Campground bathroom or camper bathroom?
Started by leslie, December 13, 2014, 12:52:16 AM
Quote from: @pinstriper" source="/post/6786/thread" timestamp="1423965975Well, hot water supply is a problem, but it's only ONE problem.
Where's all that water going to go ? My (limited) understanding of full-service hookups is that you still don't leave the dumps open full time. You just treat it like an onsite dump station and dump as frequently as needed. But the valves stay closed when not actively dumping.
Otherwise you get sewer gasses coming up into your tanks, no ? And yeah, the sinks and probably shower have p-traps, but the toilet doesn't.
[font size="3"]Many campers leave the gray tank valve open when connected to a full hookup site. I don't because I've had some problems with sewer gas backing up, but there are fixes. Theoretically this shouldn't happen, but I suspect the vacuum breakers under the sinks are not perfect. One remedy is to form a dip in the sewer hose between camper and sewer connection. This can easily be done if you use the accordion style hose support thingies.
The other reason not to leave the valve open is to accumulate soapy gray water to flush the hose after dumping the black tank. I'm far more apt to forget to close the gray valve ahead of time than to remember to turn on the WH. That I'll know immediately  :-[. Even with multiple showers a day it's not too hard to dump the gray tank occasionally.
As for the Truma tankless WH, there are all sorts of reasons not to use such devices. Despite what Truma advertises, they are flow limited. Not min flow, but max flow and nothing to do with campground water systems. Most such heaters run about 0.25 gal/min which, even when mixed with cold water for the shower, is pretty puny. Shower heads run around 2- gal/min. Simple physics limits the number of gallons you can heat per minute, especially when that water starts out at 50F (Yes, enough propane can overcome anything). Another advantage of the storage tank heater is they are recovering while the water is turned off or very low. Not so for tankless.  Most ads also mention not remembering to turn on the conventional heater or having to wait. Well, I'm not so old that I can't remember or plan ahead 15 minutes for a shower. I measured the recovery time of my WH at 20 min for gas only and 14 min for gas plus electric. That was for a full cold start with 77F water heated to 131F. YMMV.
The claim that tankless doesn't waste energy? Today's WH are well enough insulated that they lose very little through the walls and even that lost heat helps heat trailer in the winter. When hooked up to electric we seldom use the propane side of our WH, but that option isn't available for tankless.  Go feel all that wasted energy blowing out the exhaust when it's running, but don't get burned :'(. By this time you may guess I'm not a fan of tankless WHs  :).
Quote from: @funpilot" source="/post/6785/thread" timestamp="1423965546[p]Not sure if I posted my thoughts on showering here before, but my DW says she wants long hot showers when we are at full service sites.  She also will not go to the campground bathrooms if she can avoid it.  So, I have spent months researching whether or not the on demand or instant hot water heaters would really work.  I had discounted all the ones now on the market when I came across a new to the US instant hot water heater from Truma (Germany).  There is quite a write-up on it in the March 2015 issue of MotorHome magazine including how to install it (they said it only took them two hours to do it). [/p][p]
[/p][p]The issue with these water heaters is that they do not work properly if there is not the proper water flow.  That can happen in any camp ground and so you experience the water going cold way too often.  Truma claims that that does not happen with theirs.  I had a chance to have an extended talk with one of the people that was lucky enough to be a tester of the product and says it works perfectly for him.  I am in the process of buying one but want Truma to install it as they are still building their dealer network. Thus, I cannot provide any personal experience yet.  [/p][p]
[/p][p][a href="https://www.youtube.com/watch?v=OUjoK0WgsGQ"]https://www.youtube.com/watch?v=OUjoK0WgsGQ[/a][/p][p]
[/p][p][a href="http://www.truma.net/us/en/water-systems/aquago.php"]http://www.truma.net/us/en/water-systems/aquago.php[/a][/p][p]
Ah, funpilot is a good husband to do all this research to make his wife comfortable. I also like long hot showers, which is just one of the reasons I cannot go full-time RVing. Even if I use the campground facilities, I take a quick shower. I am not really comfortable using public facilities.
I would be very interested in hearing first-hand experiences with these on-demand water heaters in RVs.
My family bought me a "portable" tankless water heater for Christmas. Along with of all things a portable dishwasher.  The dishwasher is heavy and rather large.  I could setup both on the truck bed.  They bought the dishwasher because of me complaining about how much I hate doing dishes.   I havent tried either yet.   I can see using the tankless heater with the outdoor shower.
grantnpeg
For campsite toilets, we buy economy bbwipes and add rubbing alcohol to the pouch.
Also kills poison ivy oil on skin, clothes and dog. Hubby allergic< big time!
I have tried, but I cannot wash my hair in the Camplite's shower. I have a lot of long hair, and I don't have enough hot water to wash out all the suds. I also hate showering in a cold bathhouse. So, I guess it's going to be - chop, chop...
grantnpeg
[quote timestamp="1419002262" author="@leslie" source="/post/5601/thread"]Sean, in another life I was an environmental consultant. Testing public bathrooms for bacterial contamination was something I got involved in. Surprise - women's bathrooms had higher bacterial counts than the men's bathrooms. Results are results. Someone in the office thought it might be due to more children using the women's bathrooms with their mothers indstead of using the men's bathrooms with their fathers.
I started this thread because I was interested in what the rest of you thought. My husband prefers to walk through the campground to enjoy a leisurely shower instead of a fast shower in our own clean bathroom. I am scratching my head????[/quote][font size="4"]As a housekeeper in a Veteran's Home (State- not Fed, Thank you, God)., I also clean
public restrooms.
