Bathroom Skylight
Started by popup2012, July 24, 2016, 04:18:58 PM
popup2012
Has any one ever used some type of insulation to block the sun from the skylight.  I was at Daisy State park in AR last week (98+) and the heat in my bathroom was terrible.
hogtyd
Camco makes several types, such as this insulated one. Looks like it would also be a relatively simple DIY.
Camco 45192 Sunshield Vent Insulator with Reflective Surface https://www.amazon.com/dp/B0024E6QX0/ref=cm_sw_r_cp_api_nPrLxbAGM94AY
-Graham
montedtrotter1
I just bought a piece of 1 inch thick 2'x2' styrofoam insulation  at Home Depot and cut it to size to fit the hole. Works great and basically I leave it in place all the time until I take a shower. You are correct in that the heat build up is amazing without it. Works great and very cheap.
[quote timestamp="1469389463" source="/post/23318/thread" author="@graham"]Camco makes several types, such as this insulated one. Looks like it would also be a relatively simple DIY.
-Graham [/quote][font size="3"]+1 on these. Very effective. Cutting one in half and pairing with a full one works great for the shower skylight too. Just unzip, cut the foam, and rezip. Required Gvmt warning: Remove before showering; not for internal consumption.  ;) [/font]
