Practice Boondocking
Started by charliem, December 17, 2015, 03:53:42 PM
Dec 17, 2015 11:58:04 GMT -6 leslie said:
My eyes are glazing over. I can see the advantage of an SOC. My husband is an EE. I am going to have him read this thread, and the other threads about batteries and let him decide. Anything else he needs to consider?
This summer we are going to take baby steps with boondocking, so we figure out how to make water and batteries last.
[font size="3"]Leslie et al,
I'm starting this new thread to avoid diluting the battery charging thread. As you ease into boondocking, an excellent idea, I suggest you "practice" a bit. I've done this a few times to understand what limits are imposed and how to deal with them. This "practice" entails camping at a full or significant service campsite, but turning off services such as electric, water, and sewer until a limit is reached. You can test your use of the battery by simply not plugging in; test your use of water by filling the fresh water tank and turning off the water hydrant, etc. If you're camping in summer heat you can plug in and use the AC, but turn off the converter, to simulate cooler weather camping. Of course, run the WH and fridge on propane. The trick here is when you reach a battery, FW, or waste water limit, help is just a switch/valve/dump away. This will tell you how your conservation efforts are working without ruining a boondocking trip.
While boondocking I find each system has a unique solution. With dual 6V golfers and the jumper cables the battery is solved as long as you don't need AC or microwave. Fresh water is usually available either at or near the campsite. A fill up augmented by a water thief and 5 gallon jugs solves that one. The black tank should not be a problem for two people for a week. The gray tank limit depends entirely on your dish washing and showering habits. Paper plates/bowls help and my wife is the master of 1 gallon showers. If a dump station is near, a 15-20 gallon "blue tank" helps. A single 20# propane bottle lasts a long time even with moderate heating and cooking. Dual propane tanks with automatic switch-over makes this a non problem. If you're out of range for all these supplies you're at the mercy of your creativity.
BTW I do have a EE. In fact I've got two, but I still do a lot of reading  ;)    Camp on!
Thanks for some good ideas, charliem. We have already started testing our limits while on full hookups. We are adaptable and we can learn! I think this is part of the fun of having a camper, by going out of our comfort zones to see what we can really do.
You can save freshwater and grey water space by simply not doing anything to break a sweat. Then you don't need a shower.
I'm practicing up for this, right now.
aggie79
Our teardrop trailer doesn't have all of the goodies of a travel trailer, so in a way we are "semi-boondocking" all of the time even when we have electrical connections at a campsite.  (We aspire to have a 21' CampLite some day.)  Hand wipes are available in larger sizes as a (sort of) substitute for showers.  We have a Weber Q100 gas grill that runs off of disposable propane containers.  It also has an optional flat plate griddle that can be used to prepare/warm up foods.
When we are truly boondocking, we have Ryobi camplight, flashlight, fan, and radio that run off of the same 18 volt lithium rechargeable batteries.  (Its the same system for the Ryobi portable power tools that I have.  I also take a drill with an adapter to power our teardrop trailer stabilizers up and down.)  I charge several batteries before the trip and use or swap out batteries as needed.  The batteries last a long time.
