Dealer installed sway bar concern
Started by nmcamper, March 19, 2014, 12:24:12 PM
nmcamper
Prior to my picking up my 2014 Camplite 16TBS, the dealer installed a "Husky" sway bar ball mount on the right side of the tongue. I have seem comments on the forum that indicate sway bars that require drilling into the aluminum should not be used. The installer did not drill totally thru, but did drill 6 holes on the outside of the aluminum tongue to mount the plate.
Comments? Is this a potential problem?  I have also posted this on the Yahoo group forum
Thanks, Wayne
Can you clarify what you mean by "did not drill totally thru"? Did they drill through one side?
nmcamper
Yes, they drilled thru the outside, and appeared to mount the small ball mount bracket with a lag type bolt, rather than drilling thru the , inserting a bolt with nut.
vrvinmo
Interested in this as I have yet to install my sway control. My thought was that it would be better to drill holes all the way through and use bolt and nuts. I would think lag screws would come loose after a while. I also read in another thread that the factory told someone you shouldn't use WDH on the VRV? I'd love to know the truth to both WDH and sway control mounting plate.
[quote source="/post/242/thread" timestamp="1395280134" author="@vrvinmo"]Interested in this as I have yet to install my sway control. My thought was that it would be better to drill holes all the way through and use bolt and nuts. I would think lag screws would come loose after a while. I also read in another thread that the factory told someone you shouldn't use WDH on the VRV? I'd love to know the truth to both WDH and sway control mounting plate. [/quote]I agree. I have to wonder how well those lag bolts will hold since they are only gripping aluminum.
mdp
I plan on mounting my Husky sway control on the frame.  However my gas bottles are in the way.  I am going to fabricate a 16" x 5" plate with the sway control ball welded to it.  I will then bolt it on the top and bottom of the frame, probably using six stainless steel bolts, nuts and lock washers.  The holes will be drilled on the top and bottom of the fabricated plate.  I will put a think piece of rubber on the back of the plate to prevent galvanic reaction, even though the plate will painted or powder coated.
mdp,
Check out my thread on picking up our 21BHS.
Swapping the battery and propane tanks was easy, and there are pictures there.
Fabricating a mount is fine, but a Husky sells one for a reasonable amount, also discussed in my thread.
vrvinmo
I ended up going with the Andersen No-sway WDH which has sway control built-in. I didn't have to attach anything after all.
We have the Andersen hitch; just used it yesterday. It has worked out great for us and I'm sure you'll be happy with it.
