Coleman QS10 AC Question
Started by lora, July 16, 2014, 02:09:47 PM
lora
I'm seeing a lot of the Coleman QS10 in our area, but they all come with the AC.  Most of our trips are dry camping and we won't need the AC.  How easy is it to remove?  Does it come with a door to cover the hole or is this something I can order?
Thanks!
The older models were fitted with a slide out AC and a door. Thats what I have seen here:
[a href="https://flic.kr/p/nRfvp5"]
I'm not sure if they have one available to order from the factory, but I'm willing to guess LivinLite might be able to work something out with you. If not it shouldnt be that hard to fab something up. My door is just a solid frame with some of the outer skin material held on with a couple of hinges, two bar latches and some foam weather stripping.
vmcmn
Should be able to talk to the factory or have a special order put in thru a dealer.I believe that most of the units shipped to the northern US and Canada aren't equipped with A/C's.
Tim
Tallahassee,Fl.
2011 QS 8.1
or 1994 GMC Sierra 1500
