Towing and Tow Vehicle => Tow Rigs => Topic started by: bobbie56 on April 19, 2015, 09:47:15 PM
Title: Ford F150 and 21RBS
Post by: bobbie56 on April 19, 2015, 09:47:15 PM
At last, I have the two together for the first time:
(//"%20style=")Let the camping season begin!
Post by: leslie on April 19, 2015, 11:17:14 PM
Good looking rig! Happy camping!
Post by: hogtyd on April 20, 2015, 08:49:44 AM
Congrats on the successful TV & TT introduction!  They look great together.
-Graham
Post by: swbc150 on April 23, 2015, 02:16:29 PM
[p]Nice looking pair you have there.
No WDH I see in your Pic. You are under the 500lb limit for the hitch dry weight for your F150 but once loaded and ready to tow you may want to recheck that hitch weight.
If you don't already have this, look into the "Sherline" Trailer Tongue Scale, one tool you should always have in your tow vehicle.[/p][p]
[/p][p]https://www.sherlinedirect.com/index.cfm?fuseaction=product.display&Product_ID=169&CFID=44582569&CFTOKEN=38069484[/p]
Post by: bobbie56 on April 28, 2015, 09:33:19 AM
[quote source="/post/9830/thread" timestamp="1429809389" author="@swbc150"][p]Nice looking pair you have there.
[/p][p]https://www.sherlinedirect.com/index.cfm?fuseaction=product.display&Product_ID=169&CFID=44582569&CFTOKEN=38069484[/p][/quote]
Did a quick and dirty hitch load this past weekend, came up with around 500 lbs, so I setup the WD that I had (EZ2 round bar 600 lb). I had to move the propane tank back a small amount (about 3-4 inches), and I added the side bolts to strengthen the coupler. Tow tests were like night and day, and I didn't need the torsion I had with the old tow vehicle (was able to back it off 1 notch if you will).
Have to see how it holds up over this season, but looks great so far.
Post by: charliem on April 28, 2015, 10:04:03 AM
[quote source="/post/10080/thread" author="@gibby" timestamp="1430224399"]Did a quick and dirty hitch load this past weekend, came up with around 500 lbs, so I setup the WD that I had (EZ2 round bar 600 lb). I had to move the propane tank back a small amount (about 3-4 inches), and I added the side bolts to strengthen the coupler. Tow tests were like night and day, and I didn't need the torsion I had with the old tow vehicle (was able to back it off 1 notch if you will).
Have to see how it holds up over this season, but looks great so far.[/quote][font size="3"]You're confirming what I and others say, "You may not need it, but you'll want it." And glad you added the side bolts. You're set.
My 600/6000 E2 round bar hitch manual has an exception for less than 800# TW that allows a closer hanger mounting distance. You may have gotten away without moving the tanks. But it's done so Camp On!
Post by: bobbie56 on April 28, 2015, 02:18:04 PM
Quote from: @charliem" timestamp="1430226243" source="/post/10082/thread
Quote from: @gibby" timestamp="1430224399" source="/post/10080/threadDid a quick and dirty hitch load this past weekend, came up with around 500 lbs, so I setup the WD that I had (EZ2 round bar 600 lb). I had to move the propane tank back a small amount (about 3-4 inches), and I added the side bolts to strengthen the coupler. Tow tests were like night and day, and I didn't need the torsion I had with the old tow vehicle (was able to back it off 1 notch if you will).
You have the same bars I have, and I did try it shorter. But since it was reasonably simple to move the tanks back that extra distance (to get the 27"), it reduces the loads, and actually works better as the antisway pads are out near the end of the bars.
I was originally going to do the swap battery / tanks mod, but once I realized I only needed a few inches, I took the easy move. The hard part was using my 19.2 volt drill to drill 2 1/2" holes through the coupler and frame.
Post by: bobbie56 on April 28, 2015, 02:26:07 PM
A picture of the side bolts.
[attachment id="806" thumbnail="1"]
Post by: charliem on April 28, 2015, 02:34:12 PM
Quote from: @gibby" timestamp="1430241967" source="/post/10109/threadA picture of the side bolts.
[font size="3"]Looks good. Did you just drill through the outside wall of the frame and put the nuts inside the frame tubing as I did, or did you drill all the way through the frame members and put the nuts on the inside of the A frame near the jack shaft?. My access to the inside of the A frame is blocked by a welded lower plate for the jack shaft. I've wondered if I could have put nuts inside the A frame if I removed the jack and reached in. Mechanically it's a toss up. Longer through bolts, if grade 8 high strength, would be less susceptible to bending, but they would also subject the aluminum tubing to a collapsing type compression. Probably mox-nix.
Although my 20V two speed DeWalt drill might have done the job, I did resort to the old plug-in 3/8" B&D for the heavy work.
Post by: bobbie56 on April 29, 2015, 11:33:57 AM
[quote source="/post/10110/thread" timestamp="1430242452" author="@charliem"][quote source="/post/10109/thread" timestamp="1430241967" author="@gibby"]A picture of the side bolts.
[/quote][font size="3"]Looks good. Did you just drill through the outside wall of the frame and put the nuts inside the frame tubing as I did, or did you drill all the way through the frame members and put the nuts on the inside of the A frame near the jack shaft?. My access to the inside of the A frame is blocked by a welded lower plate for the jack shaft. I've wondered if I could have put nuts inside the A frame if I removed the jack and reached in. Mechanically it's a toss up. Longer through bolts, if grade 8 high strength, would be less susceptible to bending, but they would also subject the aluminum tubing to a collapsing type compression. Probably mox-nix.
[/font][/quote]It is open tube at the front, so I only needed to drill through the coupler and the outside of the frame. The bolt is only 1" long.
Post by: charliem on April 29, 2015, 11:43:33 AM
[quote source="/post/10126/thread" timestamp="1430318037" author="@gibby"]It is open tube at the front, so I only needed to drill through the coupler and the outside of the frame. The bolt is only 1" long.[/quote][font size="3"]Thanks. That's what I did and so far so good.
Post by: spot1 on April 29, 2015, 03:20:30 PM
Nice looking rig and hitch mod.
Post by: swbc150 on April 29, 2015, 08:24:33 PM
I will be doing the exact same drilling/bolt with my BC16FK.
Post by: charliem on April 29, 2015, 09:21:26 PM
[font size="3"]If there is any appreciable space between the coupler wall and the trailer frame it should be filled with flat washers. There should be no gaps in the stack up and no deformation of the coupler. Use a flat washer and a lock washer under the nuts. I recommend 1/2" grade 8 high strength bolts torqued to 80 ft-lbs. I considered stainless steel, but rejected it due to its lower strength rating.
Post by: swbc150 on April 30, 2015, 02:21:06 AM
Good points charliem, shall do..
Post by: swbc150 on May 01, 2015, 12:01:27 AM
Did the Extra Bolt Today.
