Sewer Hose Tube Too Short
Started by kath, May 26, 2015, 04:18:49 PM
[quote source="/post/11606/thread" timestamp="1432808525" author="@sandroad"]The Supertube from D&W exactly fits the frame parallel to the rear bumper when the tube is fully extended. I mounted ours under the bumper, between the bumper and the black tank. On top of the bumper I mounted a battey box to hold gloves, fittings, and Clorox wipes. I should label the box "Poop Stuff" so no one steals it thinking its a battery. I removed the OEM tube because it makes the plumbing fittings behind it all the more difficult to get to. I guess I need to get Flickr set up. [/quote]Hi Merlin can you take a picture of how you mounted the battery box on your bumper and maybe explain it a bit? Considering doing that myself to store the same type of items you just mentioned.
kath
[quote source="/post/11606/thread" timestamp="1432808525" author="@sandroad"]On top of the bumper I mounted a battey box to hold gloves, fittings, and Clorox wipes. I should label the box "Poop Stuff" so no one steals it thinking its a battery.[/quote]Would serve them right if they did!
Your setup would work well for me, I think. Pictures, please, as soon as you can set up a Flickr account.
[quote source="/post/11635/thread" timestamp="1432832543" author="@kath"]
Quote from: @sandroad" timestamp="1432808525" source="/post/11606/threadOn top of the bumper I mounted a battey box to hold gloves, fittings, and Clorox wipes. I should label the box "Poop Stuff" so no one steals it thinking its a battery.
[/quote][p]Merlin, thought I remembered you mounted that on the tongue? Thought it looked pretty trick there.[/p][p]
[/p][p]Edit: My mistake, crossed wires.
[p]Here's our Sooper Dooper Pooper Toobe:[/p][p]
My first attempt at flickr inserts, hopefully showing the D&W Supertube installed under the rear bumper and the battery box on the bumper holding the poop hose parts.
bbcode was not an option, so we'll see if the link works.
Edit.....It didn't work like I wanted it too, so I'll try again.
Flickr attempt #many
Almost there. How do I remove the account name and file name from the image.
Look at he "BB code" you're pasting and edit out everything except the text ending in .jpg and its associated "img" tags and brackets.
I still plan on producing a "how to" video, which will at first cover iOS on an iPad. It's even easier on a Mac.
That's Chowder, part of this quickly thrown together tutorial;
http://youtu.be/wMNeD9BGSTQ
kath
Great video, @fasteddieb !  @sandroad , have you seen this?  Very helpful for Ipad users.
Yes! And it worked. If I use this, I just have to figure out how to remove my wife's name from every photo since we are using her Yahoo account. Charliem suggested just going in an editing that out of every photo posted, but I'm hoping to find a universal fix.
Thank you for that great video, fasteddieb. I am not familiar with Flicker. I was spoiled by my past membership to forums such as fiberglassrv.com, where you were able to attach photos to your posts easily. I took advantage of that feature many times, but I am intimidated by the process here. I will give it a try, one day, I am sure, but.....is there any chance that this site will ever be upgraded to facilitate the process??
Just read about uploading pictures in " News and Announcements " at the top of this site. Now I understand why you are using Flickr. Guess I'll have to learn something new......darn
Happy Trails......
I think I figured out Photobucket. This looks like it worked. Shows the D&W Supertube installed under the rear bumper and the battery box full of hose parts on top (held down with a u-bolt under the bumper, not just the bungee strap for the lid! Box is labeled "Poop hose parts" to discourage those looking to swipe a battery. Now I just have to re-size the photos to something reasonable. [a href="http://s1083.photobucket.com/user/Merlin3141/media/Tube%20Installation/IMG_1440_zps3hqbpb2k.jpg.html"]
