Issues with countertop laminate?
Started by katienoellewis, April 04, 2014, 02:52:54 AM
katienoellewis
We have only had our Axxess for less than a month, and have only taken it out once so far.  The laminate countertop is starting to peel up on the edges.  Has anyone ever had this problem?  What did you do as a perma-fix?  I live in AZ, so heat will be a major issue.  Is this covered under warranty?
gizmokayaker
The edges of my countertop have been delaminated at the corners since I bought the unit.  So far I have not been able to repair it successfully.  Please let me know if you find a fix.
Regards,
katienoellewis
Sounds like the exact same issue.  It was like that upon taking it home from the dealer (didn't notice until we got it home, of course).  It started in one corner of the upper edge/lip, but we're noticing it other places now.  Have you tried silicon or any types of glue?  We're a little nervous to try a "home remedy" in case it ruins it!
tommyc
If you bought it new contact the selling dealer. If they arent any help get ahold of LL and im sure it will be taken care of. Dont mess do anything yourself before talking to them.
gizmokayaker
I have the same issue in my 13bhb I am guessing the material is the same.
Same with the 21BHS, although when cooler, I can get the laminate to stick.
katienoellewis
Update:  Having this issue since we purchased in 2014.  FINALLY getting Livin Lite to remake the countertops using the new material they are now putting in their units.  5-6 weeks to get them made... Let's see how this goes!
