We have a new Axxess Toyhauler Polaris edition that we are getting ready to take out for the first time this weekend. Upon looking over everything, we're a little concerned about the placement of the waste tube..... It is really low to the ground. It seems like it would be hit by any bump/rock we may encounter. Is this the way it looks on all Livin' Lite products? Is this normal for a toyhauler?
[attachment id="37" thumbnail="1"]
Looks about the same on my 13QBB
I was also disappointed with how low my drain fittings were, I loosened all the clamps thinking I could move the pipes up an inch or two, but they wouldn't budge.
I installed some lift kits from Perfect Casita that raised the body an additional 3 inches on my 6x15 vrv toyhauler.
They consist of rectangular tubes (powder coated) along with bolt assys. You simply unbolt the axles, then reinstall the axle with the blocks.
I had to extend the brake wires slightly.
[attachment id="226" thumbnail="1"]before lift kit install, water tank is lower than axle. [attachment id="229" thumbnail="1"] all parts were included, including nuts with tabs welded to keep them
from spinning when tightening them.
