Sienna towing 11fk
Started by cayenneman, August 26, 2016, 01:23:33 PM
cayenneman
Anyone using a Toyota Sienna to tow?
The Toyota Sienna has a 3.5 liter engine which should be more than adequate for towing an 11fk. The 11fk has a listed dry weight of 2,000 lbs and with options, gear and fluids probably hits 2,500 lbs. That should work fine with the Sienna's 3,500 lb tow rating.
Mmm, yeah. Depending on how much is in the Sienna, to make sure you don't overload the GCVWR. It's not just about tow rating.
You may have to stiffen the rear suspension. Once you load all your gear in the back, the rear wheels may tow out. This will cause lots of wear on the inside of your rear tires.
