Replacement light bulbs
Started by djsamuel, May 15, 2014, 10:57:04 PM
[p]Does anyone know the type of bulbs in the ceiling and bunk lights in the 21BHS. We had one of the bunk lights burn out camping this weekend. When I removed the bulb, there are no markings whatsoever on the bulbs. I want to by spares for the bunk lights as well as the ceiling lights, but see a wide range of wattage on bulbs that look similar.[/p][p]
[/p][p]Thanks,[/p][p]
[/p][p]Doug[/p]
[quote source="/post/1002/thread" timestamp="1400205424" author="@djsamuel"][p]Does anyone know the type of bulbs in the ceiling and bunk lights in the 21BHS. We had one of the bunk lights burn out camping this weekend. When I removed the bulb, there are no markings whatsoever on the bulbs. I want to by spares for the bunk lights as well as the ceiling lights, but see a wide range of wattage on bulbs that look similar.[/p][p]
[/p][p]Doug[/p][/quote][font size="3"][font face="arial"]Are they incandescent or LED?[/font][/font]
[font size="3"][font face="arial"]In that case I'm guessing type 921. This is a very common miniature wedge base bulb in campers. [/font][/font][font size="3"][font face="arial"]There are others out there, but generally dimmer.  [/font][/font][font size="3"][font face="arial"]My 2014 21RBS came with LED lighting so I can't check mine. Here's a link to all you'll ever want to know about them [a href="http://www.donsbulbs.com/cgi-bin/r/b.pl/921.html"]921 Bulb[/a]. If one burned out, others with similar use patterns will soon. Now is the time to go LED  [a href="http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-18-smd-led-wedge-base-tower/397/"]LED Bulb[/a].
[quote source="/post/1006/thread" timestamp="1400241634" author="@charliem"][font size="3"][font face="arial"]In that case I'm guessing type 921. This is a very common miniature wedge base bulb in campers. [/font][/font][font size="3"][font face="arial"]There are others out there, but generally dimmer.  [/font][/font][font size="3"][font face="arial"]My 2014 21RBS came with LED lighting so I can't check mine. Here's a link to all you'll ever want to know about them [a href="http://www.donsbulbs.com/cgi-bin/r/b.pl/921.html"]921 Bulb[/a]. If one burned out, others with similar use patterns will soon. Now is the time to go LED  [a href="http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-18-smd-led-wedge-base-tower/397/"]LED Bulb[/a].
[/font][/font][/quote]Thanks Charlie.  The more I looked online the more I was leaning to the 921s.  Thanks for the affirmation.
Doug
[font size="3"][font face="arial"]Glad to help, Doug. The 921s are very common, very hungry, very hot, and they degrade quickly.
