2 5/16 hitch
Started by popup2012, January 20, 2016, 12:25:34 PM
If I had to guess I'd say they are just standardizing product across the lines to make supply management easier.  It may have nothing to do with anything else.
[quote source="/post/17931/thread" timestamp="1453417592" author="@mitch"]If I had to guess I'd say they are just standardizing product across the lines to make supply management easier.  It may have nothing to do with anything else.[/quote][font size="3"]You may be right, but I'm still skeptical. The only other model to use the 2500# axle is the 11FK. Both 14s and the 16TBS use 4400s and I suspect the 16DBS will too when it goes to a single axle. That leaves the two 21s with dual axles. If aggie79 is correct that there is no cost difference between 2500 and 3500 axles then why not standardize on 3500 for all 21s and the 11FK? That's better than degrading the 21s from two 3500s to a pair of 2500s.  I guess time will reveal all.....Maybe. [/font]
