Mods to 21RBS
Started by charliem, March 06, 2014, 10:48:45 PM
[font size="3"]Here's a list of mods I've made to my 2014 Camplite 21RBS. I have/will post descriptions and pictures of some in the travel trailer section. I think this just about completes the outfitting project. Now to enjoy the camper  :).[/font]
[font face="arial" size="3"]1.   Covered entire floor with 7/8" interlocking rubber Yoga mats for thermal insulation.
2.   Installed additional 12V outlets beside bed, on TV table, and in dinette.
3.   Mounted satellite radio and cellphone booster antennas on roof. Brought cables in through running lights.
4.   Installed Voyager wireless rear view camera on roof. Brought cable in through running light. Powered from 12V and added switch in bathroom.
5.   Added 5 foot sewer hose carrier mounted lengthwise under left side. Moved 2 foot carrier to right side.
6.   Installed over-door full length mirror on bath door.
7.   Wife installed Command Strip hooks everywhere.
8.   Installed SeeLevel tank monitor system for fresh, gray, black tanks. No probes!
9.   Installed powered tongue jack.
10.   Mounted Swagman dual bike platform rack on rear bumper. That's why I had the bumper beefed up by Livinlite.
11.   Replaced bed reading lights with LED spotlights. Moved original lights to cabinets under sink.
12. Replaced analog mechanical heater thermostat with electronic battery powered illuminated model
13. Replaced shower head with Oxygenics Body Spa
14. Replaced outside storage CH751 key locks with Combi-Locks
15.   For future installation: ordered custom 32"x39" dinette table top and hardware for attaching to wall. Will provide a large steady surface.
What size combi-locks did you use?
[font size="3"][font face="arial"]I used the 1&1/8"  7850R-L model. The 21RBS required 4 total, but the 21RBH may only need 2. Check first. I think you ordered the dark exterior so you may want the black option.
http://www.amazon.com/gp/product/B000W7DBWA/ref=oh_details_o09_s00_i01?ie=UTF8&psc=1
http://www.amazon.com/Combi-Cam-7850R-L-Black-Large-Combinated-Lock/dp/B0048C8TGS/ref=pd_sim_auto_4?ie=UTF8&refRID=07PX8A8WDGA98CMT090Y
Be aware some modifications are necessary. The [/font][/font][font size="3"][font face="arial"]aluminum trim on the door[/font][/font][font size="3"][font face="arial"] interferes with the Combi-Cam dial. Same problem on the RPOD. A little filing on the trim with a Dremel fixes it, but be careful. A little Dremel goes a long way. I used the original SS finger loops, but I had to flatten and reshape them. Not ideal, but they work. Better ones are available from the manufacturer, but they are outrageous in cost and require outrageous shipping since they come from a different supplier. BTW, these are not subject to master microP control  :P.
When you say "filing on the trim with a dremel" are you talking about filing the lock, or filing the trailer? When I installed the locks on my RPod I had to trim the spacer to elevate the lock above the door trim. Is that what you mean?
They may not be subject to microprocessor control... yet :-)
[font size="3"][font face="arial"]I meant filing on the trailer. The aluminum extrusion that runs around the perimeter of the door. It interferes with the edge of the Combi dial. But if you've solved the problem on your RPOD you should be able to do a similar fix on the CL. Same issue.
I'll post some pictures once I install mine. If I remember correctly, last time I took the little toothed washer that came with the combi dial, ground off all the teeth, and then notched the side where the trim was. That washer was thick enough so that the dial could rotate freely above the door trim.
[font size="3"][font face="arial"]Sounds like a better solution. Me? I just grabbed the chainsaw (Dremel) and went at it. Brawn, no brains  :P
I'm sure it works just as well. I just cringe at the thought of taking a grinder to my trailer... It's so permanent :-) what if I change my mind later?
mdp
All of the mods sound great.  I will be using some of your ideas on my new campsite.
[quote source="/post/290/thread" timestamp="1395768504" author="@mdp"]All of the mods sound great.  I will be using some of your ideas on my new campsite.[/quote][font size="3"][font face="arial"]Maye trains of a feather flock together??? :P Modelers and train buffs anyway.
Good luck with your new CL and keep us posted.
Going back to the start...
[quote source="/post/39/thread" timestamp="1394160525" author="@charliem"][font size="3"]Here's a list of mods I've made to my 2014 Camplite 21RBS. I have/will post descriptions and pictures of some in the travel trailer section. I think this just about completes the outfitting project. Now to enjoy the camper  :).[/font]
[font face="arial" size="3"]1.   Covered entire floor with 7/8" interlocking rubber Yoga mats for thermal insulation.[font color="#1b7be8"] Where did you source these ? I bought some at Harbor Freight and they stink like gasoline and benzene all the way to Shanghai.[/font]
7.   Wife installed Command Strip hooks everywhere. [font color="#1b7be8"]Done, or in progress. I don't think this ever ends.[/font]
8.   Installed SeeLevel tank monitor system for fresh, gray, black tanks. No probes![font color="#1b7be8"] I've decided to do this, as soon as I can find a vendor and installer.[/font]
14. Replaced outside storage CH751 key locks with Combi-Locks[font color="#1b7be8"] On my list. I'd like to be able to secure these without having to constantly know "where's the keys ?"[/font]
[/font][/quote]
[font size="3"][font face="arial"]I bought the rubber mats from Rubber Flooring Inc. [/font][/font][font size="3"][font face="arial"]They meet several Gvmt standards for children and I suspect one is for Volatile Organic Compounds (outgassing). [/font][/font][font size="3"][font face="arial"]
http://www.rubberflooringinc.com/interlocking-tile/foam/78-tatami-tile.html
Any decent RV shop should be able to procure and install the SeeLevel sensors. Some thought is necessary for proper placement and operation on the tanks. I can't help much since I don't have a 14DBS. If you decide to go ahead with this I may be able to give you some general cautions.
[quote source="/post/119/thread" timestamp="1394665396" author="@charliem"][font size="3"][font face="arial"]I meant filing on the trailer. The aluminum extrusion that runs around the perimeter of the door. It interferes with the edge of the Combi dial. But if you've solved the problem on your RPOD you should be able to do a similar fix on the CL. Same issue.
[/font][/font][/quote]Here are the pic I promised. The combi-cams come with a funky washer that looks like this:
[attachment id="79" thumbnail="1"]
On the rpod I actually ground the point off, but this time I tried just flattening them with pliers and it worked just as well with less work:
[attachment id="78" thumbnail="1"]
Then you put the washer on the outside between the cam and the door. It acts as a spacer that raises the dial just above the trim. Just reuse the washer from the cheapo cam locks on the inside and you're good to go. Another interesting finding: cam lock manufacturers must hate each other because all the parts are slightly different sizes. The bolts use different threadings, the nut threading is off by like 1 tpi (you can get it about half-way) and the tabs use slightly different sized square openings. So plan on using most of the hardware from the combi-cams (not a problem, just don't mix them up).
[quote source="/post/774/thread" timestamp="1398872904" author="@tinkeringtechie"] Another interesting finding: cam lock manufacturers must hate each other because all the parts are slightly different sizes. The bolts use different threadings, the nut threading is off by like 1 tpi (you can get it about half-way) and the tabs use slightly different sized square openings. So plan on using most of the hardware from the combi-cams (not a problem, just don't mix them up). [/quote][font size="3"][font face="arial"]Been there; discovered that.
[/font][font face="arial"]Good tip on the washers.
mdp
Has anyone used screw anchors (small) to hang items on the walls??  Not sure of what outcome would be.
Thanks
