Prolonged Occupancy
Started by leslie, September 07, 2014, 11:45:20 PM
Please define the term "prolonged occupancy" as used on page 41 of the owner's manual in the section "Effects of Prolonged Occupancy".
My husband and I have ordered a Camplite 21-BHS, which at this time is scheduled to be completed on September 16, and we will take delivery at your dealer in Rockford, IL. If this winter turns out to be much like the past winter, I will be taking my camper, along with my 2 dogs, to Florida.
My question is, how much time do you consider to be a prolonged occupancy, which can cause my warranty protection to be reduced? I definitely need to know when to end my trip to Florida before "premature deterioration of structure, interior finishes, fabrics, and drapes" occurs. The damage described here "will not be considered normal, and will under the terms of the warranty constitute misuse, abuse, or neglect, and will therefore reduce your warranty protection".
Thank you, and I await your reply.
Leslie Ewing
You are worrying needlessly. It doesn't matter what the warranty says about prolonged occupancy. If you nick it, scratch it, burn it, dump harsh chemicals on it, or whatever then no warranty will cover it. If it falls apart just sitting there (and can you think of something that this might apply to, I can't) then the warranty should cover it.
The prolonged occupancy restriction is just so much bullshit written by a poor attorney IMO.
Forgetaboutit.
funpilot
I believe I saw a discussion on another forum on this.  First, pro-longed occupancy I believe is code name for using it for full time.  There are significant differences between how a trailer is built for full time usage and casual vacation use. From what I recall, most of it has to do with ventilation, quality of refrigerators, stoves, microwave, and a/c.  Even cabinetry hardware is suppose to be better for full timing.  But what I think I remember what was most important was around ventilation and cooking.  Put simply, our trailers will stink and/or fall apart more quickly if they are used for full time and that might be the core concern, but at my age I can no longer be sure how good my memory is.
My husband and I are planning some 3 - month long road trips. I will have an outdoor kitchen. However, if a trip of this length affects the warranty, now is the time to find out.
[quote source="/post/3446/thread" timestamp="1410290996" author="@leslie"]My husband and I are planning some 3 - month long road trips. I will have an outdoor kitchen. However, if a trip of this length affects the warranty, now is the time to find out. [/quote]I wouldn't worry about 3 months. They're trying to cover their butts for people who live in it 3 years and make warranty claims the whole time.
[quote source="/post/3443/thread" timestamp="1410286387" author="@david"]You are worrying needlessly. It doesn't matter what the warranty says about prolonged occupancy. If you nick it, scratch it, burn it, dump harsh chemicals on it, or whatever then no warranty will cover it. If it falls apart just sitting there (and can you think of something that this might apply to, I can't) then the warranty should cover it.
Forgetaboutit.
David[/quote][font size="3"]"The prolonged occupancy restriction is just so much bullshit written by a poor, [font color="e61942"]but well paid[/font], attorney IMO." Otherwise, you're correct.
Charlie:
You are absolutely right. I stand corrected.
IMO that language is total bullshit and no court would uphold it if a warranty claim were ever denied based on that language.
But does anyone expect that an all aluminum frame and exterior, synthetic paneled interior camper to ever fall apart, even if someone does live in it full time for the next gazillion years. Maybe the overpaid lawyer that wrote that language does ;-).
But let's talk about warranties on campers for just a minute. LL only warrants the stuff that they build: the frame, the skin, the interior paneling, the wiring and the plumbing. Everything else (and that is the stuff that can fail from heavy use) is excluded. But the excluded stuff is covered by the manufacturer's warranty. So does Dometic exclude "prolonged use" from the warranty on their refrigerator? No I don't think so. If it fails on the 364th day even if you live in your camper continuously then it is covered. After that, maybe not.
That is why I think LL's language is so much BS. It does nothing to protect them and unnecessarily upsets the consumer, like leslie.
funpilot
[quote source="/post/3453/thread" timestamp="1410301704" author="@david"]
[/quote][p]Well, the lawyer in me says that we should not casually dismiss this issue as it does pop up several hits when queried, showing that other manufacturers have language around it and not just LL. Google "prolonged occupancy in rv warranties" and read what pops up.   [/p][p]
[/p][p]Perhaps, we should see this as an acknowledgement from the industry that these trailers are not built for prolonged occupancy and our using them to do so has been shown to cause damage to the trailer. What you can be absolutely sure of is that more than one person has sued more than one RV manufacturer in the past and won for damage the manufacturers ultimately attributed to prolonged occupancy.  To protect themselves from warranty issues stemming from a usage level they did not engineer into their products, we now see the language in question. Just my 2 cents.[/p][p]
funpilot
Here is an excerpt from another owners' manual (Escape).  I do see a pattern in what I have read around condensation if that helps.
