Air Conditioner removal
Started by sandyu, September 02, 2015, 12:50:43 PM
Yes, the first time is the hardest. The have it glued down. Just go slow, maybe heat applied to top might help. I didn't use heat though.
First I got scared too, however if you play with it you can safely take it off.
Just curious, mine is a 2013. 2013 models they installed the AC wrong.
My ac is completely inside the camper, nothing sticks out. Because of this it can't breath from the sides and top. I fixed the situation by cutting the floor under the AC to let the air in. I use my ac a lot.
maryannebill
Mine slides out on two drawer slides. Simple enough system. Only two screws anchor it to the slides. I added some cut up pool noodles to help seal the gaps when the unit is deployed.  I'll post a couple of photos if you'd like.
maryannebill
Will get them on later today.
maryannebill
A/C door closed                   Door open and pool noodles   A/C unit slid out                 A/C unit removed
                                          stored for sealing
