Awning Upgrade
Started by thudd3r, December 13, 2015, 12:56:57 AM
I have a 2013 8.5 x 18 vrv sport with a dometic manual awning.  I would like to upgrade to a power awning.  i have seen kits in which you simply replace the arms, add the motor on one end, and add the electrical (the awning fabric and tube are reused), but i see LL also offers the power awning as an option.
can i purchase either the complete power awning kit or just the parts required for the upgrade directly from LL?
thanks
kevin
RV dealers who sell aftermarket equipment can order and install a power awning for you. Here is one example and I think Camping World does service/repair work on Camplites. However, awning installation is not brand dependent, so any aftermarket dealer could do it. The power feature does not look like it could be added to an existing manual awning like I have on my 16TBS; not sure about yours.
http://www.campingworld.com/shopping/item/dometic-9100-power-awning/34018d
Here's another one:
http://www.campingworld.com/shopping/item/carefree-travel-r-12-volt-patio-awning-conversion-adjustable-pitch-white/54501
Apparently you'll be left with holes where the manual arms connect to the trailer towards the bottom.   YOu would have to find something to cover/make them look better.
yea i was looking at the carefree versions (and even found better prices on them from dealers other than camping world).   with the carefree travel'r you can even add the LED strip, which would be a nice feature since we camp out in the dark boonies.   i saw that about the holes for the lower mount.  wouldnt bee too difficult to seal the holes and have them welded over or to make a patch.  one thing i need to check on is the location of the frame uprights in that area.  the brackets for the arms need to be mounted to a "substantial" structure per the install instructions (makes sense...i dont think mounting to just the skin would turn out too well) and i am not sure if there are uprights in the area right at the end of the tube where the manual arms are located.  i hope there is based on the fact that LL only builds one version of the wall (for the most part) and they offer the power awning as an option, so the wall will hopefully have the uprights to support it.
looks like the dometic upgrade requires a specific set of grooves in the tube, i just havent pulled mine apart to check yet.  i think all of the never versions have them so they can be used in either application.
[font size="3"]FYI, the OEM manual awning side arms are designed to be removed and stood up vertically like a carport. Therefore, no holes to be filled, only small brackets left near the bottom on each side. No problem.
yea...i had considered just leaving them as well...i am kind of anal though and they would probably end up bugging the crap out of me
thanks everyone for the ideas
christianm
Hi!
Just wanted to check in on the factory side with some of our guys and asked about adding a power awning to your specific unit. They said they really advise against it, because models of your make and year were not made to hold the weight and the strain of a power awning on that wall.
They mentioned that in some newer units there are supports in the wall that can allow for that kind of pull...but unfortunately, that is not the case with the 2013.
Hope this helps, best of luck with your modifications! Please let me know if you have any questions :-)
Christian
thanks for the feedback christian... will definitely have to check out the stud locations.  thanks for looking into it
