Command Strips
Started by pinstriper, August 19, 2014, 02:16:15 AM
Anyone used the "bath" versions on an exterior application ? How resilient are these around moisture ?
Not sure about exterior use but I have 2 command strip hooks in the wet bath on the 13QBB that I use for towel hooks and they haven't budged since I put them up.
If you go to Command's website at command.com, they list all of their products in different categories. They have a category for outside applications. They also have FAQs where they say that their adhesives don't work well on cars due to temperature extremes, particularly due to temperatures exceeding 105 degrees softening the adhesive to the point that it loses its stickiness.
However, lots of people use Command products in their RVs and they seem to be very satisfied. I would think that the issues with cars would be similar to conditions with RVs, especially when you consider what storage conditions are like.
Thanks, both. I guess I may blaze the trail with the exterior use.
