Replacement parts?
Started by jammydee, August 06, 2016, 07:08:11 PM
jammydee
Just bought our 10.0 and towed it home. When we set it up the first time, the table appears to be warped and wobbly on the inside and the outside table has proven impossible for us to slide onto the rail. Any ideas on a table we can buy to fit the dinette since the one provided appears to not have even survived shipping from the factory without warping?
We were so excited and now we're just frustrated. Thanks for any help you all can provide.
James and Julia
Not your problem. The dealer's problem. Take it back to them and have them deal with the warranty claim.
mjmoore17
I needed a good dosing of WD40 to loosen up my outside table. Now works well. Inside tables have been disappointing.
The table is definitely light weight but it shouldn't be warped. It should be replaced under warranty. However it's not a bad idea to replace it. We found this one is a direct replacement http://amzn.to/2aDZ7K4
It is a bit thicker so it makes the dinette bed less usable but that didn't bother us since we never used it as a bed.
jammydee
Thanks Sean. That looks great! As for the dealer they're 4 hours away so not really ideal.
tom0001
I do not slide the outside table onto the rail. I put the top portion on first and then swing it down over the lower lip. I have never had the table come off the rail doing it this way. I too tried sliding it on when I first received mine and struggled to get it on. Has anyone ever talked to LL to see what the proper way is? Try it and let me know what you think.
Where's the nearest Camping World ? I thought they became authorized warranty centers with the Thor deal. Worth checking out.
ajreaper
The inside table, IMO is pretty worthless.  Whether used as a table or to convert the dining set up into a bed.  I removed mine and replaced it with 1/2 inch pine plywood piece cut to fit and use the area strictly as a bed.  The outside table slides on with difficulty even with a fair amount of WD40 but it does go on.
