LP gas supply
Started by shovelhead, May 29, 2014, 05:06:27 PM
I'm looking at an outdoor RV grill.  In the sales info it says it will run off an RV's LP gas supply.  Is there such a thing on a 21RBS. Looks as though you plug into your RV supply and run the tube to this grill for cooking.
[quote source="/post/1265/thread" timestamp="1401393987" author="@shovelhead"]I'm looking at an outdoor RV grill.  In the sales info it says it will run off an RV's LP gas supply.  Is there such a thing on a 21RBS. Looks as though you plug into your RV supply and run the tube to this grill for cooking.[/quote]
Such thing as what? The trailer uses LP gas for several appliances and the grill is no different.
You may need some adapters depending on the type of fittings used. The tanks on the trailer are identical to those used for propane grills, so even in a worst case scenario you could just disconnect one tank and connect it to your grill. I would recommend installing a tee after the changeover regulator though so you can connect more easily and manager your tanks better.
The sales pictures show a supply line from an RV and you connect with a hose they  include.  I wasnt sure if there is a supply line to the rear bumper area already.
Not on mine, but maybe others have it. I'm sure they'd add it if you custom ordered it. It would be fairly easy to add later too; all of the LP lines are accessible beneath the trailer.
