QS10.0 - loose wall between dinette bench and cabinets
Started by dhs, April 16, 2014, 11:12:52 PM
dhs
Help!
The wall between the dinette bench and cabinets is loose, very loose, and I can't seem to figure out how to secure it.  I assume I need to take off one of the panels covering the wall to access some screws, but I'd prefer to get good information on how to fix this issue before I start "exploring". The bracket holding the wall nearest the external wall appears secure and I don't see any screw holes underneath the trailer.  Any advice is welcomed!
-dhs
dhs
So I decided to explore and what did I find?  Unscrew the wall board from one side, peel it back - it's attached with two sided tape - and I found that the wall was secured to the floor with two small, inadequate screws. I replaced the screws, added a few more along the length for support and put it back together.  The wall is now solid.  Easy squeezy.
-dhs
Good information. I did notice the wall on my 10.0 was a bit loose as well, but not enough for me to worry about it yet. I just assumed the movement was due to the fact that it didn't have much support against the torque. I imagine its only there for a bit of cosmetics since I have the removable benches and I don't think the wall provides any structural support.