Men lift the seat if they aren't going to sit.  Women hang over and pee on the seat!
Men don't wash their hands as often.  Soap and paper towels last much longer in men's
room.
Men don't scratch "BoBo luvs Poopsy" in the stall walls, and they don't write on the
mirror w/ lipstick!
Men don't string t-paper all over seat and leave it on the floor.
Men don't leave "fem" pads stuck on the stall walls.
I don't know... are women the ones that "always" clean the bath, and they are afraid
to touch anything?
By the way, Have you ever looked at the filth on the doors of both?  Light switch?
Just don't touch you face til ya get to the hand san.  I carry in pocket.
peg
QuoteMen don't wash their hands as often.  Soap and paper towels last much longer in men's
room.
[p]
Boys are taught at an early age not to piss on their fingers. At least in Catholic school. I dunno about the publics.[/p][p]
What a revolting turn this discussion has taken!  LOL! LOL! Some females do not give a fig about anybody else coming in to use the restroom after them. Why I prefer my little bathroom in my camper. If my husband is at all typical of men, then I believe that soap and towels last longer in men's rooms. I am always after him to wash his hands. I keep chlorox wipes in the Jeep and we use them a lot,!
chuck893
[quote source="/post/13986/thread" timestamp="1438776343" author="@leslie"]What a revolting turn this discussion has taken!  LOL! LOL! Some females do not give a fig about anybody else coming in to use the restroom after them. Why I prefer my little bathroom in my camper. If my husband is at all typical of men, then I believe that soap and towels last longer in men's rooms. I am always after him to wash his hands. I keep chlorox wipes in the Jeep and we use them a lot,![/quote]We use the camp bathrooms for the simple reason that we camp in an 8.1 so there's no choice. I just re-read all the posts (What a revoltin' turn this discussion...  (rofl) ). We mostly camp to tour (as opposed to camping to camp) so we somewhat shamefacedly admit to using KOA a lot. My understanding is that KOA's are independently owned, but policed by KOA corporate. If a camp does not measure up they can be booted out of the system. Staying in requires particular attention to washrooms! Still, they vary, especially on weekends when it's hard for staff to stay on top. My personal experience is that the men's rooms are usually pretty good, but my wife says there are times when the women's is terrible, and she blames women! I suspect there is a tendency on the part of some people in general to be slobs on the principle that they don't have to clean it up.  :P It's sometimes a thundering nuisance (especially when it's thundering) but what can ya do?
When we are touring I make reservations ahead, usually online, and because we are (um) older I ask to be close to the washrooms, and they almost always can accommodate. I honestly don't usually take pictures of washrooms, but here's a couple of KOA standouts:
Iconic teepee style KOA office ==>[a href="https://flic.kr/p/fxFyLN"]
And THIS one ^ is a standout!
[quote source="/post/13975/thread" timestamp="1438743350" author="@pinstriper"]
room.
[p]
[/p][/quote]Men figure out how to pee without even touching it. Why do you think we wear sweat pants all the time. Commado ????
I just enjoy dropping one straight down the hole...nuthin' but net...while kicking down the pedal on the terlit with my left foot perfectly timed. Swish! If you get it wrong it's like a Playdough Fun Factory chopping it in half though.
[quote source="/post/14006/thread" author="@whoofit" timestamp="1438808689"]I just enjoy dropping one straight down the hole...nuthin' but net...while kicking down the pedal on the terlit with my left foot perfectly timed. Swish! If you get it wrong it's like a Playdough Fun Factory chopping it in half though.[/quote]Wow!  This has REALLY taken a turn now. I LOVE the playdough analogy!  :D (rofl) :o
[quote source="/post/14016/thread" author="@djsamuel" timestamp="1438829216"]
Quote from: @whoofit" source="/post/14006/thread" timestamp="1438808689
Wow!  This has REALLY taken a turn now. I LOVE the playdough analogy!  :D (rofl) :o[/quote][p]Yes, when the black tank is empty you do get a satisfying Thud as it touches down on the tank bottom. At that point you know you are good.[/p][p]
[/p][p]I learned early on that some poops will just bridge the hole. You have two choices, munch through the poop with multiple PacMan actions of the pedal or get a stick and poke it down.[/p][p]
[/p][p]The first one wastes water and fills the tank too quickly, makes a mess of the thing, and gets the seal all chunky. Then it takes a real man with great aim and velocity to clear the chunks.[/p][p]
[/p][p]The second one makes me scold my dog to not chase the stick I just sent flying into the woods.... "NO! No Fetch!"... (rofl) Yep, good times all around... Makes me feel like an angry monkey flinging its poo.[/p][p]
[/p][p]I know I am supposed to pre fill the bowl with lots of water but we only have a 14 gallon black tank and if we did that the capacity would be somewhere around eight hours...lol
Quote from: @whoofit" source="/post/14019/thread" timestamp="1438857135[p]I know I am supposed to pre fill the bowl with lots of water but we only have a 14 gallon black tank and if we did that the capacity would be somewhere around eight hours...lol
[font size="3"]I believe your black tank is 28 gallons, so you're good for 16 hours [/font]  ;)
[quote timestamp="1438860518" source="/post/14020/thread" author="@charliem"][quote timestamp="1438857135" author="@whoofit" source="/post/14019/thread"][p]I know I am supposed to pre fill the bowl with lots of water but we only have a 14 gallon black tank and if we did that the capacity would be somewhere around eight hours...lol
[/p][/quote][font size="3"]I believe your black tank is 28 gallons, so you're good for 16 hours [/font]  ;)
[/quote]No the 2013's have a 14 gallon black tank, Charlie. Just bigger than a bread box unfortunately.