Chapter 2: Effects of Prolonged Occupancy
Your recreational vehicle was designed primarily for recreational use and short-term occupancy. If you expect to occupy the coach for an extended period, be prepared to deal with condensation and the humid conditions that may be encountered. The relatively small volume and tight compact construction of modern recreational vehicles means that the normal living activities of even a few occupants will lead to rapid moisture saturation of the air contained in the trailer and the appearance of visible moisture, especially in cold weather.
Just as moisture collects on the outside of a glass of cold water during humid weather, moisture can condense on the inside surfaces of the recreational vehicle during cold weather when relative humidity of the interior air is high. This condition is increased because the insulated walls of a recreational vehicle are much thinner than house walls. Estimates indicate that a family of four can vaporize up to three gallons of water daily through breathing, cooking, bathing and washing.
Unless the water vapor is carried outside by ventilation or condensed by a dehumidifier, it will condense on the inside of the windows and walls as moisture or in cold weather as frost or ice. Appearance of these conditions may indicate a serious condensation problem. When you recognize the signs of excessive moisture and condensation in the trailer, action should be taken to minimize their effects.  Ventilation, Condensation and Moisture Management  The following steps should be taken to aid in eliminating internal moisture condensation:  Interior Care of Your RV  Signs of excessive moisture can be obvious, such as water droplets forming on surfaces or wet areas around cushions or mattress. Conversely, signs of excess moisture can be subtle, such as condensation forming on metal surfaces. When symptoms appear it is important to timely determine the cause of the excess moisture and take appropriate corrective action to prevent moisture related damage.  Control Relative Humidity  Monitoring and controlling relative humidity within the RV is one of the most important steps to minimize the risk for moisture-related damage. Ideally, relative humidity should be at 60% or less. Relative humidity can be monitored utilizing a portable hygrometer, a small device that measures temperature and relative humidity. Hygrometers are available at electronics or building supply stores for approximately thirty dollars ($30).
Use exhaust fans, the air conditioner, and/or a portable dehumidifier to manage moisture inside the RV to maintain relative humidity at 60% or less. In cold climates, relative humidity may need to be at 35% or less to avoid window condensation issues.
If the RV is used the majority of the time in a hot-humid climate, it may be difficult to keep relative humidity below 60%. A dehumidifier will help, but it is important to check the condensation (water) collection bucket regularly or discharge the condensation (water) directly to a drain.
6
Avoid Drastic Thermostat Setbacks Cooler surface temperatures increase the potential for condensation and surface mold growth. To minimize the opportunity for condensation to form on interior surfaces, maintain a comfortable temperature in your RV, and avoid nighttime setbacks of 10 degrees or more. Drastic setbacks that reduce the indoor air temperature quickly can increase the chance for airborne moisture to condense on cool surfaces such as windows. If you are away from your RV for an extended number of days, we recommend that you do not set the temperature back without taking other measures to manage relative humidity, including operating a dehumidifier with a continuous drain.  Manage Window Condensation  Window condensation issues can be identified by water or ice build-up, usually at the base of the window. The majority of these problems can be addressed by managing moisture generated inside the RV. Minor condensation issues are not unusual, especially for RVs used in colder climates. The key is to manage this small amount of moisture if evident by wiping the surface, and as discussed above, maintaining a reasonable relative humidity within the unit.
To help minimize window condensation, use exhaust fans vented to the outside, avoid drastic changes in thermostat settings, do not use 'vent-free' heaters and use window coverings wisely. For example, make sure to open curtains or blinds during the day to allow air to circulate and warm the window surface. Storage and Other Isolated Areas Within the RV  Storage areas are more difficult to condition since the areas are isolated from the main body of the RV. The surfaces of these areas are more at risk for condensation and surface mold growth. To minimize this risk, clean storage areas regularly, and allow an air space between stored items and the exterior wall to promote air circulation.
