Quicksilver => QuickSilver General Q & A => Topic started by: david on April 24, 2015, 11:49:43 AM
Title: 4 way club to 6 flat blade on TV
Post by: david on April 24, 2015, 11:49:43 AM
With the GVWR of the QS 10 at 1,500 lbs and the curb weight of your Ridgeline being 3 times more, I don't think you need brakes. Just get an adapter from the 6 to the 4 pin plug. Your dealer can fix you up.
Post by: admin on April 24, 2015, 12:08:51 PM
I agree with @david, there should be no real need for brakes. I tow a QS 10.0 with a Honda Pilot with is nearly spec for spec the same as the Ridgeline. The converter from the round 6 pin to 4 pin should be all you need.
Post by: charliem on April 24, 2015, 12:58:09 PM
[font size="3"]It depends on where you plan to travel to or through. Brake requirements vary by state. Your QS10 is rated at 1500# GVWR. Some states require trailer brakes for trailers in this weight range
[a href="http://www.brakebuddy.com/towing-laws"]http://www.brakebuddy.com/towing-laws[/a]
Post by: gnies on April 24, 2015, 02:36:33 PM
[quote source="/post/9881/thread" timestamp="1429894873" author="keeponhiking"][div][/div][quote source="/post/9873/thread" timestamp="1429888131" author="@admin"]I agree with @david, there should be no real need for brakes. I tow a QS 10.0 with a Honda Pilot with is nearly spec for spec the same as the Ridgeline. The converter from the round 6 pin to 4 pin should be all you need.
-Sean[/quote]Thanks for the info.
Does the 4 way flat plug charge the trailer battery while traveling?[/quote]no
Post by: keeponhiking on April 24, 2015, 03:05:39 PM
How does one keep the battery charged on long camping trips?
Post by: admin on April 24, 2015, 03:54:36 PM
The battery will charge when you are plugged into a shore power source. If you plan to stay anywhere there is no power then there are a wide range of other options. Some that are common are:
1. Use a generator to power/charge your camper while setup
2. Solar panels can be used while at camp to recharge the battery. If done right they can even be used while the camper is closed.
3. Use the tow vehicle to charge the battery. This can be done by running a circuit to charge the battery. You could also just use jumper cables to top off the camper battery when needed.
Many options have been discussed around the forum but much of it depends on your end goal and technical skill set.
Post by: keeponhiking on April 24, 2015, 04:01:25 PM
[quote source="/post/9894/thread" timestamp="1429901676" author="@admin"]The battery will charge when you are plugged into a shore power source. If you plan to stay anywhere there is no power then there are a wide range of other options. Some that are common are:
Many options have been discussed around the forum but much of it depends on your end goal and technical skill set.[/quote]Thank you, wanting to keep it simple so a generator is out, never camp with hookups so that is out for me, solar panel sounds interesting, jumper cables sounds like a hassle, I am just looking for a simple camper to get me out of my tent, at 71 I no longer want to sleep on the ground, but still want to camp with only the basics.   The dealer here in Tucson only has a couple of Quicksilver trailers and neither has the larger tires which I want and they both have the air conditioners which I don't need.  Seems the QS are hard to come by.  Thanks again.
Post by: admin on April 24, 2015, 04:03:59 PM
Honestly you could use the QS's without a battery if you wanted. If you dont plan to use the AC unit and you are comfortable with just tent camping then there is very little need for the battery.
I've been perfectly happy without using any of the onboard electronics before.
Post by: keeponhiking on April 24, 2015, 04:08:16 PM
[quote source="/post/9898/thread" timestamp="1429902239" author="@admin"]Honestly you could use the QS's without a battery if you wanted. If you dont plan to use the AC unit and you are comfortable with just tent camping then there is very little need for the battery.
I've been perfectly happy without using any of the onboard electronics before.[/quote]Thank you, I think I would want to use the 12 volt lights and fan, not much then that.  Would a solo panel hook into the battery somehow?
