How to use the black tank flusher
Started by leslie, January 07, 2016, 01:27:09 PM
tt2retire
Would anyone recommend using a water pressure regulator when using the black tank flush?
[quote timestamp="1456215075" source="/post/18927/thread" author="@tt2retire"]Would anyone recommend using a water pressure regulator when using the black tank flush?[/quote][font size="3"]Not required with reasonable water pressure. The black tank flusher is just a check valve, vent, and hose end. Nothing to stop the flow so no significant pressure will build up. That said, I did read someone had 120+ psi pressure somewhere  :o . That might split the feed hose![/font]