During prolonged use of the recreational vehicle in very cold weather, closet and cabinet doors should be left partially open in order to ventilate the interiors of storage compartments built against exterior walls. The air flow will aid in warming exterior walls, assist in reducing or eliminating condensation, and prevent possible ice formation.  Use of Unvented Combustion Equipment  Unvented combustion equipment, such as propane stovetops, are a source of moisture within the RV. For every gallon of fuel consumed, approximately one gallon of water vapor is evaporated into the air. Whenever possible, operate an exhaust fan in combination with the use of any unvented combustion appliance within the RV. Water vapor and other combustion by-products should be vented to the exterior of the RV. The RV owner should strictly follow use and maintenance instructions for safe operation of any combustion equipment, particularly unvented equipment.
DO NOT HEAT THE TRAILER WITH RANGE OR OVEN.
7
(WARNING Continued)
In addition to the dangers of toxic fumes and oxygen depletion which makes heating with the range or oven very dangerous, open flames add moisture to the interior air, increasing condensation. Do not use an air humidifier inside the trailer.  Use of Your RV  It is important to remember that the square footage of an RV is significantly less than that of a single family residence. This fact alone will elevate the relative humidity because there is less volume of air to help absorb or dissipate the humidity. For example, showering and cooking create a lot of humidity in a small area. In these instances, use of an exhaust fan and opening windows should reduce the relative humidity, particularly when living in the RV for an extended period.
Ventilate your recreational vehicle regularly by partially opening roof vents and one or more windows. Use vents when using the range or shower. While this venting will increase the furnace heating load, it will greatly reduce, or eliminate, water condensation. NOTE: Even when it is raining or snowing, ventilation air from outside will be far drier than interior air and will effectively reduce condensation.
Remember to run the range vent fan when cooking and the bath vent fan (or open bath vent) when bathing to carry water vapor out of the trailer. Avoid excessive steam resulting from boiling water or use of hot water. Remove snow or water from shoes or boots before entering the trailer to avoid soaking floor.
Also avoid drying overcoats or other clothes inside the trailer Exterior Care Of Your RV  The exterior shell of the RV is the primary weather and moisture barrier. Over the life of the RV, the shell will require regular care and maintenance in accordance with the owner's manual. The shell includes the roof, sidewalls, windows, doors, and under-floor. Particular attention needs to be devoted to these components in order to maintain a tight barrier against bulk water intrusion.
The shell should be inspected periodically for cracks, gaps, and condition of sealants in accordance with your owner's manual. Areas that require maintenance should be resealed utilizing a similar, high quality sealant used by the manufacturer. Storage of Your RV  During those periods when your RV is not in use, care must be taken to ensure moisture sources are addressed. Ideal storage of your RV would be in an enclosed climate controlled environment. When this is not possible, the following steps should be taken to ensure moisture is controlled:
• Turn off all water sources;
• Turn off all combustion appliances;
• Drain the water tank(s);
• Drain the water heater;
• Open all closets, cabinet doors and drawers;
• Close all windows and entrance doors;
8
• Open a vent or a window enough to allow for some limited ventilation air flow, but not so far as to allow snow or rain to enter;
When storing the RV in high humidity climates (ambient relative humidity is greater than 60% year round), add a dehumidifier drained to exterior to control humidity inside the RV during storage.  Wet Areas  Areas that are exposed to water spills or leaks should be dried as soon as possible and definitely within 24-48 hours. Drying areas quickly minimizes the chance for moisture damage and possible mold growth, which can begin to form colonies in 24-48 hours. A variety of methods can be used to help the drying process:
• Remove excess water with an extraction vacuum.
• Use a dehumidifier to aid drying.
• Because moisture is key to mold issues, treat all signs of condensation and spills seriously and deal with promptly. Failure to deal with a moisture issue promptly may cause more severe issues where none initially existed, or may make a small problem much worse.
• Be sure to understand and eliminate the source of moisture accumulation as a part of the clean-up. Otherwise, the same issues will simply recur.
• Small amounts of mold should be cleaned as soon as they appear. Small areas of mold should be cleaned using a detergent/soapy solution or an appropriate household cleaner. Gloves should be worn during cleaning. The cleaned area should then be thoroughly dried. Dispose of any sponges or rags used to clean mold. Use A Dehumidifier  During prolonged and continuous usage of the trailer, a dehumidifying appliance may be more comfortable and effective in removing excess moisture from interior air. While use of a dehumidifier is not a cure-all, operation of a dehumidifier will reduce the amount of outside air needed for ventilation. Thus, the heating load on the furnace will be reduced and the interior will be less drafty.
