Andersen WDH on a CL21BHS how to install
Started by cl21bhs, May 13, 2014, 11:23:12 PM
Thanks for the well thought out discussion. It really helped me process how a wdh works. Good job.
I went with the Andersen for sway control and bounce control. I don't need weight distribution since I'm way under any limits of the TV and there's very little droop in the rear when hitched and loaded up. I'll need to add a couple of chain links to miss the propane tanks, but otherwise it looks like an easy install. Probably be spring before a really good test run, but I'll report back then on the Andersen/16TBS set up.
vrvinmo
[quote source="/post/5021/thread" timestamp="1415808218" author="@epiphysis18"]I went for a short ride the other day....with my Andersen wd hitch hooked up......it made a big difference!  the ride was much smoother.....I had to look back to see if the trailer was still there.....and my bike is in the trailer......mpg is about the same...around 15mpg......very little bounce, no sway, steering much easier.....I'm a fan!  [/quote]Curious, what kind of bike did you haul and what is the payload rating of your Ram from the yellow sticker in the door jam?
