Camplite => Camplite Travel Trailers => Topic started by: solds88 on September 14, 2014, 07:40:43 PM
Title: Walking on the roof
Post by: solds88 on September 14, 2014, 07:40:43 PM
I'm getting ready to install Maxxair vent covers over the existing vents. Can the roof be walked on with tennis shoes without putting dents in the skin or compromising the roof trusses??
Post by: drdave on September 14, 2014, 08:56:35 PM
When I installed mine on the middle vent I put a ladder against the side wrapped in towels.   I moved the ladder back and forth from side to side a couple times trying to avoid actually having to go on the roof but got sick of that quickly.   The roof felt sturdy enough that I crawled around on me knees or sat while I worked...no dents or any signs of weakness while moving around.   Although it's likely strong enough I didn't see the need to fully stand up but tried to keep my wight spread out as much as possible just in case.   your results may vary.  By the way I'm 175 lbs.
Post by: cl21bhs on September 14, 2014, 10:15:25 PM
I have the 21bhs and also installed three MaxxAir vent covers. I walked on the roof to install and I did not have any problem, in fact I walk on the roof to clean it as well.
Post by: pinstriper on September 15, 2014, 12:47:46 AM
A key consideration is not the roof so much as the walker. The lighter you are, the more likely you can get away with it. Heavier folks should perhaps stay off the roof. I dunno what the magic number is. We've got one person at 175# who did it, another at unspecified weight. Perhaps we'll get someone else who dented or collapsed their roof and we can find out that way what the load bearing is.
Post by: hdrehder on September 16, 2014, 11:27:24 PM
I weigh 120. Walked all over my roof last weekend with no trouble while putting on the new ADCO cover. I realize I'm lighter than most of you guys,but didn't sense any trouble at all.
Post by: oleo on September 20, 2014, 02:53:07 PM
When we picked up our 13qbb, we met the dealer at the factory.  We noticed the factory had installed the 13.5 vs the 9.2 a/c we ordered.  They swapped out the a/c right there.  Two guys, approximately 185lbs each stood on the roof to remove and replace it without issue.  Just our experience with our 13qbb.
Post by: solds88 on September 22, 2014, 04:40:54 PM
Guys,
Thanks for the feedback. According to your posts the roof appears to be very sturdy. I'm going to have one of my boys do the work. I was on the ladder looking at the top and there may be a slight problem. The thick gray goop that LL used to seal all the seams is approximately 1/2" to 1" proud of the horizontal surface. Without modification, in my opinion, may create too much of an air gap between the Maxxair vent cover and the roof. My primary concern is that the vent may try to lift at highway speed? Keep in mind that the Maxxair "L" brackets are thin aluminum and not stainless steel as is the rest of the mounting hardware. Any comments or ideas, are my fears unfounded???  James
Post by: drdave on September 22, 2014, 06:16:51 PM
Mine has a similar thick, but white layer of goop on all the seams.   I installed the Camco brand cover (same thing, but different brand as the maxxair) and had no difficulties.   I'm assuming the maxxair hardware is at least as good as my camco brand.    I snugged everything down and afterwards had absolutely no concerns it was going anywhere.   According to the camco directions a gap is normal and desireble to allow for ventillation and moisture to escape.
Post by: mizv on March 10, 2015, 04:15:14 AM
We ordered our 21BHS about a month ago and requested a ladder on the back. The factory came back and said okay, but you can't walk on the roof or it will dent/collapse/explode. (Not sure exactly what they said as it was filtered through the dealer.) Maybe they are just being cautious?
Post by: mitch on March 10, 2015, 08:41:37 AM
[quote source="/post/7626/thread" timestamp="1425971714" author="@mizv"]We ordered our 21BHS about a month ago and requested a ladder on the back. The factory came back and said okay, but you can't walk on the roof or it will dent/collapse/explode. (Not sure exactly what they said as it was filtered through the dealer.) Maybe they are just being cautious?
[/quote]It's the explosion part that'll get you every time.
Post by: jtelles3993 on March 10, 2015, 09:34:40 AM
I installed 2 Maxxair vents yesterday with no issues, the roof felt very sturdy. I moved around on my hands and knees most of the time to keep my 200 lbs spread out.
Post by: jtelles3993 on March 10, 2015, 09:52:05 AM
In regards to the install, the Dicor on mine was applied sufficiently but not over 1/2" thick. The metal brackets on mine were formed with 2 rib channels for strengthening, I couldn't bend them by hand. I may be wrong, but I think the vent assembly will stay put - I say that because by design they are free flowing and shouldn't contain much air, if any?
Post by: charliem on March 10, 2015, 09:54:34 AM
[/quote][font size="3"]Exploding roof? I bet that dealer says you don't need WDH when towing with your VW Beetle.
Post by: charliem on March 10, 2015, 10:12:58 AM
[font size="3"]I would recommend against actually walking on the roof. Although the roof truss structure will support the weight the thin aluminum sheet will bend and deform somewhat and tend to work the seams, particularly around the edges. As prone to leaks as any camper roof is I don't see the need to invite trouble. All necessary work on the roof, with the possible exception of A/C replacement, can be accomplished from an 8' step ladder. I have done roof work on my 21RBS, but limited roof stress by sitting or crawling on all fours. Compare this to putting 200 pounds on one shoe print when walking. Why do you really need to walk on the roof?
Post by: shovelhead on March 10, 2015, 10:49:48 AM
I dont do roof's ... I get dizzy on the first rung of a ladder.  My neighbor installed my MaXAir covers.  The goop did raise the brackets and made a gap about 1/4" above the roofing aluminum material.  The neighbor weighs about 150lb and slide on his butt between the front & rear vents.
