mdp
Started by mdp, May 07, 2014, 05:06:44 PM
mdp
Is it ok to use short plastic screw anchors to hang wall decorations.  They not have a lot of weight.
Thank You
[font size="3"][font face="arial"]I would advise against using them in the Camplite walls. The Azdell wall material is extremely thin, only about 0.2 inches thick, and the wall is filled with foam insulation. Not much for the wall anchors to grab on to and they leave holes if you change you mind. Many of us use 3M Command Strips. T[/font][/font][font size="3"][font face="arial"]hey adhere well[/font][/font][font size="3"][font face="arial"] if you clean the surface before applying and can be removed without damaging the wall. [/font][/font][font size="3"][font face="arial"]I use the water resistant variety because humidity does build up in the camper sometimes.
[a href="http://www.amazon.com/Command-Designer-Plastic-Water-Resistant-4-Strip/dp/B000FCES6K/ref=sr_1_1?srs=2587573011&ie=UTF8&qid=1399495223&sr=8-1&keywords=water+resistant+command+strip"]Medium Hooks[/a]
[a href="http://www.amazon.com/Command-Hooks-Resistant-Adhesive-Strips/dp/B000YEZJQW/ref=sr_1_38?ie=UTF8&qid=1399495428&sr=8-38&keywords=water+resistant+command+strips"]Mini Hooks[/a]
mdp
[font color="#e64a19" size="4"]Hello Charlie:  thanks for the reply.  I was afraid that might be the case for screw anchors.  I will proceed with the 3m hooks.
By the looks of the locomotive, I would say you have been out west, Colorado?
Melvin[/font]
[font size="3"][font face="arial"]Yes and Yes. That's on the Cumbres & Toltec SRR between Chalma, NM and Antonito, CO. I consider CO home an we try to go there each year. West is best, East is least.
If you need to hang something heavy look for the studs in the wall or the framing members around the edges. They are 1"x1" square AL tubing and will hold almost anything with a sheet metal screw.
mdp
Finding the studs should not be a problem.  the 3m hooks will do most of the stuff i need done.
