Stabilizer Jacks
Started by idlerockfarm, June 08, 2016, 11:21:11 PM
To be clear I was not saying to use just any old spot under the axle. I am not always as talented as Charlie but I did mention using the location where the axle is mounted. I knew I could count on you guys to more accurately describe the concept :) While we are on the topic we should note that while the concepts are the same no matter what, they become more important with the added weight. Something like a QuickSilver where its weight is around 1000 pounds will not have the same impact as a 21 foot CampLite.
[quote timestamp="1467292552" author="@admin" source="/post/22684/thread"]To be clear I was not saying to use just any old spot under the axle. I am not always as talented as Charlie but I did mention using the location where the axle is mounted. I knew I could count on you guys to more accurately describe the concept :) While we are on the topic we should note that while the concepts are the same no matter what, they become more important with the added weight. Something like a QuickSilver where its weight is around 1000 pounds will not have the same impact as a 21 foot CampLite.[/quote]Yes, very much more likely to get away with it, a caveat to my original response. Which I only made so someone else doesn't come along and mistake it for something to do with the heavier trailers.
