Cracks in brand new tires!
Started by geo92128, April 13, 2015, 06:58:58 PM
The spare! Of course. Dope slaps all around.  :) Sure sorry you're dealing with all this.
[quote source="/post/9728/thread" timestamp="1429659906" author="@sandroad"]Paul, Do you have the off-road package? If not, yours would be the first I've seen or heard about with the standard wheel/tire set up that came with radials. What brand and model is LL using for that?
[/quote][p]
Hi Merlin as promised  Westlake Super ST Steel belted radial ST175/80R13
[p]
tincan
I have the Vail Sport ST205/75D14 tires.  No cracks they look fine.  They do appear to be radial tires.
geo92128
Tincan,
If you have radials the tire number would be ST205/75R14. I am not sure why they use D for bias ply tires. I replaced all my Vail Sport tires with radials.
scout
Monte,
Had a flat on the regular rim and just switched to our spare, and guess what? ...after a quick trip to Banff, we now have the exact same cracks on the sidewall of the  spare.  We have the TRAIL EXPRESS on the 13 RDB. Other two tires on reg rims show no cracks.
The curious thing though is the weight rating of the tire at 1360 LBS. For the single axle on the 13 RDB that puts us at (2X) = 2720 LBS, however the GVWR is listed at 3000 LBS? Anyone have any thoughts on this, or am doing my math wrong? tally plate shows 3000LBS GVWR and 900 LBS for "cargo weight".
Trailer weight for the 13 RDB (without tip out) is calculated as 2100 LBS; therefore the total combined wet haul is another FW167 LBS + GW225 LBS +BW117 LBS + 20 LBS Battery + 20 LBS Propane = ~550 LBS. that would give a wet total of 2650LBS. That gives us a whopping "70 LBS" to load out food, clothes, beers, etc. on the maximum of 1360 for these tires? (don't think we will ever be hauling both a full FW+GW+BW tanks, but the tires should allow for a "full" wet load. (also consider the tip out model adds a 150 LBS to the equation and may or may not have the same tires).
[quote source="/post/11331/thread" timestamp="1432519189" author="@scout"]Monte,
[/quote][font size="3"]The GVWR is the sum of axle weight and tongue weight. I suspect the axle is nominally a 3000# axle, but the weight on the axle is limited by the tires to 2720. For stability the tongue weight should be 10-15 percent of total weight. If you were to load to the maximum of 3000# with 300# (10%) on the tongue, you'd be at 2700# on tires. You'd be within specs, but border line too light on the tongue. You can see you don't have a lot of margin when you start loading up. You should travel with empty waste tanks and only about 15 gallons of FW which includes the 6 gallons in the WH. Some nominal overloading will be OK for short, low speed trips such as from a FW fill station to the campsite and campsite to dump station, but no highway travel. Tires don't like overloads at speed.
scout
Charlie,
thanks for the thoughts, makes sense with the 3000 pound dexter axle. Luckily I do have the room for more tongue weight on the TV=Silverado. I guess this is incentive to get my butt in gear and install the lift kit and new LT BF Goodrich tires I ordered. I will have a bit more comfort at +1700 LBS per tire soon(but then limited by the axle)...not a big fan of the Lion's Head cracker sidewalls...also need to look at a portable GW tank. Luckily the 13er can only carry so much, so our cargo should be manageable. :D
geo92128
LionsHead sent me five new tires after they approved the forms/pictures requested regarding cracks in tires. They sent these out via UPS within two days of getting the forms. I have not received the $30.00 per tire installation cost yet but was told last Friday it takes about 3 weeks for this to be processed. I actually used one of the new bias ply tires for the spare but replaced all the others with Maxxis Radial LT trailer tires. The tire shop where I bought the Maxxis tires gave me $100 for four of the off brand trailer bias ply tires from LH; so I got four Maxxis tires installed for about $200. I feel much better now about my tires!
LL buys the cheapest tires they can get and then if there is a problem, the supplier has to deal with LL customers. They have no skin in the game so why not buy as cheap as possible!
silly122
Brought my 21BHS home on the weekend and my tires are all full of cracks. Scary stuff IMO. I called Lionshead and left a voice mail with my cell number and email address. Anyone know how long it takes to get a call back or can anyone send me the form they sent you and the email to submit the claim back to? I have camping trips planned and would hate to cancel a trip waiting for these things to be replaced.
Thanks in advance.
Posted using my powerful BlackBerry Z30
[p]Glad you got it square. As an aside, Maxxis High Roller II tires are all I will run on my downhill bike. If their auto tires are QC'd anything like them they are of the finest. These tires cost more than twice as much each than you paid. Great deal.
I have already had a flat tire. I took it to an RV dealer, not one who handles LL, and had him replace the bad tire with a new tire, same brand as the rest on my Camplite. It failed due to uneven wear. The RV dealer said that if it happened again, it would be due to axles improperly installed, and then I would have to work with Dexter, and the dealer would help me.
I asked about the cheap tires, and that I would want to eventually replace them with better tires. His reply was that these tires would be replaced due to age before they wore out, and that it didn't make sense to put on a better grade of tire.
geo92128
Poncherelley,
Contact Beth Scott at LionsHead via email;bscott@lionsheadtireandwheel.com; she is in customer service and warranty.They seem to answer email much quicker than phone calls.
geo92128
Leslie,
I have heard the save story, RV tires dry rot or crack due to age and not miles. But I disagree on the quality of tires and went with LT radials. I may be wrong but everytime I look at my tires now I have a much better feeling about safety and longevity. If I have a flat or blow out I will be the first to report.
Not a bad assumption if you consider that you might put 5K miles a year on your camper tires vs. your tow vehicle. When we sold our 2013 16DB that we put 8,000 or so miles on the tires and they looked new. I could see tires aging out before they are wore out. Most tire dealers will not do anything with tires over 10 years old.
keep an eye on the wear of the tires on the same axle you have the flat on. If it still wears uneven (compared to the other axle) you will most generally have a axle alignment problem.
geo92128
By the way, LL does not balance the tires on your trailer ( no idea why) but I have another general trailer that is going on its third set of tires. The last set were LT tires from Sam's and they were balanced. What a difference. The trailer used to bounce down the road, now runs smooth as silk, an amazing difference. I have to believe the same holds true on LT tires for our LL TT. The new tires are balanced and it does make a difference!