Remember, your trailer is not designed, nor intended, for permanent housing. Use of this product for long-term or permanent occupancy may lead to premature deterioration of structure, interior finishes, fabrics, carpeting and drapes. Damage or deterioration due to long-term occupancy may not be considered normal and may, under the terms of the warranty, constitute misuse, abuse or neglect and may therefore reduce the warranty protection.
USE OF KEROSENE OR OTHER AFTERMARKET SPACE HEATERS IS NOT RECOMMENDED AND IS AT YOUR OWN RISK. SUCH HEATERS MAY DISCHARGE MOISTURE AND GASES FROM COMBUSTION INTO YOUR TRAILER OR CAUSE EXCESSIVE INDOOR HUMIDITY. SUCH HEATERS MAY ALSO CAUSE A FIRE, DEPLETE
9
(WARNING Continued)
OXYGEN, OR RELEASE CARBON MONOXIDE OR OTHER HARMFUL GASES WHICH CAN CAUSE SERIOUS INJURY OR DEATH.
funpilot:
I really should shut up about this crazy issue and enjoy a shot of good bourbon after dinner. But it bugs me.
The boating industry has been aware of condensation inside boats long before Columbus discovered the new world. It is worse than on RVs because, well boats are on water. Even in the days of wooden boats, owners and boat builders understood this problem and learned to live with it. Today with 99.9% of boats being built of fiberglass (but often with wood interior trim and panels) I don't know of any manufacturer who has such a crazy warranty exclusion. The customers would laugh them out of business if they did.
Yes there may have been some mildew claims on RVs and just maybe structural damage was alleged to have been caused by moisture as a result of "prolonged occupancy". That is probably why the industry inserted that onerous language.
But it ain't gonna happen to a Livin Lite camper. Aluminum isn't going to mildew. Maybe Azdel will develop a surface coating, but it certainly won't rot. The risk of dammage to a LL is zip, zero, nada.
Reading funpilot's last post reminds me of why I did not become a lawyer. I fell asleep reading legal cases
However, I do appreciate the lengthy excerpt. I read the Camplite Owner's Manual completely and carefully. I notice that Livin Lite used some of the same phrases as is presented here. Livin Lite's version left out some of the content. Livin Lite is a member of RVIA, the industry's association. I think RVIA has provided some of these phrases, IMHO.
I have heard lawyers say that if something doesn't have a definition, then it doesn't exist. I asked Livin Lite to define "prolonged occupancy". So far, they have declined to do so. Therefore, the question is - does it exist?
Prolonged occupancy = ROUS. I don't think they exist.
funpilot
[quote source="/post/3463/thread" timestamp="1410315892" author="@leslie"]Reading funpilot's last post reminds me of why I did not become a lawyer. I fell asleep reading legal cases
I have heard lawyers say that if something doesn't have a definition, then it doesn't exist. I asked Livin Lite to define "prolonged occupancy". So far, they have declined to do so. Therefore, the question is - does it exist?[/quote][p]I just went out and looked at Lance's language on prolonged occupancy.  Like Leslie said, it is virtually identical. That at least seems to state that the industry has a consensus that these types of trailers are not suited for that.  I am going to try and contact the RVIA later today to see if they are the source of this language and whether there is a definition.[/p][p]
funpilot
Ok, I was able to talk to the right person at the RVIA.  He had never heard the term "prolonged occupancy" before so that tells us any boilerplate we are seeing did not come from the RVIA. He did say a couple of things that were interesting.  First, under the fire code, our trailers are defined as vehicles and can only be used for temporary living quarters. He offered to send me links on that so when I get them, I will post it. Second, he has not heard of any complaints being filed with the RVIA on warranty issues related to prolonged occupancy.  Third, he did say they have numerous defined terms in their standards and defining them has not stopped the debate on what they mean from one manufacturer to another.  The vagaries around creating a "prolonged occupancy" definition he conceded would be a challenge.
So, with that in mind, I went back again and looked at several sections around prolonged occupancy and they seem to be focused on the impact of it.  So, at this point, I am seeing it as a "heads up" from the manufacturer that these trailers are not homes (they are vehicles) and we should not use them in a way that was not intended. As to when and if they would use that as a defense against a warranty claim, I cannot answer that.
Seems to me if there is so much uncertainty within the industry itself, they could not expect the customer to clearly understand where the coverage ends. You can't agree to something that neither party is clear on as to its definition. That would be my assertion and make them defend that. Then trot in all the examples of different interpretations in support of your argument.
