questions about possible buying a 2015 QS 8.0....
Started by abodyjoe, January 02, 2017, 05:05:53 PM
abodyjoe
  ok so i found a 2015 QS 8.0 at a dealer not all that far from me.    i looked at it today and have a few questions on what a good price for it would be...
its a basic 8.0 with a/c and an awning.,  i believe thats the only options it has...
it is raining out today so that was good..  there were no leaks.  the int looked decent.  needed some cleaning is all...
we noticed that there were a few snaps torn out of the canvass.   the table that clips on the outside was kinda busted up and missing the bottom support..  a couple of scuffs on the side under where the table would clip on and one dent in the rear panel above and centered between the tail lights.   not a huge dent ot anything that is structural.  just cosmetic.   other then that it seemed ok...
it also had two Fan / Light units..    look like they were made for it..
so the dealer says they will fix the snaps/canvass on the front and back of it and replace the outside table and support.
they will let it go for $6400 out the door (original price was 7400 and change out the door with nothing repaired)..  thats the trailer, the canvass fixed, the table replaced, set up fee (they go over the entire thing and make sure everything is working and things like that and demo it for me), tax,tags and doc fees..
  is this a decent price?    is there anything else i need to look for?
down the road if i needed new canvass what does it cost for new canvass and where would you buy it?
 do that make mattress covers for the stock mattresses?
i have two little Honda EU2000i 2000W Generators with a parallel kit that allows me to plug a 30amp rv style plug into it..  wikk they be enough to run the a/c?
  thansk in advance for the help...
[font size="3"]I cannot advise on the price but I can warn you that this forum will disappear in 1-2 days. Thor/Livinlite has withdrawn their corporate support. Most members of this forum are moving to [a href="http://aluminiumcamperforum.com/"]http://aluminiumcamperforum.com/[/a]. You should post your question there where many QS owners can help you.
The two Hondas should run the AC. I think it's a 5-9K BTU unit so one Honda might do it.
