New 2014 Camplite 21BHS
Started by tinkeringtechie, April 19, 2014, 02:03:32 AM
[font size="3"][font face="arial"]You're correct. My unit has two 15 Amp half breakers in the rightmost slot, one for the converter and one for the WH. You could use the unused MW breaker, but it's probably already wired to the outlet. Replace the wide breaker and rewire. You'll have to figure out the mounting for the on/off toggle if you want it. I don't know where LL mounts it on the BHS. It's not absolutely necessary and lots of lower end trailers rely on the outside switch built into the WH and the breaker inside. However, the inside lighted toggle is sure convenient. Lots easier to check before you plug in an empty WH.
