2015 14DBS
Started by funpilot, August 12, 2014, 04:50:33 PM
funpilot
Have you reached out to the factory directly on this unit?  At least in the sales/build cycle (which I am still in), I have found them very responsive. I almost wonder if this unit was damaged in transit from the factory to you as the gaps/windows not level, and the other issues you raise might point to that.  Much more knowledgeable forum participants than me may likely post their observations but I would not be happy at all if that was my experience. Based on what you have posted they all look like warranty repairs anyway.
djsamuel
I hope you are able to get this fixed to your satisfaction.  We've been using our 21BHS for about 11 months now, and after some issues, it is a very reliable camper.  I had some leaks due to poor caulking between the roof trim and the awning strip.  I recaulked with Proflex RV, and that problem hasn't returned.  I don't trust the tires, and in fact had one replaced under warranty due to a sidewall blemish that turned into a crack.
As far as the slideout leaks, was it raining when you pulled in the slideout?  We had some water on the floor near our slideout after driving through the rain, but I had the slideout extended in the rain while loading the trailer.  No leaking since then, but I supposed it is possible for some water the be forced through while driving if the slideout is not adjusted properly.
Once sorted out, they are good trailers, very solid.  In addition, in the event of leaks, the amount of damage that can be done is far less than other brands of trailers.
BEst of luck.
Doug
Camplite 21BHS / Ram 1500
Central Florida
funpilot
[quote source="/post/2491/thread" timestamp="1407890758" author="Keith Kulm"][div][/div][font face="times new roman"]When you pay 3 times retail for a Camp Lite vs. a common travel trailer, you don't expect leaks!  And, the issues we have seen (windows installed off level) are definitely factor quality issues.  I have not contacted the factory direct; leaving that up to the selling dealer.  Oh, additionally, the simulated wood trim around the slide out simply fell off after some humidity.  It is apparently held on with poorly applied glue and double backed tape.  As are the seat cushions, which didn't stay intact for even a day!  I too, was impressed with the construction of the vehicle; but the proof of quality did not show in actual performance![/font][/quote]The trim issue is discussed in another thread. The poster said he preferred leaving it off.  He is going to cover the black metal that is there with post cards of where he camps....
[quote source="/post/2495/thread" timestamp="1407892807" author="@funpilot"][quote source="/post/2491/thread" timestamp="1407890758" author="Keith Kulm"][div][/div][div][/div][font face="times new roman"]When you pay 3 times retail for a Camp Lite vs. a common travel trailer, you don't expect leaks!  And, the issues we have seen (windows installed off level) are definitely factor quality issues.  I have not contacted the factory direct; leaving that up to the selling dealer.  Oh, additionally, the simulated wood trim around the slide out simply fell off after some humidity.  It is apparently held on with poorly applied glue and double backed tape.  As are the seat cushions, which didn't stay intact for even a day!  I too, was impressed with the construction of the vehicle; but the proof of quality did not show in actual performance![/font][/quote]The trim issue is discussed in another thread. The poster said he preferred leaving it off.  He is going to cover the black metal that is there with post cards of where he camps....
[/quote][p]Well, yeah. But that's kinda beside the point. OP has a litany of minor quality issues that aren't all that hard for the factory to get right. Clear sign to me of a rushed production line that places more importance on throughput than quality. [/p][p]
[/p][p]Mind you, I thing these are all easily addressed and shouldn't be over-reacted to.[/p][p]
[/p][p]For my part, I would say frustration is warranted, but not cause for any serious buyer's remorse.[/p][p]
[/p][p]We rented an R-Pod, less than 6 months old. Yeah, rental unit and all that, but the interior was particle board and every. single. screw. had pulled out.[/p][p]
djsamuel
The biggest item in that list is the installation of the windows and the door.  The leaking and the fact that they were not installed correctly really indicate a quality problem.  I haven't seen anybody complaining about something like this, which is a concern because that means it made it through being inspected.  That should have been caught prior to leaving the factory.
Central Florida
nmken
I'm in the early stages of getting a customized unit as well.  Thanks much for letting us all know - when we go through our inspection we will certainly be looking closely at the items you called out.  Any chance you can get some photos of the gaps and offlevel and other issues posted here for us?  Definitely reach out to the factory and let us know how it goes
Quote from: Keith Kulm" source="/post/2552/thread" timestamp="1407945697I did find at least one picture taken shortly after we bought it, which may show how the windows are off level.  Not sure how to post it here.
As a guest it wont allow you to directly post a picture. You can create a member account to post directly, or post a link to an external host service like flickr, facebook, etc.
funpilot
LOL....I do not think that is the case.  Sean will most likely reach out to you to help resolve this.
If you want to send me your details to livinliteforum@gmail.com along with a screenshot of the error its giving I'll be happy to see what I can do.
kettebacam9
I got my registration issue cleared up.  I am now idahover.
kettebacam9
[quote source="/post/2581/thread" timestamp="1407963406" author="@idahover"]I got my registration issue cleared up.  I am now idahover.[/quote]I tried to add a photo, but the attachment limit is 1 MB.  I doubt if any photo is that small.
[quote source="/post/2584/thread" timestamp="1407964246" author="@idahover"][quote source="/post/2581/thread" timestamp="1407963406" author="@idahover"]I got my registration issue cleared up.  I am now idahover.[/quote]I tried to add a photo, but the attachment limit is 1 MB.  I doubt if any photo is that small.[/quote][font size="3"]Large photos can be scaled using MS Paint or equivalent applications. Very good photos at 640x480 pixels can be uploaded. The size will be less than 250MB. [/font]
hdrehder
We picked up our special order 14DBS in mid June and have taken two weekend trips since.  No leakage.  Had to replace the front door lock set; there is one screw that sticks when opening/closing the left most kitchen cabinet and the laminate on the door is bubbling some.  Nothing like what idahover describes. I have my fingers crossed for nothing big to crop up.
kettebacam9
We just heard from our dealer (Access RV) who said that the Livinlite factory has denied our claim to rectify the windows being installed off level.  This makes no sense to me; since, if we would have noted them when we picked it up at the dealer, and before we wrote them the check, it would have been fixed or replaced!  What has changed; they have the money in the bank?
fasteddieb
I post my photos to Flickr via iPhoto, then choose a browser-friendly size to link to.
I'd like to see a photo of your windows.
If you can't make it work, email me a copy and I'll try to post it to this thread. fasteddieb@mac.com
Mineral Bluff, GA
2014 CampLite 21BHS
2011 Ford Flex EcoBoost