Post by: admin on April 24, 2015, 05:48:52 PM
The simplest option would be to use a a solar panel like this:
http://www.northerntool.com/shop/tools/product_200578630_200578630
To be safe you should have a charge controller as well. Something like this:
http://www.amazon.com/Schumacher-SPC-7A-Solar-Charge-Controller/dp/B00752TRNW/ref=sr_1_13?ie=UTF8&qid=1429908414&sr=8-13&keywords=12v+solar+charge+controller
You might also want an extension cable so you can move the panel around:
http://www.amazon.com/Schumacher-EC-25-Cable-Connector-Extension/dp/B003WDEYPE/ref=pd_sim_auto_2?ie=UTF8&refRID=1KT5AEPNHHZXRCP9AWC7
Post by: david on April 24, 2015, 06:26:43 PM
With only minimal lights and fan usage, you will not consume many amphours per day. Maybe 20 AH which will let you camp for about two days without recharging with a typical Group 27 battery.
How long do you plan to camp in one place at time? How long do you plan to camp before going home where you can hook up to shore power?
If you are only going to camp for a couple of days and then move, you can cut off the flat connector and wire up a round 6 pin with the existing 4 wires for the trailer ant then run a new positive wire to your trailer battery. That will charge the battery while you are driving to your next camping spot. Your dealer can wire this up for you.
Post by: keeponhiking on April 24, 2015, 06:41:50 PM
[quote source="/post/9911/thread" timestamp="1429910803" author="@david"]With only minimal lights and fan usage, you will not consume many amphours per day. Maybe 20 AH which will let you camp for about two days without recharging with a typical Group 27 battery.
David[/quote]Thank you, I could see maybe about 3 nights at one place before moving on, maybe being out for a week or so on a trip, at this time I would probably never be hooked up to shore power.  I could take the battery off the trailer when at home and put it on a charger, I live in a condo so no way to charge it while in the trailer.  I could probably just change out the connector and have a new wire run to the battery, I think this is the way to go, thanks for your help.  Actually the more I think about it maybe I should just take a couple of battery operated fans and a couple of battery led lanterns and don't even have a battery on board.
Post by: pinstriper on April 24, 2015, 07:44:15 PM
[quote source="/post/9898/thread" author="@admin" timestamp="1429902239"]Honestly you could use the QS's without a battery if you wanted. If you dont plan to use the AC unit and you are comfortable with just tent camping then there is very little need for the battery.
I've been perfectly happy without using any of the onboard electronics before.[/quote]Wait....you run your A/C off that battery ? Skeptical.
Post by: pinstriper on April 24, 2015, 08:09:51 PM
 [quote source="/post/9914/thread" author="@keeponhiking" timestamp="1429911710"][quote source="/post/9911/thread" author="@david" timestamp="1429910803"]With only minimal lights and fan usage, you will not consume many amphours per day. Maybe 20 AH which will let you camp for about two days without recharging with a typical Group 27 battery.
David[/quote]Thank you, I could see maybe about 3 nights at one place before moving on, maybe being out for a week or so on a trip, at this time I would probably never be hooked up to shore power.  I could take the battery off the trailer when at home and put it on a charger, I live in a condo so no way to charge it while in the trailer.  I could probably just change out the connector and have a new wire run to the battery, I think this is the way to go, thanks for your help.  Actually the more I think about it maybe I should just take a couple of battery operated fans and a couple of battery led lanterns and don't even have a battery on board.  [/quote][p]In all things battery, ignore David's advice to your own peril. He is our resident expert on batteries and extended dry camping.[/p][p]
[/p][p]I vote for cutting the wires and putting in a 6 wire harness. You'll be set up for the eventual trailer brake upgrade anyway.[/p][p]
[/p][p]Regarding battery operated alternatives...[/p][p]
