New Livin lite web site ???
Started by popup2012, September 19, 2016, 11:50:00 PM
popup2012
Looks like they may have a new web site and some of the spec's seem new.
otisw
Looks like the Aluminum floor is gone: Laminated Floor – 1 7/8" Thick w/Fiberglass, Block Foam & Azdel (No Wood = No Rot)
[quote timestamp="1474340522" source="/post/24765/thread" author="@otisw"]Looks like the Aluminum floor is gone: Laminated Floor – 1 7/8" Thick w/Fiberglass, Block Foam & Azdel (No Wood = No Rot)[/quote]This is what I have in my 28RLS.  I'm sure it'll be controversial on here, but I like mine.   It's solid and has insulation...no cold toes in the AM!   No sqeeks or anything like that.   Linoleum over the extruded aluminum floor was not a great solutin IMHO.  I notice they kept the aluminum floor in the Toyhaulers which is a wise move for them.
[font size="3"]I have long thought that the cold AL floor could be cured by some sort of layered composite structure if they really wanted to. Apparently they (Thor) did and that's great. Time will tell if it holds up. However, I still like my rubber tile floor. This weekend we removed all the tiles, cleaned them, vacuumed the AL under them, and replaced them. Simple job over two days. Easily cleanable and repairable if needed. Can't do that with the fiberglass/composite/Linoleum floor, but nothing says you can't put thinner rubber mats on top. All around good solution. Also noticed the 21s picked up 500# and 10" in length. Maybe the wood cabinet trim and/or the new floor. Then there is something about dual 5 " double AL frame members. What's that all about?
queen
I keep getting a security alert when I try to get to their site, can someone post a link to the new site and I'll see if that works.
[quote timestamp="1474389201" source="/post/24776/thread" author="@queen"]I keep getting a security alert when I try to get to their site, can someone post a link to the new site and I'll see if that works.[/quote][a href="http://www.livinlite.com/"]http://www.livinlite.com/[/a]
idlerockfarm
I didn't dig into the site, but I poked around last night. It kept me up a bit. As before, I want more pictures!
idlerockfarm
Ok. There ARE more pictures up today vs last night.
I like the simplicity of the original aluminum floor and then you can do what you want on top of it!
I noticed they switched to leaf springs, along with the 2500 pound axle.  Looks like they added double steps.
[quote timestamp="1474382604" source="/post/24774/thread" author="@charliem"][font size="3"] Then there is something about dual 5 " double AL frame members. What's that all about?
[/font][/quote]The 5" double AL frame members look like they are paired with a 3" Tongue Tube Middle Rail
It looks like they will stop using Dexter axles. Will this be an improvement? I don't know.
[font size="3"]They went to leaf springs on CLs, but stayed with Dexter on their toy haulers. And that means........?
[font size="3"]But the [font size="4"]major[/font] improvement is still the lighted outside speakers. They'll go well with my new unmuffled 15,000 watt generator. Where can I get those?............... :P
