Trying to get the most out of the TV alternator
Started by waejae, June 17, 2014, 12:33:05 PM
waejae
So if the TV has a 180 amp alternator how is the best way to get power to the trailer?  This seems like a pretty good sized alternator.
How much does/can the 7 way carry?  Would an additional wire and connecter like an "Anderson" be able to put more amps to the charger and there by charging the battery bank faster?
I saw this product called an "ArkPak" that has Anderson connections(nothing to do with the Anderson hitch).  I think sometimes we would park the trailer and go off and do thing during the day and if the vehicle is running anyway down the road the incremental fuel use would be very low.
I am particularly thinking about in some Yellowstone and other campgrounds where no generators are allowed and you do travel up and down the roads during the day.  Or if you are in full shade in the campground.
I think I remember that you can charge at 1/3 the capacity per hour.  I am not sure if this was for wet or AGM.  And I think that lithium can take a lot more per hour, maybe even the capacity of the battery in one hour.  Lithium are still expensive but if you can dump a lot of juice into the battery it might be easier than bringing a small generator.
Could you mount the ArkPak or similar set up in the TV and then just run a wire to the trailer's charger when you get back to camp.  Maybe not the most efficient but seems quick and easy.
The ArkPak seems like it could be very versatile.  If you put a lithium battery in there it would not be "too" heavy and could store a lot of energy while chargeing relatively quick.
Maybe there is another set up that would be better or easier or efficient but I do not have any experience with house batteries.  I like the idea of having options and alternatives instead of being stuck.  My parents both have CPAP machines and will use this trailer a lot so I am trying to plan ahead while not actually have ever sleept in a trailer myself.
https://www.arkportablepower.com/arkpak
In-Vehicle recharging:
There are two ways you can recharge your ArkPak in your vehicle:
(a) Simply by plugging it into the 12V socket in your vehicle, via the optional DC-DC car charger adaptor (sold separately) – giving you 6 amps of charge per driving hour.
(b) Via the ArkPak's built-in 50 amp Anderson Plug, giving you a potential 50amp charge per hour directly off your vehicle's alternator.
I believe the 7-way is rated for 35 amps, but my guess is that they put a 30amp fuse on there (check your specific vehicle). Voltage drop over the length of the load wire will reduce that rate pretty significantly though. The limitation won't be the connector, it will probably be the gauge of the wire used.
This is an interesting idea. You're basically storing charge while driving around away from the trailer and then adding it back later, right? I think the ArkPak is overkill unless you need the inverter. It would probably be cheaper and easier to just charge a second battery in the TV while you're driving and then swap it with the one on the trailer. I'll need to think about this one a bit more... I might do something similar myself.
I did something similar to this in my old Jeep when I was doing some car camping with minimal gear. I had a second battery wired into my regular electrical system. While I was driving around I could engage the circuit to top off the battery. Then while back at camp I could either run my 12v gear directly off the second battery, or 120v gear off a small inverter I had. I never took measurements (wish I had) but since I only needed to charge it while I was already running the Jeep I never noticed a spike in fuel consumption.
I think the ArkPak's main advantage is the fact that everything is already bundled. However its only an advantage if you need the power to be self contained. If you are simply needing to power your rig then there is no need for the extras.
I bet you could put something together with a tool box and a couple of sealed batteries that better fits your needs. If you are using the $400 price point of the ArkPak I would think you could put it together for half the cost. I bet a couple of golf cart batteries wired up inside the box with a couple of quick connect fittings and you'd be good to go. The gauge of the wire would still be a factor though.
[font size="3"][font face="arial"]I would agree the ArkPak is too much fluff for camping folks. If you're going to haul a battery with you just carry the battery. Hook it up in parallel with the TV battery through a relay (solenoid) activated from the ignition switch. Then when back at the campsite move the battery to the camper or hook it up with jumper cables.  If you go with a pair of GC2 golfers you'll never be without juice. Get a small inverter if you really need low power 120VAC. 100-200 watt inverters are cheap.
