Cadillac Fleetwood converted to LP in the eighties so I believe any gasser can be done single fuel style, some with more coaxing than others.[/p]
sidecarmike
Quote from: @whoofit" source="/post/8689/thread" timestamp="1427806935[p]I went with this one from Central Maine Diesel. I had a brand new core at that time though too so I had them do the drilling of the carb. There are several kits out there and some of them are cheaper. Since it came from a respected diesel shop I felt confident going with this one.  [a href="http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit"]http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit[/a][/p][p]
[p]Wow.  My daughter works for Generac. [/p][p]She let slip that I have a new IX series coming in June.  :)[/p][p]
[/p][p] I spoke to her recently about propane, but they only offer it in a larger unit than I want.  I've sent them a note to see if they make a kit for them.
[p]I have no experience with the new IX Generacs. Only the old contractor ones some twenty something years ago. My how the world has changed since then.
US Carburation seems to offer a LP/LNG only kit for Generacs. Again, no experience with them. [a href="http://www.propane-generators.com/generac-generators.php"]http://www.propane-generators.com/generac-generators.php[/a][/p][p]
[/p][p]Propane conversion is a natural fit for RVers in my opinion. But good old petrol works just fine too. I like having the option for both on the Honda but once you go LP you don't miss that stabilizer/drain routine much.[/p]
I don't use a generator for RVing, but we lost power recently and I lit up my 20 year old, second hand no-name generator. Went off to the mailbox and notice sparks - SPARKS !!! coming off the generator head. Not out the muffler or the gas engine side, buy the thing with all the wire wound about it that spins around and makes electricity.
So I went to the Costco and got a dual-fuel propane/gasoline beast with far more power than I need. I have only run it on propane so far, and that's all I ever intend to do, barring a zombie apocolypse.
billmoore
We picked up this Champion 2800W/3100W generator from Costco while it was $100 off (so $699).
http://www.costco.com/Champion-2%2c800W-Running--3%2c100W-Peak-Digital-Inverter-Gas-Generator-%28CARB-50-State-compliant%29.product.100139466.html
Figured it was hard to go wrong with Costco's excellent return policy.
This generator puts out almost as much power as two Honda EU2000i's in parallel, and while it is a bit louder than one Honda, it is significantly quieter than two of them.
We are able to run either the AC or the microwave (but not both at the same time), and it does a great job of keeping the battery charged. On our last camping trip, we boondocked for 4 days/3 nights, and we went through one tank of gas in the generator (1.5 gallons), which was about 8 hours of run time. This kept the battery charged up, and allowed us to use the microwave while it was running. This trip was very rainy and cold, requiring the furnace to run a lot, so the battery would have only been good for one night without a way to recharge.
This is basically the same generator as the Champion 3100W available from other retailers (its on Amazon for $850), the only difference is that the Costco version is black instead of yellow, has flip up covers over the outlets, and the model number uses the running wattage rather than the peak wattage.
Our emergency house generator is a Honda eu3000i. It's a little more than we really needed for our 21RBS (eu2000i would suffice), but rather than spend money for something different, we're gonna be taking it with us when we travel. The up side is, it powers everything running at the same time and reverts back to ECO mode when the load drops. Super quiet and fuel efficient.
Living in hurricane territory, we've owned several cheap generators over the past 3 decades. When my last one died in 2010, I decided to buy the Honda. I wish I had bought it first. Other than the Yamaha, I'm hesitant to recommend anything else.
sidecarmike
[quote source="/post/8693/thread" timestamp="1427814457" author="@sidecarmike"][quote source="/post/8689/thread" timestamp="1427806935" author="@whoofit"][p]I went with this one from Central Maine Diesel. I had a brand new core at that time though too so I had them do the drilling of the carb. There are several kits out there and some of them are cheaper. Since it came from a respected diesel shop I felt confident going with this one.  [a href="http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit"]http://www.generatorsales.com/order/Honda-EU2000i-Tri-Fuel-Kit.asp?page=Honda_EU2000i_Tri_Fuel_Kit[/a][/p][p]
[/p][p]They have them for the 1000W. I don't see one for the 5000W but I'd call and ask. My Dad had a 1973 Cadillac Fleetwood converted to LP in the eighties so I believe any gasser can be done single fuel style, some with more coaxing than others.[/p][/quote][p]Wow.  My daughter works for Generac. [/p][p]She let slip that I have a new IX series coming in June.  :)[/p][p]
[/p][/quote][p]I received a response from the company.  They do not make a kit at this time, but will build one if I send them my carburetor and sell it for the same price as the Honda.[/p][p]I'm not sure if it's worth $200 to do this.  It would be nice to not carry a couple quarts of gasoline, but that's a lot of money for convenience.
