[font size="3"]I have no experience with truck campers, but here's the kit used on Camplite trailers:
[a href="http://www.dwincorp.com/products/66/Hot-Cold-Spray-Port-"]http://www.dwincorp.com/products/66/Hot-Cold-Spray-Port-[/a]
If you have the 6" depth required it should look fine.
A little less fancy as the true shower kit but you can simply add a standard garden hose outlet to the outside of your rig which is then plumbed to your existing system. Then you can use any hose and head you choose. This was part of my thinking when I added a 12v water pump to my 10.0 pop up. Details and video [a href="http://www.livinthelitelife.com/2016/04/how-to-add-an-on-demand-water-pump/"]HERE[/a]. Granted its not a true shower since there is no mixing valve so you are limited to either all hot, or all cold. In my case that wasnt an issue since I dont have a water heater, plus even if I did, I only planned to use it primarily when I needed cold water.
Quote from: @charliem" source="/post/23547/thread" timestamp="1470067457[font size="3"]I have no experience with truck campers, but here's the kit used on Camplite trailers:
I may do one of these.
