Cabinet latches
Started by stewartnp, April 19, 2014, 04:40:20 AM
stewartnp
Okay we are on the road right now with our new 13QBB and a small issue with a cabinet door latch has arose. The door has latched itself closed with the door slightly cracked. Also the button to open the cabinet will not engage making the door stuck in this position. Any ideas? I'm sure there is a simple solution.
[font size="3"][font face="arial"]Not sure how you can open the door. [/font][/font][font size="3"][font face="arial"] That's a new problem and I can't replicate it. The door has to be fully closed before the unlatching button engages so try pushing on the door and/or the longer section of the button assembly to fully close [/font][/font][font size="3"][font face="arial"]and latch [/font][/font][font size="3"][font face="arial"]the door . Or look[/font][/font][font size="3"][font face="arial"] closely at another latch to see how you might work a card or tool into the crack to open it or engage the button. When you get it open, the latches are fully adjustable for closing/opening force and engagement point. The adjustment is made by tweaking the screw and nut combination on the back (inside) of the latch.
Is anything blocking free movement from behind?  Karen had that issue once - it impeded the movement of the latch arm, which does extend pretty far behind the latch.
stewartnp
Alright first day jitters! Got it fixed. The nut in the picture was unscrewed 2x's as far as the correct position. This is the correct position:
[attachment id="47" thumbnail="1"]
Now only if I can figure out how to keep the windows  propped up with these gas struts!
[quote source="/post/598/thread" timestamp="1397916576" author="@stewartnp"]Alright first day jitters! Got it fixed. The nut in the picture was unscrewed 2x's as far as the correct position. This is the correct position:
Now only if I can figure out how to keep the windows  propped up with these gas struts![/quote]One of mine was reluctant at the PDI, and finally gave up the ghost last weekend:
Don said I could just reassemble it, but I suggested they just send me a new one.
Rest have worked as advertised, so that's the good news!
Now only if I can figure out how to keep the windows  propped up with these gas struts![/quote][p]Ours (window struts) were balky when we were touring the lot (same unit we ended up getting). Salesman has said they hold themselves open, but we couldn't make them work.[/p][p]
[/p][p]Come time to pick up the unit, we asked the tech about it during the PDI. He made a puzzled face, and demonstrated them. They worked fine, haven't had a problem since.[/p][p]
[/p][p]So, operator error. Try opening.....them.....slooooowly....to....juuuuuust....paaaaast...the....cliiiiiiick.....and they'll probably be fine.[/p][p]
The struts on my windows didn't latch the first day we got them home, but over the course of our first camping trip, they started to work better.  Now they are perfect.
stewartnp
Pinstriper nailed it. Slooooowly is the key. Thanks
