21rbs roof Ladder
Started by docktorjj, August 18, 2016, 11:39:15 PM
docktorjj
[font face="arial"]Can a roof ladder be added to a 2017 21rbs; say resting and attached to the bumper?[/font]
I'm curious about this as well.
Attached ? Sure.
How much weight it will bear is questionable.
What do you intend doing on the roof so often that you want a ladder ?
[font size="3"]Sun deck option on the new rubber roof?  8-)     8-)
djmiller
The rear wall was not designed for a roof ladder so there are no backers in the wall.
docktorjj
So Djmiller how can I add backers?   Please do not tell me what you cannot do; rather how do you suggest it be done?  I bought this trailer to attempt to live my full-timer dreams?  And pinstriper I figure a ladder attached is better than having to carry one when I am on the road fulltime, for maintenance and check the caulking as we are supposed to check - this is not new to me however, after reading this forum I am wondering if selling my 1999 Casita was a MISTAKE?
I hate to tell you what we do, doctorjj - we haul our Camplite off to a dealer and have the dealer check this stuff out! Neither I nor my husband want to get up on that roof. The dealer's we have used have special ladders on wheels that they use to access the roof - much more stable than a ladder that we would use.
[quote source="/post/25556/thread" timestamp="1477360942" author="@docktorjj"]So Djmiller how can I add backers?   Please do not tell me what you cannot do; rather how do you suggest it be done?  I bought this trailer to attempt to live my full-timer dreams?  And pinstriper I figure a ladder attached is better than having to carry one when I am on the road fulltime, for maintenance and check the caulking as we are supposed to check - this is not new to me however, after reading this forum I am wondering if selling my 1999 Casita was a MISTAKE?[/quote]I wonder if a portable ladder would be much more versatile than a permanently attached ladder? A folding or telescoping ladder strapped on the rear bumper or in the back of your Tundra would be more useful for general maintenance and cleaning for slides, windows, lights, etc and still provide access to the roof when needed. There are other threads on useful ladders others have purchased. For example:
http://livinlite-owners.com/thread/1960/sooner-ladder
Also, when camping, I always figured I could park next to my camper and easily (so to speak) get on the roof from the roof of my TV if I had an emergency fix to do.
[quote timestamp="1477360942" author="@docktorjj" source="/post/25556/thread"]So Djmiller how can I add backers?   Please do not tell me what you cannot do; rather how do you suggest it be done?  I bought this trailer to attempt to live my full-timer dreams?  And pinstriper I figure a ladder attached is better than having to carry one when I am on the road fulltime, for maintenance and check the caulking as we are supposed to check - this is not new to me however, after reading this forum I am wondering if selling my 1999 Casita was a MISTAKE?[/quote]Physics works. I've seen it happen.
A ladder leaning against the side of the rig has most of it's weight pushing straight into the ground. As Jack Nicklaus said, when asked what he learned in his golfing career "dirt is more dense than air". The bumper has less weight bearing capacity than the ground.
Then consider that the ladder leaned against the rig is pushing INTO the trailer wall. Contrast that against a ladder that is pulling on unsupported areas of the aluminum skin.
As for adding backers, it's simple. Disassemble the interior walls, weld in some additional aluminum framing, and put everything back.
[span style="font-size:13.3333px;"]How often are you checking the caulk ? I let the dealer do that once a year.[/span]
The way I see it, the rear bumper is plenty strong to support my 185 lbs.
If the base of the ladder was anchored there, it would support nearly all my weight. As long as the top of the ladder had support extending onto the roof, the project seems eminently doable with no "backers" needed at all on the rear wall.
Or so it seems to me.
Quote from: @fasteddieb" source="/post/25583/thread" timestamp="1477448305The way I see it, the rear bumper is plenty strong to support my 185 lbs.
"Nearly all" is mathematically equivalent to "less than all". What's carrying the extra weight ?
A couple sheet metal screws into 1/16th" aluminum ? Go ahead, I'll hold your beer.
[quote source="/post/25583/thread" author="@fasteddieb" timestamp="1477448305"]The way I see it, the rear bumper is plenty strong to support my 185 lbs.
Or so it seems to me.[/quote]Exactly.  If the base of the ladder can be anchored to the main frame (NOT the bumper), and the top of the ladder anchored to some of the roof structure, no loading will be placed on the exterior back wall.  Done correctly, that should work, but I don't get on my roof often enough to make a worthwhile investment of time, money and risk.
pinstriper,
Good point.
I'm imagining the bumper taking 99% or so of my weight, as would be the case if the ladder were mounted vertically. I would screw or bolt it to the top of the bumper, so that the fasteners would  be subject to little if any shear.
At the top, I'd think the fasteners would mainly be there to prevent the top of the ladder from pulling away from the trailer. Connecting to the aluminum roof either directly or via doubler plates should take that minor load.
I think - stipulating I'm no engineer!
And, to be perfectly accurate, most times you'd be holding my tequila, not my beer!
djsamuel,
Looks like we were both composing our posts at the same time.
The bumper sure seems strong enough to me.
[font face="arial" size="3"]I'm sure I don't need to weigh (pun?) in on this...... but I will. IMO, FastEddy is close to the mark here. The bumper is rigid and welded directly to the extended frame members so it is strong enough to take the weight of a human. The load is all in shear. Torque load kills the bumper, not shear (assuming good welds of course).  If the top of the ladder extends above the roof like an inverted "J" or swimming pool ladder, the load on the roof will be primarily in shear with a small compression component. The connection must be made directly to the roof structural tubing, using rectangular aluminum tubing to span members if necessary. No connection to the back wall should be attempted. Maybe I'll post a picture if I can get my CAD program away from my model railroad layout.  ;)
All that said, I question the real need for this complexity and cost. For the number of times I need to get to the roof  I can pull the TV up close or wait until I get home.  If really needed, a 12 foot folding or telescoping ladder could easily be carried on the bumper or stowed and would be much more versatile.[/font]
