13QBB WDH recommendation?
Started by stewartnp, April 10, 2014, 02:04:34 AM
stewartnp
We are going to be taking delivery of our new 13QBB next week and are interested any advice or recommendation for WDH/Sway hitches for this model. I saw the Andersen hitch is used on some of the bigger models but I haven't seen any discussion for the 13RDB, 13QBB, or 13BHB in particular. I am okay with using the Andersen just don't want to spend $500-$600 if it does not work on our model. My main goal is minimize sway and purchase a system that is easy to use.
Also is there any warranty issues with these devices being used?
[font size="3"][font face="arial"]What are you towing with? That may decide what you need. Livinlite recommends that you do not drill holes in the aluminum frame, but many WDHs and sway controllers attach via clamps. Should be no warranty problems. Beware of dealers: they will lead you astray from lack of knowledge or $$ envy.
stewartnp
It is a 2013 Jeep Wrangler Unlimited Sport: Max Tongue weight 350lbs, Max Tow weight 3500lbs, GCWR 8,257lbs
[font size="3"][font face="arial"]Looks like you're going to be well set up. The 13QBB is a good match for the Jeep.
Now beware. The two most controversial subjects on RV forums are WDH/sway and tires. You've hit one  :)  For full disclosure, I am a big advocate for WDH/sway on any short wheelbase small TV. Some will argue that you don't need them, but I'm convinced you'll want them for safety and comfort. The WDH, in addition to its safety contribution, will greatly increase your ride comfort by reducing bouncing and "porpoising". The WDH transfers tongue weight to the TV front axle and the trailer axle. The effect is to simulate a longer wheelbase rig, thereby better dealing with road bumps and dips. My previous rig (Honda Pilot 4X4 and RPOD 172) was similar in weight/size to your rig and I installed the Fastway E2 WDH. Great improvement! I still use the E2 on my present rig.
I like the E2 which provides WD and sway control and installs with no drilling. Djsamuels, on this form, is an Andersen user and may jump in with his experience. Over to you, Doug.
stewartnp
I was just looking at the E2. The price is definitely better than the Andersen. Are you using the round bar or trunnion? Also the dry tongue weight is 170lbs and the minimum they show for the E2 is 600lbs, am I too light or does it not matter.
[font size="3"][font face="arial"]The E2 is definitely cheaper. It's very popular on small TT forums. The only knock against the E2 is some noise when turning. I like it. It lets me know it's working!
I have the round bar style. The trunnion version provides more ground clearance under the hitch, but costs more. The  #600 rating is a maximum, not minimum. The 600/6000 model will work perfectly for you and provide some growth potential. By the time you fill the propane tank, add a battery or two, and a bunch of "stuff" you'll be at 250-350 pounds.
stewartnp
Thanks charliem. I am so happy this forum came about when it did. Thought I would add what rkazimer said from the Yahoo group:
I have a 13BHB that I tow with a Chrysler town and country minivan.  You don't need a WDH for this camper.  We just got back from a trip with the camper and the mini van loaded down and we drove over the mountains between TN and NC on one of the curviest and hilliest roads you can find (tail of the dragon 318 curves in 11 miles).  The rig pulls fine I can't imagine needing a WDH unless you have it overloaded or improperly loaded which you should not do anyway.  I was worried about a needing a WDH also before I got my rig based on the things I had read online but someone told me I didn't need it and to try it out first and they were right it is totally not necessary.
Good Luck!
Andy at CanAm recommended EAZLift Elite W/D and the Husky sway control for my Ford Flex towing a 21BHS.
As an aside, with the Husky clamp-on ball (optional) no holes had to be drilled for the hitch or the sway control. Several holes for self-tapping screws had been drilled already for the propane tank mount and the battery mount, and I had to drill a couple more when I swapped their locations.
[font size="3"][font face="arial"]As I said, lots of controversy and opinions surrounding this subject. And there's a difference between need and want. Need is an undefined term based on lack of industry standards and want is difficult to describe until you try one. You could try it without the WDH/sway and see how you like it. The problem with that is people will tell you sway control only helps you when you really needed it. Then it's too late. Check out the discussion of WDH/SC on the Rpod-owners forum. The Rpods are similar to the smaller Camplites in size and weight.
BTW, the simple sway controls are well south of $100. Seems like good insurance, even if you only keep it lightly tightened down most of the time.
I like to think of it this way:
Sway control should NOT be used to control sway under normal conditions (stay with me for a second...). If your trailer is swaying during normal diving, there's a much larger issue that needs to be addressed (weight distribution, trailer angle, etc...). Adding sway control to a trailer that sways only masks the problem. Sway control is more like a horizontal stiffener. Even if the trailer isn't "swaying", sometimes gusts of wind or trucks will make the rear end of your vehicle wiggle side to side (like a fish swimming). It's unnerving. Adding sway control makes the vehicle and trailer feel like one long vehicle. It's more comfortable and safer.
Weight distribution is like a vertical stiffener. It uses tension to transfer some of the trailer weight to the front wheels of your vehicle. As Charlie mentioned it will also increase ride comfort. If you don't use a WDH, every bit of weight you add behind the rear axle will actually reduce the amount of weight on the front wheels. Less weight on the front wheels = less steering traction.
Using 600lb spring bars with a lighter trailer should be fine, but make sure not to use too much spring tension. If you reduce the weight on the rear wheels too much it will put you at risk for jackknifing. Take careful measurements when you set it up to make sure the front and rear axles are loaded properly.
stewartnp
Thank you everyone for your responses. I have pretty much decided WDH/SC is something I want. My concern now is tongue weight. I have yet to find an accurate 'real world' weight for this trailer but 300lbs seems to be the best number I can find for tongue weight. So if I add a 100lb WDH like the e2 I will be over my max tongue of 350lbs. Any ideas? Should I go back to looking at the Andersen(60lbs) or even Blue Ox(68lbs)? Even with those I will be over my limit... This is harder than I thought it would be.
stewartnp
Oh I forgot to mention the Blue Ox has 350lb and 550lb bars available. I was thinking the 350lb bar might be easier on the frame.
That's the trouble with most of these hitches. They help distribute, but also add a significant amount of weight.
stewartnp
Okay I have spent more time than I care to mention on this little problem but now it looks like a WDH will not even work. If you look at this picture the top of the frame is covered in wires. So a clamp on WDH is out and a bolt is out because of the aluminum frame.
[attachment id="45" thumbnail="1"]