One note on wire size. The wire size from the TV battery to the aux battery makes a HUGE difference in the charging current. The TV's electrical system will limit the voltage to 13.2-14+ depending on the charge of the TV battery and the age of the TV. My 2013 Tacoma with a 130 Amp alternator puts 13.2 volts on the battery a few minutes after starting. This is all in an effort to squeeze another 0.001 mpg for EPA. Dropping this by 0.5-1 volts through wire to the aux battery reduces the charge to a trickle. That's why the usual #10 wire to the Bergman becomes nothing more than a maintainer. I measure more than a 10 Amp difference going from cheap #8 gauge jumpers to better #6 gauge cables, both 12 feet long. So, when hooking up the battery in parallel with the TV battery I recommend #6 gauge minimum. Four gauge is better and 2 gauge isn't overkill. The connection to the railer isn't as important because the loads are not as demanding unless you have a big inverter on board.
waejae
Yes, storing a charge.  Pretty much charging the trailer battery with the battery in the back of the TV.  Could you just run them in parallel while the vehicle is there?   I was thinking more like a fuel can that you could dump when ever the car gets back to camp.  I would want to not completely drain the battery in the back of the TV [font size="2"]but transfer a good bit of charge from the TV battery to [/font]the[font size="2"] trailer so when we drove we could fill the battery back up.   Like having a battery powered battery charger that stayed in the TV.  I would not think this would be the most effective way but hooking up a wire and hitting a switch would be quick and easy.  Swapping the whole battery be simple but a pain in the but for my parents.  A good sized battery is easy 60 lbs.  I was thinking more like plugs or connectors.
Also if you ran a heavy wire separate from the 7 way and into a larger battery charger say 50 or 60 amp, would the alternator tell the engine to increase rpm while in neutral at idle?  Then at least when you were trailering you could top off rather quickly.
waejae
Thanks Charlie,  So labor is the same time for the most part so use the #2 with the appropriate connection between the TV and TT.  Would the wires go right from one battery to the other? Or to the battery charger on the TT?  If you have 2 batteries on the TT would that be too much drain?
[font size="3"][font face="arial"]The best connection is direct battery to battery with as big and short a cable as you can work with, both to the TV battery and the TT battery. If using jumper cables the labor is the same so go with #2. If permanently installing in a vehicle it gets harder because big wire is harder to work with. Either way you must disconnect the aux battery from the TV while you are camping to avoid running down the TV starting battery overnight. Bad experience next morning if the TV won't start![/font][/font]
No problem with multiple batteries as long as you connect to corresponding 12 volt points. [/font][/font][font size="3"][font face="arial"]
Of course the best set up would be two GC2 golfers installed under the hood with a relay and big wire. Then a quick disconnect connector mounted in the grill with #6 or #8 for connecting to the TT battery. But that requires room under the hood - - - a thing of the past on newer vehicles  :'(
One caution: If you do provide a semi-permanent connection to allow charging the aux battery while driving be sure to provide a fuse inline very close to the TV battery. About 50 Amps should be good. An accidental short with big wire across a car battery can cause lots of fire.
Side note, its not going to be an immediate transfer of energy. If you are expecting to charge a battery while driving then dump it to the TT its not going to happen the way it seems like you are expecting. I think of it like two barrels of water sitting next to each other, where one is full and the other is nearly empty. When connected the full barrel will eventually fill the nearly empty barrel until they are at an equal level.
I think with the links you posted are basically what I was thinking. When its all said and done you would have a portable power source that can be used in a variety of situations. Add a small inverter to the side with some Velcro and you could even use it independently for lighting or a radio when an extension cord isn't an option.
[quote source="/post/1565/thread" timestamp="1403061065" author="@waejae"]Maybe something using the below?  battery box, quick connects, 2 gauge wire, battery isolator,
http://www.amazon.com/MinnKota-Trolling-Motor-Power-Center/dp/B001PTHKMG/ref=pd_sbs_auto_1?ie=UTF8&refRID=09QXH6440M9EN7RKSYW1
http://www.amazon.com/Tuff-Stuff-Winch-Quick-Connector/dp/B002CEPI5O
http://www.amazon.com/Smart-Dual-Battery-140A-Isolator/dp/B00400IYTK/ref=sr_1_19?s=automotive&ie=UTF8&qid=1403060784&sr=1-19&keywords=Amp+Battery+Isolator
http://www.amazon.com/Absolute-PROP2G20BK-2-Gauge-Ultra-Flexible/dp/B004FOSG08/ref=sr_1_2?s=automotive&ie=UTF8&qid=1403059668&sr=1-2&keywords=2+gauge+wire
[/quote][font size="3"][font face="arial"]You're on the right track, but here are a few thoughts:
[ol type="decimal"][li]The battery case - Seems like too expensive and fancy for your use. Do you really need extra 12 outlets and a voltmeter? If so, OK, but there are cheaper, simpler battery boxes.
