Is it just our trailer, or do all of them come with the audio systems wired up wrong?
Ours has 6 speakers, 4 inside and 2 outside. They are wired such that the only way to have the outside speakers turned off is to set the balance control all the way to the left channel. This means you are only getting half the sound. They should be wired so that the fade control fades inside to outside, not front of the trailer to back of the trailer.
Anybody else noticed this, and if so, have you done anything about it? I pulled the stereo out of its enclosure and took a look at the rats nest of wires behind it, and it looks like a not very fun job figuring out what wires are what back there...
I don't think I even have outside speakers on my 2015 Camplite 21-BHS. Does anybody with a 21-BHS or 21-RBS have outside speakers? Where are they?
Ours are under the awning, up high, one towards the front and one near the back.
dont feel like it is just yours. i dont have external speakers, but a friend did on his '14 vrv and his were wrong as well. they wired his to the front and rear (one to each), so no matter what he did, he couldnt turn them off completely without turning the balance all the way to one side...then he could only have two speakers working inside if he didnt want the outside ones on
didnt take much to rewire them and i think he even used a cheap "a-b" switch from radio shack to control them.
on the vrv the stereo hangs in a plastic holder above the sink. to access the wires you can take off the front of the cabinet above it and then the aluminum sheet that serves as the floor of the cabinet...all the wires come up from the radio into the space under the floor of the cabinet. pretty easy to swap around the connections there. depending on where they made the connections, you may also have to use the keys to pull the stereo out and disconnect the quick disconnect plug. mine were all labelled (luckily since LL uses all grey wire) so it was pretty easy to sway them around. i had to fix mine because they mixed them up so left/right and front/back were opposite what they were supposed to be
[quote source="/post/9219/thread" timestamp="1428859337" author="@thudd3r"]dont feel like it is just yours. i dont have external speakers, but a friend did on his '14 vrv and his were wrong as well. they wired his to the front and rear (one to each), so no matter what he did, he couldnt turn them off completely without turning the balance all the way to one side...then he could only have two speakers working inside if he didnt want the outside ones on
on the vrv the stereo hangs in a plastic holder above the sink. to access the wires you can take off the front of the cabinet above it and then the aluminum sheet that serves as the floor of the cabinet...all the wires come up from the radio into the space under the floor of the cabinet. pretty easy to swap around the connections there. depending on where they made the connections, you may also have to use the keys to pull the stereo out and disconnect the quick disconnect plug. mine were all labelled (luckily since LL uses all grey wire) so it was pretty easy to sway them around. i had to fix mine because they mixed them up so left/right and front/back were opposite what they were supposed to be [/quote]Yeah that is exactly how mine are wired, can only turn off the outside speakers by having the balance such that only two inside speakers work. I need to find the right size torx bit to get the screws out of the little black holder, none of mine quite fit correctly. I did slide the radio out and look inside, but I think in order to have space to work I'll need to completely remove the holder. Thanks!
Our Axx is wired similarly. Turn 'balance' to the left, outside speakers quiet. Balance turned mid-way, all 6 speakers share sound; turn balance to the right, inside speakers quiet. Now, this next part is taken from our Son, who checked the system out in more detail than 'mom and pops'. According to him, a channel (sound) is not lost with any balance control setting. It is raining now (YES....been so dry in FL) and so we can't check it now, but will get back to you soon.
In my opinion, 'mom' here, the stereo is the worst and most unfriendly ever used and have written it off as useless. On the other hand....'sonny boy' says, the stereo is easy...'gosh!' So there you go. Will post findings soon.
Quote from: @leslie" source="/post/9208/thread" timestamp="1428810968I don't think I even have outside speakers on my 2015 Camplite 21-BHS. Does anybody with a 21-BHS or 21-RBS have outside speakers? Where are they?
Looked at pics of 21s and smaller, and it looks like they may not have outside speakers. This serves to further confirm in my mind that the 'toy hauler' crowd is indeed a little bit different than than the traditional trailer crowd...a tad more boisterous, I do believe. P-)
[quote source="/post/9221/thread" author="@billmoore" timestamp="1428863522"][quote timestamp="1428859337" author="@thudd3r" source="/post/9219/thread"][/quote]Yeah that is exactly how mine are wired, can only turn off the outside speakers by having the balance such that only two inside speakers work. I need to find the right size torx bit to get the screws out of the little black holder, none of mine quite fit correctly. I did slide the radio out and look inside, but I think in order to have space to work I'll need to completely remove the holder. Thanks!
[/quote]the screws on a LL camper (at least all of them on mine) are square drive (well, a few a standard phillips). a torx is 5 point and these are 6 or 8 pt (i believe it is 6 pt). a #2 square bit fits perfect. i was scratching my head trying to find a torx that would fit until someone told me the secret
[quote source="/post/9229/thread" timestamp="1428876965" author="@gwbushhog"][quote source="/post/9208/thread" timestamp="1428810968" author="@leslie"]I don't think I even have outside speakers on my 2015 Camplite 21-BHS. Does anybody with a 21-BHS or 21-RBS have outside speakers? Where are they?[/quote]Looked at pics of 21s and smaller, and it looks like they may not have outside speakers. This serves to further confirm in my mind that the 'toy hauler' crowd is indeed a little bit different than than the traditional trailer crowd...a tad more boisterous, I do believe. P-)[/quote]
:D
[quote source="/post/9244/thread" timestamp="1428896388" author="@thudd3r"]the screws on a LL camper (at least all of them on mine) are square drive (well, a few a standard phillips). a torx is 5 point and these are 6 or 8 pt (i believe it is 6 pt). a #2 square bit fits perfect. i was scratching my head trying to find a torx that would fit until someone told me the secret[/quote]Thanks, that is good to know. I thought I was going crazy when none of my torx bits fit!
"Anybody else noticed this, and if so, have you done anything about it? I pulled the stereo out of its enclosure and took a look at the rats nest of wires behind it, and it looks like a not very fun job figuring out what wires are what back there...'
Sure enough, when I pulled that access panel and looked at the "rat's nest" of wires I laughed out loud. Audio wiring done badly, in the classic sense. I'm adding an amp to power my new speaker (4 inside only since I don't have outside speakers). I'm not into that project yet, but it will be "fun" to see if the wire labels are random or accurate.
Fixed the speaker wiring issue today. Thanks for the tip on the #2 square head bit, works great. Just like billmoore, we have 6 speakers in our Axxess, 4 inside,2 outside. After untaping the wiring bundle I checked it against the stereo wiring diagram, and sure enough, it matched the diagram. The problem is how the LL factory identifies the speaker wires. Instead of differentiating between the inside and outside speakers, the factory labeled them Front and Rear - 2 inside and 1 outside front, 2 inside and 1 outside rear.Wound up re-making 2 speaker connections with crimp terminals, now the fronts are inside and the rears outside. the outside speakers are 5 inch, puts out just a little bass, but ok. The insides are 4-inch, and are lacking bass altogether. May upgrade later with a powered subwoofer, but at least now we can use the stereo using the front/rear fader for inside/outside.
Finally got around to rewiring mine today. Much better now, being able to fade from inside to outside without dropping a stereo channel...