Post by: ammobob on March 27, 2015, 09:07:48 AM
Have a 21BHS on order and am qurious why you guys are installing these vent covers? Weather, debris or areodynamics? Or is it to vent while traveling?
Post by: tinkeringtechie on March 27, 2015, 10:11:22 AM
[quote timestamp="1427458068" author="@ammobob" source="/post/8530/thread"]Have a 21BHS on order and am qurious why you guys are installing these vent covers? Weather, debris or areodynamics? Or is it to vent while traveling?[/quote]Usually to open while it's raining or to vent while travelling. It also helps if you accidentally leave a vent open and travel because it can easily damage the vent.
Post by: charliem on March 27, 2015, 10:26:38 AM
[font size="3"]What TinkeringTechie says X2. Also lets you leave the vents open when you leave the trailer for day trips. No worrying about rain.
Post by: ammobob on March 27, 2015, 11:16:49 AM
Thanks. Another good idea.
Post by: solds88 on March 27, 2015, 04:10:28 PM
[p]Ditto for the above. And, the OEM vents are made of very thin plastic and over a period of time the UV will make the plastic brittle. One winter we had an enormous amount of very wet, heavy snow piling up on TT's roof and I couldn't make out the location of the vents. I used a small plastic shovel to clear the roof and accidently hit the vent, not very hard, but hard enough and shattered the entire side of the vent. The Maxx Air vent cover is manufactured of much heavier plastic and is more resilient than the OEM vent cover.[/p]
Post by: swbc150 on May 12, 2015, 06:33:00 PM
I got up on my BC16FK Roof last week as there was no way I could mount the middle Camco Vent Cover. I didn't stand on it, just sat or on my knees and hands. Roof felt very Solid. I weigh 225.
Post by: tincan on May 12, 2015, 09:47:49 PM
205 pounds! Walked on my roof! NO DEFORMATIONS, dents, wrinkles that were not already there.  I wear a size 11 work boot, so maybe 10 square inches of sole.  That makes 20 pounds per square inch when only one foot is on the roof.  It ain't thin and it barley flexes in the middle between trusses.
I would say no jumping, running, etc. but working on your roof is fine.
The roof is OK to walk on, just don't go crazy up there and have 3 people standing right next to each other. NO dance parties or family photo session.
Post by: peislander on May 12, 2015, 10:22:40 PM
[quote source="/post/10731/thread" timestamp="1431478069" author="@tincan"]NO dance parties or family photo session.[/quote]So doing this should probably be avoided? It really can't be good for the camper. This looks like it was at a rv dealership or perhaps the Northwood manufacturing facility. In either case -- people who should know better!
(http://s30.postimg.org/7czdspo4h/Northwood_1.jpg)
Post by: daplumbr on May 12, 2015, 10:56:04 PM
Well that's just plain dumb. Looks like about 30 people so there's  probably well more than 2 tons on that roof. I'd like to see the photo taken right after this shot!
Post by: djsamuel on May 13, 2015, 08:46:10 AM
I've walked on the roof of my 21BHS with no problem.  I weigh about 200 pounds.  Normally though, if I need to get up there, I throw some sheets of plywood up there to distribute the weight.
Post by: djsamuel on May 13, 2015, 08:48:38 AM
[quote source="/post/8547/thread" timestamp="1427483428" author="@james"][p]Ditto for the above. And, the OEM vents are made of very thin plastic and over a period of time the UV will make the plastic brittle. One winter we had an enormous amount of very wet, heavy snow piling up on TT's roof and I couldn't make out the location of the vents. I used a small plastic shovel to clear the roof and accidently hit the vent, not very hard, but hard enough and shattered the entire side of the vent. The Maxx Air vent cover is manufactured of much heavier plastic and is more resilient than the OEM vent cover.[/p][/quote]
The vent covers on my 21BHS all cracked.  I replaced them with the CAMCO replacement covers.  They are MUCH thicker and more durable.
Post by: thudd3r on May 13, 2015, 09:36:45 PM
i just replaced 2 of the fans with fantastik vents.  both of the cover had cracks in the edge where the indentions were.  the 3rd cover i had to replaced after resting my hand on it (during the install of the other 2 vents) at which point it pretty much exploded.  my vrv is a 2013 so i was surprised they were so brittle after just 2 years.  i replaced that 3rd hengs with a smoked hengs replacement.  it seems like a different material but will probably only last 2 or 3 years as well.  at least they are pretty cheap
here is a link to the replacement from hengs  http://www.amazon.com/gp/product/B0027XK7OW/ref=od_aui_detailpages00?ie=UTF8&psc=1
hey dj...what was the camco part number that fit the hengs fan?  thanks
Post by: ammobob on May 13, 2015, 10:17:29 PM
I think it's the 40148 smoke 14"x14" universal vent cover
Post by: swbc150 on May 13, 2015, 11:30:52 PM
[p][attachment id="857" thumbnail="1"]
(http://[URL=http://s774.photobucket.com/user/SWBF750/media/2015%20Livin-Lite%20Bearcat%20BC16FK%20ToyHauler/BC%20Smoke%20Covers_zpshonmk3dd.jpg.html][IMG]http://i774.photobucket.com/albums/yy25/SWBF750/2015%20Livin-Lite%20Bearcat%20BC16FK%20ToyHauler/BC%20Smoke%20Covers_zpshonmk3dd.jpg[/IMG][/URL])
(http://http://images.proboards.com/v5/bbcode/image.png)
Post by: thudd3r on May 14, 2015, 01:20:27 AM
thanks!
