28BHS Recommendations
Started by cl21bhs, November 02, 2015, 11:15:08 PM
cl21bhs
I am considering purchasing a 2015 28BHS, does anyone have one that can provide recommendations etc. I currently own a 21BHS and previously a 16DB so I am very familiar with camplites, we just love them.
Thanks for the thoughts.
Steve
Pirdytj owns one up in Oregon. You might private message him.
Quote from: @cl21bhs" source="/post/16426/thread" timestamp="1446520508I am considering purchasing a 2015 28BHS, does anyone have one that can provide recommendations etc. I currently own a 21BHS and previously a 16DB so I am very familiar with camplites, we just love them.
Steve
If that's what you want, then get it while you can because they just discontinued it:
http://www.livinlite.com/camplite-models.php
"Dealer stock only"
Dropping a bunch of models out of the Camplite line. Wonder if they are just moving them to the Bearcat brand.
[quote timestamp="1446563152" author="@tinkeringtechie" source="/post/16434/thread"]If that's what you want, then get it while you can because they just discontinued it:
"Dealer stock only"[/quote][font size="3"]And so it continues.....................[/font]
[quote timestamp="1446563371" author="@ammobob" source="/post/16435/thread"]Dropping a bunch of models out of the Camplite line. Wonder if they are just moving them to the Bearcat brand.[/quote]It's possible, but it would seem silly to advertise the end of a model and not introduce the replacement. Of course it also seems silly to add wood cabinets to an all aluminum trailer  :'(
Steve, not to discourage you but after an Internet search there are very few of the 28s out there. I found 1 in Maryland and 1 with a pending sale in Florida. Might be a tough find with only dealer inventory available.  :-[
[quote source="/post/16440/thread" timestamp="1446569712" author="@ammobob"]Steve, not to discourage you but after an Internet search there are very few of the 28s out there. I found 1 in Maryland and 1 with a pending sale in Florida. Might be a tough find with only dealer inventory available.  :-[ [/quote]I'm guessing that's why they discontinued them... probably only sold a handful of them. I think there's only two or three that showed up here on the forum. Rather than "update" them it made more sense to just let it go.
purdytj
Yes, we purchased one over Labor Day this year. Loving the space for our family of 5. Annoyed by the wheel well leaks but I recently resolved those with Vulkum. Haven't tested it all yet but should be a big improvement.
We do have a crew cab long bed Duramax diesel, weight distribution hitch, and anti sway bar. No complaints on the towing quality even though I'm about to put new shocks and lift kit components on my truck.
How do you apply the Vulkum sealant to the wheel wells? Do you have to crawl under the trailer and apply while lying on your back, or do you have to put it up on a lift? Or can you take care of it from inside the camper?
purdytj
[quote source="/post/16828/thread" timestamp="1448741813" author="@gbpack"]How do you apply the Vulkum sealant to the wheel wells? Do you have to crawl under the trailer and apply while lying on your back, or do you have to put it up on a lift? Or can you take care of it from inside the camper?[/quote]I used jack stands and removed the wheels on one side at a time. I then sealed every seam that was pieces of metal coming together (there is one long edge that is bent metal - I didn't worry about it). The biggest gap was between the wheel wells and the siding of the camper (outside edge), which happens to be the hardest to get to. However, I think the greatest leaks were happening where the wheel well metals attach to the flooring & linoleum.
purdytj
Also of note, we're having a problem with water coming in when the slideout is closed: Water runs along the top of the slideout and drips in. It appears to be that the seal between the slideout and exterior fiberglass are not making contact - there is about a 1" gap! I need to purchase a bigger seal / gasket to make a better watertight seam.
OK. Thanks so much for the tips. Will look for those things when we get ours next week's
[quote source="/post/16831/thread" timestamp="1448746051" author="@purdytj"]Also of note, we're having a problem with water coming in when the slideout is closed: Water runs along the top of the slideout and drips in. It appears to be that the seal between the slideout and exterior fiberglass are not making contact - there is about a 1" gap! I need to purchase a bigger seal / gasket to make a better watertight seam.[/quote]
I wonder if the slide out "in" position is adjusted correctly? A once inch gap from the installed seal is significant and perhaps the stop mechanism is not shutting the motors down early? Our slide out has a large gap along the bottom when closed from a poor seal design, but the sides and top are fine.
purdytj
[quote source="/post/16834/thread" timestamp="1448762715" author="@sandroad"][quote source="/post/16831/thread" timestamp="1448746051" author="@purdytj"]Also of note, we're having a problem with water coming in when the slideout is closed: Water runs along the top of the slideout and drips in. It appears to be that the seal between the slideout and exterior fiberglass are not making contact - there is about a 1" gap! I need to purchase a bigger seal / gasket to make a better watertight seam.[/quote]I wonder if the slide out "in" position is adjusted correctly? A once inch gap from the installed seal is significant and perhaps the stop mechanism is not shutting the motors down early? Our slide out has a large gap along the bottom when closed from a poor seal design, but the sides and top are fine. [/quote]I wonder if the dealer would cover it under warranty. Hopefully so.
