Do you have one of these?
Started by shovelhead, May 07, 2015, 04:18:41 PM
Do you have Portable Waste Tank?  It's just me and I'm about to go on some boondocking.  Any recommendations? Do I really need one?  What size 15, 22, 30 gallon?
[img style="" style="max-width:100%;" src=""]
[font size="3"]Dave,
Whether you need one or not depends on how, where, and how long you camp. I have the 15 gallon Barker blue tank, but actually I've yet to use it. I'm usually close enough to a dump station. I chose the 15 gal size because it fit nicely on it's side in my pickup bed. So why do you need one? Assuming just you the black tank will last for weeks. You should not have to empty the black tank very often, and if you do, you won't want to use the portable tank unless you really have to. Too messy. [/font]
[font size="3"]
Keep in mind the combined black and gray tank space is 2X the fresh water tank, so unless you have an additional supply of [/font][font size="3"]fresh water you will never have to empty a waste tank. [/font][font size="3"]The biggest demand on gray water space is the shower. Depends on how and how often you use the shower. [/font][font size="3"]We capture the dish washing water in plastic tubs and dump it down the toilet to conserve gray water space. That also adds soap to the black tank.
Another factor on the size of the tank is what will you do with it when it's full. If you can tow it to a dump station any size will work. If you have to lift it into the TV I think 15 gals is about max.
True boondocking is a careful balance among many variables: battery capacity, recharge methods, fresh water supply, waste water capacity and disposal, and propane supply. Most of our camping is at state and national parks that have electricity and water. Therefore gray water is the first limit and that's why I have the 15 gal blue tank.
Years ago we full time camped in a 24' fifth wheel for about 3 months straight but moved from campsite to campsite every 2-4 days. And this was before the days that all state and national parks and a lot of NF campgrounds have dump stations. We never ran out of black water capacity. I do admit to at least once dumping grey water on the side of the road when we were moving from NF to NF campsite and there was no dump station along the way.
So Charlie is right. Grey water will be your limiting factor. We can easily go for a week with the grey water capacity in our 16TBS, 32 gallons.
[font size="3"]One additional note on boondocking. Fresh water is easily hauled in containers. Rigid 5-7 gal water jugs can be carried empty and filled close to the final campsite. Collapsible 5 gal jugs are easily stored until needed. So it's practical to carry 60 gal of water onboard, and with careful waste management, survive for quite a while using only the installed waste tanks.
Having solved that problem the next limit will be the battery. Two six volt GC2s or two Trojan T-1275s are a must, plus a way to recharge. Generators work and solar is possible, but I favor heavy copper jumper cables from the TV. With all that we won't see you until you hit the beer and/or ice cream limits. Camp on!
If you're talking about true boondocking (no services) then an extra tank won't have much value. We bought the 15 gallon grey one from your picture and we use it at sites that have dumps and water, but no sewer connection. I only bring it if I know I'll be going to a site like that for an extended period because then we can continue to take showers and just dump the grey with the portable tank (I've never used it for black). Normally we don't bring it though because we usually move every few days and dump between sites.
Thanks for the input.  Helped a lot.  Saved me about $100.  If the grand kids were camping ..... maybe.  But by myself I think the onboard tanks will suffice.
Good info, thanks. In most of the state/national parks where we intend to camp for this year at least, there is electricity at the sites but no water or sewer. To avoid having to move the trailer just to dump, we may get a small 15 gallon tank  to strap on the rear bumper for grey water dumping. And we have a collapsible 5 gallon water carrier to add water to the fresh water tank.
We had a blue boy at the seasonal site. Used it maybe half dozen times in three years. Honey wagon took care of the rest weekly. I gave ours away with that trailer when we sold it. Try to get the one with the tongue to lay onto the hitch ball for larger CGs.
aznighthiker
Perhaps a good idea, I have heard many campgrounds require you to collect your grey water. Camping on the national forest in Arizona we have been asked how we collect and dispose of waste water and noted they are taking a survey.
15 Jumping Jack Camper
swbc150
I dry camp 95% of my camping in National Forest and like said above if you are careful with your Black water use, then your waste holding tanks will be fine.
My Last Trailer had two 25 gallon ea waste tanks, I stayed out for 3 weeks on many trips and only needed to add fresh water.
I have found the 5-6 gallon jerry type of water containers (Plastic) makes it easier to refill your RV Fresh water tank because of the spout that comes with it.
I wash the dishes mainly pots/pans outside instead of in the campers sink, I also use paper plates to cut down on washing, into the Fire pit they go.
I'm noticing that some of the Gas Stations are now offering a sewer dump for RV'ers and that really comes in handy.
