Power Center
Started by drake, June 20, 2016, 11:45:09 PM
drake
Finally have time to start going through our new 21bhs. I plugged it in in the driveway to go through AC items and noticed something odd with the power center / fuse box / not sure of official name.
Every couple minutes or so it starts making a humming type noise, I'm assuming the transformer charging the battery.  After 10 seconds or so, the fan kicks on, runs rather weakly, then cuts off after 5 seconds or so.
Is this normal?
I don't have a 21 but my power center makes no noise and something cycling that frequently would strike me as a problem.
I'm not sure what normal is, but my power center does not cycle on-off like that. The converter that charges the battery and runs the DC circuits is always on but a heavy load could make it hum and kick on the cooling fan. I think you should ask the dealer about the frequent cycling; maybe that's normal on certain brands, but yours seems extreme.
drake
Thanks!
Checked this morning and it is silent. I am guessing it was due to the load from the fridge, but am definitely adding it to my list for my next dealer visit.
Knock on wood, I have even pleasantly surprised by the lack of issues I've encountered.
pjcd
Never noticed any odd noise,,,,  but then again, I must be hard of hearing, my wife says I never hear her when she's calling.
[quote timestamp="1466477109" source="/post/22401/thread" author="@drake"]Every couple minutes or so it starts making a humming type noise, I'm assuming the transformer charging the battery.  After 10 seconds or so, the fan kicks on, runs rather weakly, then cuts off after 5 seconds or so.
Is this normal? [/quote][font size="3"]Humming and a running fan indicates a heavy load on the converter such as charging a very depleted battery, but [/font][font size="3"]I would not expect it to be that intermittent. [/font][font size="3"]Please check the brand and model of your power panel.[/font][font size="3"] There is a label inside the front door. The original was a Power Dynamics, Inc. model PD4045KA. It has a fan, but I've never heard mine come on. I'm curious as to whether LL is using the same PD converter. [/font][font size="3"][/font]
drake
Same model you referenced above.
I couldn't hear the fan, I removed the cover plate and saw it engage.  I'll keep an eye on it, thanks!
[font size="3"]Glad to hear they're still using the PD. Your fridge only runs on 120VAC and Propane, although it does require minimal 12VDC for control. Not enough to tax the converter. However, the fridge does have its own fan that turns on periodically with a temperature sensor. You might be hearing that and it's normal.
drake
Ah, good call.
This was definitely coming from the converter . . .
