Quicksilver => QuickSilver General Q & A => Topic started by: thriftybill on August 29, 2015, 04:29:56 PM
Title: QS A/C: How Much Does It Help?
Post by: thriftybill on August 29, 2015, 04:29:56 PM
I can't imagine an A/C unit trying to cool down a fabric sided popup is going to succeed in hot weather.
What is the experience of owners out there?
How hot did it handle, what were you able to cool down to?
Fabric wall R value has to be close to zilch. Still in hot weather, just cooling it down after dark for sleeping would be a big plus over no A/C. I tent camped at Zion National Park last July. IT was totally miserable.
TIA!
bill
Post by: sandyu on August 29, 2015, 05:03:03 PM
The ac will cool things down and bring the humidity down nicely once the sun goes down. Im very glad I have it in hot and humid areas. For example, on my way back home this July in a Iowa stop it was 95 degrees during the day and the humidity was about as high, the ac cooled and dried the air enough to make things plenty comfortable. Plus, it adds some nice white noise when you have loud neighbors.
When the sun is high in the sky the ac is useless. It's best just to unzip the windows.
Post by: maryannebill on August 29, 2015, 06:10:44 PM
My 6.0 cools down nicely in a typical hot and sticky Ga. summer. Of course, adding pop up gizmos or the homemade equivalent is good for 10-15 degrees cooler in the trailer.
Post by: sandyu on August 29, 2015, 06:46:32 PM
I would love to know does anyone use a gizmo on a 10.0, and does it allow you to keep the camper cool during the day.
Post by: thriftybill on August 29, 2015, 11:03:54 PM
I forgot the white noise benefit. Thats a good plus too.
Post by: maryannebill on August 30, 2015, 11:39:29 AM
Cooler is the key word. With the reflective surface away from the tenting, I've measured  a 15 degree difference between inside and outside temps. My a/c unit was able to bring the interior temp down another 12 degrees, and also cut the humidity. This was with the heavy duty space blankets and spring clips from Home Depot. No more than $50 invested, with an additional benefit of keeping the tenting cleaner. In the cold months I put the orange side out. Small ceramic heater has had no trouble down to single digits. Another addition has been Reflectix insulation cut to fit all of my zip open windows. Available at all the home stores.
Post by: sandyu on August 30, 2015, 03:08:24 PM
[a href="http://www.homedepot.com/p/Grabber-Emergency-All-Weather-Blanket-Blue-8613AWBBL/202829424"]http://www.homedepot.com/p/Grabber-Emergency-All-Weather-Blanket-Blue-8613AWBBL/202829424[/a]
I'm guessing this is the blanket you use.
I use my camper a lot in the Summer months, and it would be nice to be able to find a cool camper sometimes for a nap.  I would say if I kept my camper zipped up in the summer it's 10 to 20 degrees hotter inside than outside.
Post by: walt3 on August 31, 2015, 12:13:00 AM
We put some heavy curtains that the wife made so we can block off the bed ends. It helped a lot. Also we use two fans one down in front of the ac and one on the counter. We kept it around 80 in full sun with outside temps in the upper 90's. My new thing to try is that bubble wrap covered in a foil. Going to cut pieces to fit in the windows of the main area.
Post by: sandyu on August 31, 2015, 09:38:18 AM
Thanks for information. I think I'm going to try the solar blankets  and foil in window option myself when I get time.
Post by: fjrob on September 01, 2015, 11:08:11 AM
I use a small fan near the A/C to help circulate the air and it really makes a difference.  The last time I went camping it was around 98 degrees in the hot TX heat and I felt comfortable with the fan and A/C combo.
Post by: snocrvr on September 01, 2015, 11:15:32 AM
[quote timestamp="1440878583" author="@kybrowns" source="/post/14685/thread"]The ac will cool things down and bring the humidity down nicely once the sun goes down. Im very glad I have it in hot and humid areas. For example, on my way back home this July in a Iowa stop it was 95 degrees during the day and the humidity was about as high, the ac cooled and dried the air enough to make things plenty comfortable. Plus, it adds some nice white noise when you have loud neighbors.
When the sun is high in the sky the ac is useless. It's best just to just unzip the windows. [/quote]I totally agree!
Post by: thriftybill on September 01, 2015, 03:28:49 PM
Took my wife to look at a used QS10. What a bust. First, the AC was not working, it was blowing warm air. It was 80 degrees outside, and at least 85F inside the trailer.....
Post by: sandyu on September 01, 2015, 10:21:35 PM
Maybe you can use the broken AC to your advantage. I've taken mine out several times. Replacing it would not take much work.
Sent you a personal message by the way.
Post by: shake973 on September 12, 2015, 06:29:27 PM
We just bought a popupgizmo and it worked well,  it was not that hard to get on qs 10.
Post by: sandyu on September 12, 2015, 06:56:22 PM
Funny,  I just bought one and it came it in today. How do you attach your bungee cords? Bob had mentioned some people install eyelets. I'm not sure where they put them.
I called them eyelets, but I don't think that's what they are called.
Post by: obadiah on September 12, 2015, 11:28:02 PM
I got creative and clipped them onto random parts of the camper including under the sides to the c-channels on the floors and the bed struts. I was able to just make it work but I could see a couple stainless steel tie down rings working great. Still need to buy a stool... My wife and I aren't small people but it's hard to reach! Recommend two people at least especially if windy.
O
Post by: shake973 on September 13, 2015, 09:29:48 PM
I used regular bungees cords and connected them to the frame. It did not want to drill into the frame. It worked great.  My camper looks like a jiffy pop,  but it works.
Post by: sandyu on September 13, 2015, 10:04:28 PM
Funny
Post by: kinyo on September 23, 2015, 10:35:51 AM
From my experience this summer it helps a lot. Our 10.0 was equiped with a a/c unit from factory.
This summer we have camped 2 weeks in Virginia Beach & Myrtle Beach with very hot temperatures.
At night with all the windows closed it was really confortable. When we were in Virgiia Beach, our camp site was directly in the sun. It was too hot in the tent for the afternoon nap of my girl. But I Myrtle the tent was in the shade and we were able to have au daughter nap in the afternoon.
Personally, I dont know how I could have slept at night without a/c, it was way too hot outside.
Kinyo
Post by: sandyu on September 23, 2015, 10:46:38 AM
Well I just tried on my pop gizmo for the first time. I think it will help a lot. I plan on using some solar blankets on the sun lit sides of the camper. It will get a small test soon in Florida. I will give it a big test this summer out west.
Post by: shake973 on October 02, 2015, 11:50:52 PM
How do I post a picture?
Post by: sandyu on October 02, 2015, 11:53:55 PM
In a couple days I'll try to post some pictures of my setup.
To post pictures I just use a link from google photos.
Post by: riotanga on February 07, 2016, 02:41:38 AM
I was just following this link and never saw any pics of the gizmo things? Anybody?
Post by: sandyu on February 07, 2016, 10:01:55 AM
(http://uploads.tapatalk-cdn.com/20160207/99172b14b6233a73ca333ff08d755105.jpg)
Post by: sandyu on February 07, 2016, 12:45:22 PM
Sorry, better late than never.