[/p][p]I have 2 of the [a href="http://www.homedepot.com/p/Ryobi-18-Volt-ONE-Dual-Power-Portable-Fan-Tool-Only-P3320/205022215?N=5yc1vZc298Z1awZ1z0v1k4"]Ryobi One+ fans [/a] that I use for circulating air when painting, and these run about 6-8 hours on one of the [a href="http://www.homedepot.com/p/Ryobi-18-Volt-One-High-Capacity-LITHIUM-Battery-P108/203466938?N=5yc1vZc246Z1aw"]large batteries[/a]. I also have 2 of their [a href="http://www.homedepot.com/p/Ryobi-18-Volt-ONE-LED-Workshop-Light-Tool-Only-P780/202545372"]LED lanterns[/a] and they will likewise run for 8+ hours. I use one of the [a href="http://www.homedepot.com/p/Ryobi-18-Volt-One-Impact-Driver-Tool-Only-P236/100049838?N=5yc1vZc298Z1awZ1z0v1k4"]One+ nut drivers [/a] with a 3/4 socket to raise and lower the stab jacks in seconds. That battery lasts all season. I bring the lanterns along as backup, but not the fans. I guess I would bring one of the fans when dry camping.[/p][p]
[/p][p]You can also bring extra batteries and a charger for these along but you will have to eventually have hookups.[/p][p]
Post by: thudd3r on April 24, 2015, 08:58:32 PM
as for solar panels, cant get much simpler than the deltrans panels.  i run one at camp sites and while my camper sits in the storage lot to keep the batteries topped off.  they come with a quick disconnect to hook to the battery
http://www.amazon.com/Battery-Tender-10-Watt-Built--Controller/dp/B007N7VLWO/ref=sr_1_7?ie=UTF8&qid=1429919775&sr=8-7&keywords=battery+tender+solar+panel
(http://ecx.images-amazon.com/images/I/31k4-hvesWL.jpg)
Post by: charliem on April 24, 2015, 09:17:03 PM
[font size="3"]If you do run a wire to charge your trailer battery, be sure to run a heavy wire. At least #10 AWG, preferably #8 if you can do it. Also be sure to add a [/font][font size="3"]fuse and a [/font][font size="3"]relay, operated by the ignition switch, between the auto battery and the added charge line. This will isolate the two batteries and prevent discharging you starting battery by the trailer when you stop. Really bad form to wake up in the morning with two dead batteries.   >:D
Post by: david on April 24, 2015, 09:31:50 PM
[p]Charlie:[/p][p]
[/p][p]I think every tow vehicle with a factory round 6 pin connector has the relay built in to the vehicle. My last two TVs did: a Ford and a Nissan- 2001 and 2013. I agree, they are essential to keep your TV battery from running down if you leave it connected.[/p][p]
[/p][p]David[/p]
Post by: charliem on April 24, 2015, 09:51:23 PM
[font size="3"]David,
You're right. I guess I misread the posts. The added wire mentioned was on the trailer side after the replaced or adapted 4 pin connector.
Cheers.
Post by: admin on April 25, 2015, 09:14:09 AM
Quote from: @pinstriper" source="/post/9917/thread" timestamp="1429915455[quote source="/post/9898/thread" timestamp="1429902239" author="@admin"]Honestly you could use the QS's without a battery if you wanted. If you dont plan to use the AC unit and you are comfortable with just tent camping then there is very little need for the battery.
Did you forget your glasses pin, or am I just going crazy b/c I dont see where I said anything about running the A/C off battery :)
Post by: pinstriper on April 25, 2015, 09:15:44 PM
That would be this part:
QuoteIf you dont plan to use the AC unit and you are comfortable with just tent camping then there is very little need for the battery.
Having a battery is irrelevant to whether you plan to use the AC unit. You can have a battery, and plan to use the AC. But it won't happen. AC requires a 30amp hookup.
Post by: admin on April 25, 2015, 09:55:38 PM
I see where you got there, but that wasnt my intent :) I was referring to keeponhiking's overall comments where he wasnt planning on using shore power, thus no AC, and how he was comfortable camping without the need for a larger battery. I guess the idea sounded better in my head than it did on paper ;)
Post by: pinstriper on April 25, 2015, 10:57:54 PM
[quote source="/post/9985/thread" timestamp="1430009738" author="@admin"]I see where you got there, but that wasnt my intent :) I was referring to keeponhiking's overall comments where he wasnt planning on using shore power, thus no AC, and how he was comfortable camping without the need for a larger battery. I guess the idea sounded better in my head than it did on paper ;)[/quote][p]Most of my ideas sound better in my head than on...well, not paper...in 1's and 0's.[/p][p]
[/p][p]Don't take me too seriously, I was an English major and we're pedantic SOB's.
