removing dinette
Started by janivogell, August 18, 2015, 11:29:16 AM
janivogell
From what I  understand the table is built in in the 14 model and the off road models. Would there be a way to remove it ( cut it out) with damaging the rest of the unit?
[font size="3"]Looking at the LL pictures it appears the table is supported by two standard table support tubes inserted in flush mount floor fittings. If so you can just pull up on the tubes and remove them. The flush mount floor fittings will remain but shouldn't be a problem. They could even be covered by a throw rug if desired.