[/li][li]The connector - I like this. A good way to connect to the TT.[/li][li]The isolator - I like the claim that it has no voltage drop, but it's physically impossible. The implication that it's not a diode isolator is good, but I would prefer a true relay (solenoid) controlled by the ignition switch. I also question the 13.4 volt turn-on threshold. My newer model truck sometimes doesn't get above 13.2 when the battery is fully charged. If yours is similar you may never charge the aux battery. Again, a relay controlled by the ignition switch is either connected or not connected.
[/li][li]The wire - I cannot tell by description if the wire is 100% copper or Copper Clad Aluminum (CCA). Aluminum wire has more resistance per foot for a given gauge than copper, but it's cheaper. Manufacturers advertise a certain gauge trying to fake you out with a lower cost product. In general #2 aluminum is electrically equivalent to #4 copper, #4 Al equivalent to #6 Cu, etc. Make sure you get true 100% copper wire. If it doesn't say so, it ain't.
[/li][li]The heavy #2  wire is only important between the TV battery and the battery you are trying to charge due to the heavy currents expected. The connection from the aux battery to the TT can be smaller because the currents are generally less than 10 amps. That said, if you want to recharge the TT battery directly from the TV while it's idling you would need the larger wire.
[/li][li]The comments from Sean are applicable. Recharging a battery is not instantaneous. The nice thing about hooking up the charged aux battery to the TT is it will run the TT while it slowly equalizes with the TT battery.[/li][li]Let us know how you progress.
[/li][/ol]
here is a much cheaper option of the same basic box: http://www.amazon.com/Shoreline-Marine-Battery-Power-Station/dp/B004UOUSWM/ref=sr_1_5?ie=UTF8&qid=1403106027&sr=8-5&keywords=battery+box though i dont know what size battery you plan to use so that might be a limitation.
[quote source="/post/1566/thread" timestamp="1403097387" author="@admin"]Side note, its not going to be an immediate transfer of energy. If you are expecting to charge a battery while driving then dump it to the TT its not going to happen the way it seems like you are expecting. I think of it like two barrels of water sitting next to each other, where one is full and the other is nearly empty. When connected the full barrel will eventually fill the nearly empty barrel until they are at an equal level.[/quote]
[quote source="/post/1568/thread" timestamp="1403103394" author="@charliem"][font size="3"][font face="arial"]Recharging a battery is not instantaneous. The nice thing about hooking up the charged aux battery to the TT is it will run the TT while it slowly equalizes with the TT battery.[/font][/font][/quote]
Both comments are correct, and Sean's analogy is an easy way to visualize the situation, but...
My thought was to use a boost circuit to actually force the auxiliary battery to charge the TT battery. In your analogy it would be like raising one of the barrels and using a syphon :)
There are plenty of adjustable boost circuits available on Amazon, but I'd be worried that I might overcharge the TT battery unless it was multi-stage. Which made me realize that my solar charger is multi-stage and I believe has a boost circuit built-in. I wonder what would happen if I hooked up the aux battery as the "solar panel"... would it boost and charge the TT battery using the aux battery as the source? I guess it's worth a try.
waejae
  " I wonder what would happen if I hooked up the aux battery as the "solar panel"... would it boost and charge the TT battery using the aux battery as the source? I guess it's worth a try.  "
I think that is what I was looking for.... I just didn't know it.  Not sure how a booster works but thought there had to be something that did it.  I will read up on them tonight.  Maybe leave the battery mounted in the vehicle and just run a thick pair of wires from the TV (if you can park close) with a quick connection set up on both ends?
Thanks again
[quote source="/post/1575/thread" timestamp="1403123048" author="@waejae"]
Thanks again[/quote]A boost circuit produces a higher voltage than the input voltage (with some efficiency losses). This will create current from the input (the mobile battery) to output (the trailer battery) beyond the point of equalization you'd get from just connecting them in parallel. It's essentially a battery powered battery charger  :).
For example, lets say your mobile battery was at 100% and your trailer battery was at 75%. If the mobile battery is half the capacity of your trailer battery and we're in a magical world where charging is 100% efficient (it isn't) then connecting them in parallel would yield two batteries at 83% charge  >:(. But with a boost circuit you could charge the trailer to 100% by draining the mobile battery down to 25% (not ideal for lifespan, but maybe it's a cheap battery). That would give you a fuller trailer battery AND an emptier mobile battery to charge up the next day.
